GCV
Scratch2 Motor Control
Thu Jan 04, 2018 5:24 pm
I have Raspi3 with Scratch 2. I have setup motor control with L293D IC and it works through Python.
http://www.instructables.com/id/DC-Moto ... and-L293D/
Trying to get the same working through scratch using either of the following
1.Using new GPIO Blocks
set gpio X to {output highh/low/input} works
The motor spins forward and backward but I am not able to setup pulse width modulation
2. Using old style
broadcast gpioserveron
broadcast config2out
broadcast config3out
broadcast config4outputpwm
bradcastt gpio2on gpio3off gpio4pwm50
This is not working. Running command gpioserveron on command prompt gives command not found
Looking to create some kind of reusable blocks of code in scratch so that my 8 and 10 Yr old kids can safely experiment and play with this
saltydog
Re: Scratch2 Motor Control
Fri Jan 05, 2018 9:34 am
GPIO PWM is not included with scratch2.
See for adding: s2-pi Creating Scratch 2 Extensions On Your Raspberry Pi
Chris
GCV
Sun Jan 07, 2018 7:46 am
Thanks You Chris
I am not able to run s2pi
[email protected]:~ $ s2pi
File "/usr/local/bin/s2pi", line 7, in <module>
from s2_pi.s2_pi import run_server
File "/usr/local/lib/python3.5/dist-packages/s2_pi/s2_pi.py", line 29, in <module>
from SimpleWebSocketServer import SimpleWebSocketServer, WebSocket
ImportError: No module named 'SimpleWebSocketServer
What libraries am I missing?
Alternatively is there a way to call python functions from scratch? So that I can mask the complexity of GPIO and have kids just play with scratch
ghp
Sun Jan 07, 2018 10:36 am
scratchClient is supporting scratch2 and allows to use prebuild python adapters for GPIO, PWM, Servo, ADC chips and a lot more.
See http://heppg.de/ikg/wordpress/?p=984 for some details.
Regards,
Gerhard
There is an adapter "adapter.gpio.GpioMotorPWM"; sample config is config/config_hbridge_motor.xml.
saltydog
Sun Jan 07, 2018 12:06 pm
Did you use pip or zip to install?
I just tried installing it and pip created issues with python paths that caused library errors.
Using the zip method worked without issues.
Just had a quick play and PWM worked OK.
Never tried in scrartch2. Can't help sorry.
Chris
Return to “Scratch”
