rricharz
create a block to execute a python script
Wed Nov 08, 2017 10:31 am
Has anybody written an extention to create a block which calls the command line (for example a python or shell script), preferrably with arguments?
I would like to send commands to some hardware (output only), which cannot be done by just changing a gpio pin, but can be easily done from within a python script.
The goal is to allow children to manipulate that hardware using scratch.
ghp
Re: create a block to execute a python script
Wed Nov 08, 2017 9:49 pm
with scratchClient, it is possible to start shell scripts.
See http://www.heppg.de/download/scratchCli ... mmand_line
This specific adapter does not use parameters.
scratchClient is written in python and there are quite a few adapters for all sort of hardware available. What type of hardware do you want to control ?
Regards,
Gerhard
rricharz
Thu Nov 09, 2017 7:59 pm
Thanks, Gerhard,
I will try to use what you suggested.
Rene
Return to “Scratch”
Who is online
Users browsing this forum: No registered users and 1 guest
