simplesi
Alpha testers needed for Scratch-GPIO control
Fri Aug 31, 2012 11:14 pm
Alpha testers needed for my Scratch GPIO package for the RPi - your going to need leds, resistors and determination :)
My final intended audience is primary school teachers and parents of young children - so it needs to just work:)
If you've got a bit of hardware and a little bit of time, I'd be very grateful if you could give it a go :)
http://cymplecy.wordpress.com/2012/08/2 ... spberrypi/
regards
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
simplesi
Re: Alpha testers needed for Scratch-GPIO control
Sat Sep 01, 2012 5:24 pm
Hello - anyone out there? :)
Simon
harrisonc
Sun Sep 02, 2012 1:47 am
Hey si,
I am hoping that I will receive my pi soon but will take a look at this when I'm all setup. I am used to programming an arduino so have all the LEDs ready,
Harrison
jbeale
Sun Sep 02, 2012 5:22 am
sounds good; thanks for doing this! I will see if I can give it a try.
simplesi
Sun Sep 02, 2012 8:22 am
Ta :)
DukeOfTarporley
Sun Sep 02, 2012 2:34 pm
hi
on a new image of RASPIAN
the install scripts run after a raspi-update
however does not run.
ive looked for the files blinktest.sb and rsc.sb and these seem to be missing post install. [used : "find -name *.sb " in the top directory]
happy to do more Alpha testing
ED
simplesi
Sun Sep 02, 2012 2:38 pm
hon a new image of RASPIAN
At last :) Thanks very much - I'll be onto things tonight when I get home - thanks again :)
Simon
PS for info blinktest.sb and rscsb should end up in /home/pi/Scratch
DukeOfTarporley
Sun Sep 02, 2012 3:00 pm
I am running the Aug 16th Image.
I think Stratch has moved to /usr/share/scratch
some more for you below
presume you are trying to kill previous instance but -9 is not an option!
also see the connection issues. IT seems to be trying to connect ot SCRATCH before it has started.....
__________________________________________
[email protected] ~/simplesi_scratch_handler $ sudo bash scratch_gpio.sh
kill: invalid option -- '9'
Usage:
kill [options] <pid> [...]
Options:
<pid> [...] send signal to every <pid> listed
-<signal>, -s, --signal <signal>
specify the <signal> to be sent
-l, --list=[<signal>] list all signal names, or convert one to a name
-L, --table list all signal names in a nice table
-h, --help display this help and exit
-V, --version output version information and exit
For more details see kill(1).
Output Pins are:
11
12
13
15
16
18
Input Pins are:
22
7
Starting to connect... Trying
There was an error connecting to Scratch!
I couldn't find a Mesh session at host: 127.0.0.1, port: 42001
Trying
Trying
Trying
Trying
Trying
Trying
Trying
^X
Trying
^CTraceback (most recent call last):
File "/home/pi/simplesi_scratch_handler/scratch_gpio_handler.py", line 305, in <module>
the_socket = create_socket(host, PORT)
File "/home/pi/simplesi_scratch_handler/scratch_gpio_handler.py", line 275, in create_socket
time.sleep(3)
KeyboardInterrupt
Executing: /usr/lib/squeak/4.4.7-2357/squeakvm -encoding UTF-8 -vm-display-x11 -xshm -plugins /usr/lib/scratch/plugins/:/usr/lib/squeak/4.4.7-2357/ -vm-sound-alsa /usr/share/scratch/Scratch.image /home/pi/Scratch/rsc.sb
DukeOfTarporley
Sun Sep 02, 2012 3:01 pm
i have managed to get a RED LED to work by connection pins 6 & 1 :D
simplesi
Sun Sep 02, 2012 3:40 pm
Great - glad at least the LED is the right way around (and hope you've a resistor in there as well!)
