simplesi
Re: Scratch locks up? (when playing sound?)
Tue May 07, 2013 1:50 pm
yep - will do as soon as I get back home :)
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
timrowledge
Tue May 07, 2013 5:07 pm
This is very odd; I've been running Scratch sounds for *hundreds* of hours with no problems a t all until yesterday when BOOM - or rather '?' which is the lack of boom when required. Total lock-up of the sort that I always thought was impossible on unix.
I'm pretty sure it's not a specifically Squeak/Scratch issue since the same code runs on other machines and indeed other OSs without this happening; so probably some detail of the ALSA driver for this particular hardware.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
simplesi
Tue May 07, 2013 9:12 pm
I'm getting
fatal: destination path '//root/.rpi-firmware' already exists and is not an empty directory.
 !!! Failed to download new firmware files
when trying sudo rpi-update
Simon
simplesi
Tue May 07, 2013 11:00 pm
I think my update problems might be due to running out of space on my sd card if the error msgs are right :(
Just have to dig out a Linux machine tomorrow and do a bit of partition resizing
Simon
simplesi
Wed May 08, 2013 8:44 pm
I did
sudo apt-get update
followed by
sudo apt-get dist upgrade
then
sudo rpi-update
then
sudo rm /etc/asound.conf
I can now do
When Green Flag Press
play note
rest
play drun
rest
play meow
without any crashing :0
Simon
Return to “Scratch”