Just some background, you run ScratchGPIO from desktop - it trys to kill any previous pyhton handler prog running and the re-launches the handler prog again (big bodge but until someone does this properly it'll have to do)
I'm on the the 1st Raspbian and not done any updates so there's the 1st issue - I need to get myself up to speed :)
Thats where it is for me as well so that shouldn't be any issue but will check once I've moved to the Aug image when I get home
Yes - as above - kill -9 works on my RPi - ned to check that one out
The python handler waits for Scratch to go into Remote Sensor Connection mode and then makes the connection - those mesages are just useful info for debugging - don't panic.
I'm guessing that maybe you don't have a ScratchGPIO desktop icon or your not using it??
If no desktop icon , then run normal Scratch and enable Remote Sensors by right-clicking on bottom item in the Sensing section
Then sudo python /home/pi/simple_scratch_handler/scratch_gpio_handler.py and it should connect OK and then you should be off to the races :)
Thanks for feedback :)
SImon
DukeOfTarporley
Sun Sep 02, 2012 4:54 pm
[quote][/quote]
hi,
having another look at it.
1)It is unclear where you expect the "missing" .sb files to be. youve told me two locations. The first loaction does not exist pre pr post running of the script.
2) I tried to click on the ikon and I get this error message in a message box:
Failed to execute child process "./simplesi_scratch_handler/scratch_gpio.sh" (Permission denied). That is why I looked at the .sh file and tries to run it from the command line
3)if I start scratch and enable RSC and then run the script it connects!
ED
simplesi
Sun Sep 02, 2012 5:13 pm
I'm reaaly confused myself - all I thought I told you was
blinktest.sb and rsc.sb should end up in /home/pi/Scratch
Maybe there is no /home/pi/Scratch folder to save peoples files in anymore - there is on mine - maybe I created it manually ages ago and have forgotton :eek:
A simple blinktest is
While Green Flag is pressed
forever
  broadcast pin11high
  wait 1 sec
  broadcast p11low
  wait 2 sec
and this will blink pin11
so you could try this out until I can get home and get things sorted :)
Ah - I probably need to add in a
 sudo chmod +x simplesi_scratch_handler/scratch_gpio.sh
Could you try this and see if that cures it please? :)
Great feedback - really really grateful for your time and efforts :)
Simon
DukeOfTarporley
Sun Sep 02, 2012 5:37 pm
ok we have lift off or blink off at least!
I had a little play with you code and it worked.
Ithen worked through your suggestions
I think you must have created the /home/pi/Scratch directory...
I created it and rerun the script and the MISSING .SB files appeared!
I did the CHMOD and now the ICON works
GREAT NEWS! thanks a lot!
NOw to work on getting scratch faster!
simplesi
Sun Sep 02, 2012 6:11 pm
Excellent - looking like midnight before I can get home to alter the installer but it'll be done before bedtime
PS where does Scratch default saving/loading files from now (and does it work - I remember now that the default didn't work!)
For speed issues have a read and join in here http://www.raspberrypi.org/phpBB3/viewt ... 77&t=12522 :)
Simon
simplesi
Sun Sep 02, 2012 11:55 pm
Well just loaded up Raspbian 2012-08-16 and before I did anything, I went looking at the file system and I have a /home/pi/Scratch folder so that's a bit strange that you didn't have it on yours.
So all I've done is add in the sudo chmod +x /home/pi/simplesi_scratch_handler/scratch_gpio.sh and tried it out.
At the moment - its sitting doing nothing - seemingly hung on "Building dependancy package... 0%" :(
I think I'll go back to the old way of installing the GPIo library package
Simon
simplesi
Mon Sep 03, 2012 12:23 am
Ok went back to old way of installing the GPIO drivers and it worked fine.
Desktop icon got created, and the blinktest and rsc files ended up in the /home/pi/Scratch folder and worked OK :)
So, I'm going to wipe SD card - install 2012-08-16 image , do an update and see what happens then
Simon
simplesi
Mon Sep 03, 2012 10:12 am
I believe that its all sorted now so going to launch it properly :)
Thanks for the help :)
Simon
DukeOfTarporley
Mon Sep 03, 2012 11:19 am
Hi .
you seem to be getting there with an updated script on drop box over night.
below is a screen grab from a terminal on a virgin Raspian Aug 2012 SD card pot update.
NOTE this was done before I saw your posting saying you had updated this morning.
Firstly i demonstrate that Scratch is not in in the pi directory but this is probably a mute point
The only error seem to be in the creation of the documents/scratch projects directory. I think you need to include QUOTE MARKS " else you end up creating two seperate directories one being PROJECTS and the other SCRATCH
you can see from the dump below I did this and then the CP woked
ED________________________
[email protected] ~ $ pwd
/home/pi
[email protected] ~ $ ls -l
total 8
drwxr-xr-x 2 pi pi 4096 Aug 16 00:56 Desktop
drwxrwxr-x 2 pi pi 4096 Jul 20 18:07 python_games
[email protected] ~ $ sudo wget https://dl.dropbox.com/s/ay5xsoo5nh3wjf ... io_1.0b.sh -O /boot/install_scratch_gpio.sh
--2012-09-03 10:33:33-- https://dl.dropbox.com/s/ay5xsoo5nh3wjf ... io_1.0b.sh
Resolving dl.dropbox.com (dl.dropbox.com)... 184.73.159.129, 174.129.253.24, 23.21.206.224, ...
Connecting to dl.dropbox.com (dl.dropbox.com)|184.73.159.129|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 138563 (135K) [text/x-sh]
Saving to: `/boot/install_scratch_gpio.sh'
100%[======================================>] 138,563 322K/s in 0.4s
2012-09-03 10:33:40 (322 KB/s) - `/boot/install_scratch_gpio.sh' saved [138563/138563]
total 8
[email protected] ~ $ sudo /boot/install_scratch_gpio.sh
Self Extracting Installer
./blink11.py
./blink11.sb
./GPIOexample.sb
./installer.sh
./python-rpi.gpio_0.3.1a-1_armhf.deb
./rsc.sb
./scratchgpio.desktop
./scratch_gpio_handler.py
./scratch_gpio.sh
Running Installer
Selecting previously unselected package python-rpi.gpio.
(Reading database ... 54978 files and directories currently installed.)
Unpacking python-rpi.gpio (from .../python-rpi.gpio_0.3.1a-1_armhf.deb) ...
Setting up python-rpi.gpio (0.3.1a-1) ...
cp: cannot create regular file `/home/pi/Documents/Scratch Projects': No such file or directory
total 16
-rwxr--r-- 1 root root 331 Sep 3 10:34 blink11.py
drwxr-xr-x 2 pi pi 4096 Sep 3 10:34 Desktop
drwxr-xr-x 2 root root 4096 Sep 3 10:34 simplesi_scratch_handler
[email protected] ~ $ mkdir Scratch
total 20
drwxr-xr-x 2 pi pi 4096 Sep 3 10:34 Scratch
./blink11.py
./blink11.sb
./GPIOexample.sb
./installer.sh
./rsc.sb
./scratch_gpio.sh
Running Installer
(Reading database ... 55007 files and directories currently installed.)
Preparing to replace python-rpi.gpio 0.3.1a-1 (using .../python-rpi.gpio_0.3.1a-1_armhf.deb) ...
Unpacking replacement python-rpi.gpio ...
total 20
-rwxr--r-- 1 root root 331 Sep 3 10:35 blink11.py
[email protected] ~ $ cd scratch
bash: cd: scratch: No such file or directory
[email protected] ~ $ cd Scratch
[email protected] ~/Scratch $ ls -l
total 0
[email protected] ~/Scratch $ mkdir /home/pi/Documents/Scratch Projects
mkdir: cannot create directory `/home/pi/Documents/Scratch': No such file or directory
[email protected]rypi ~/Scratch $ mkdir /home/pi/Documents/Scratch Projects
mkdir: cannot create directory `Projects': File exists
Projects
[email protected] ~/Scratch $ mkdir "/home/pi/Documents/Scratch Projects"
Projects
[email protected] ~/Scratch $ cd ..
/home/pi
total 24
drwxr-xr-x 4 pi pi 4096 Sep 3 10:38 Documents
drwxr-xr-x 3 pi pi 4096 Sep 3 10:37 Scratch
[email protected] ~ $ mkdir "/home/pi/Documents/Scratch Projects"
mkdir: cannot create directory `/home/pi/Documents/Scratch Projects': File exists
./blink11.py
./blink11.sb
./GPIOexample.sb
./installer.sh
./rsc.sb
./scratch_gpio.sh
Running Installer
/home/pi
total 24
-rwxr--r-- 1 root root 331 Sep 3 10:39 blink11.py
total 4
drwxr-xr-x 2 pi pi 4096 Sep 3 10:37 Projects
[email protected] ~/Scratch $ cd projects
bash: cd: projects: No such file or directory
[email protected] ~/Scratch $ cd Projects
[email protected] ~/Scratch/Projects $ ls
[email protected] ~/Scratch/Projects $ ls -l
rknigh21
Tue Sep 04, 2012 4:58 pm
Hi
Thanks a great addition to the Pi.
I ran the installer and it initially failed to install correctly. Looks like the directory "Scratch Projects" is missing from
/home/pi/Documents
I manually created it, re ran the installer and it now works. I have been able to get it to control all 6 LEDS and read in a push switch on pin 7.
If you would like me to test anything specific please let me know. ([email protected])
Robin
techpaul
Tue Sep 04, 2012 8:39 pm
Do you need help creating a script and tests in it for what already exists?
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
simplesi
Tue Sep 04, 2012 9:02 pm
@DukeOfTarporley and @rknigh21
I think I've squared the circle finally :)
It seems that Documents/Scratch Projects is created on first run of normal Scratch which is why I thought it already existed but of course its not there if the 1st thing you do after making a SD card is to run my script :)
So V1.1 will create it if it doesn't exist already.
Sorted ( fingers crossed)
Thanks for help and feedback :)
Simon
simplesi
Sun Sep 09, 2012 8:53 pm
Noticed something strange yesterday at Manchester RaspberryJam that the first time I launched ScratchGPIO from the desktop, nothing seemed to happen - try it again and it worked.
I put it down to dodgy doubleclicking my young Scratch testers (Robert and Jacob) but having just tried it myself - it happened to me as well.
So I've run the gpio_scratch.sh file (Which is what the ScratchGPIO desktop icon points to) in its own LX Terminal window and its not launching Scratch after it runs scratch_gpio_handler.py.
(It does end up launching once you try again in a second window so I need to make the 2 halves of the script run simultaneously and not one after each other
regards
Simon
simplesi
Sun Sep 09, 2012 9:19 pm
Fixed - just needed a couple of & at end of lines :)
Simon
sdmeijer
Fri Sep 14, 2012 10:51 am
I tested it, and works great. Except for one thing; I have a Rev2-board and pin 13 doesn't use GPIO21 anymore, but GPIO27 (http://www.raspberrypi.org/archives/1929), so pin 13 doesn't work at this time. Can you fix this?
croston
Fri Sep 14, 2012 11:29 am
sdmeijer wrote:I tested it, and works great. Except for one thing; I have a Rev2-board and pin 13 doesn't use GPIO21 anymore, but GPIO27 (http://www.raspberrypi.org/archives/1929), so pin 13 doesn't work at this time. Can you fix this?
The next release of RPi.GPIO which this Scratch interface uses automatically detects rev 2 boards and this should fix the issue. Release due in the next few days - I'm run off my feet at the moment.
Return to “Scratch”
