Myra
WeDo + Scratch working!
Tue Jul 10, 2012 10:27 pm
I now have the WeDo crocodile happily chomping on my finger, powered by my Pi, thanks to some help from Alex Bradbury. In order to make this happen you need to add a udev rule which makes the WeDo USB hub readable and writable by the pi user.
Go to directory
/lib/udev/rules.d
make a file called "40-scratch.rules" that contains the following:
ATTRS{idVendor}=="0694", ATTRS{idProduct}=="0003", SUBSYSTEMS=="usb", ACTION=="add", MODE="0666", GROUP="plugdev"
Then start up Scratch, plug in your WeDo USB hub, and the motor control blocks should show up in the Motion area.
Hooray, chomping crocodiles for everyone!
Myra
Re: WeDo + Scratch working!
Wed Jul 11, 2012 8:43 am
Hmmm, I think my announcement was a bit premature. This udev rule works with the Scratch on the new wheezy distribution, but not on squeeze. At least it doesn't work on the version of squeeze that I've got!
asb
Wed Jul 11, 2012 9:15 am
We're moving to wheezy anyway. Very possibly the version of squeak-plugins-scratch used in the wheezy distribution didn't have WeDo, or maybe the pi user isn't a member of the plugdev group (if that's the problem, running scratch as root should still allow WeDo to work).
FangW
Wed Mar 25, 2015 5:40 am
Hi, I just purchased rasberry pi 2 ultimate kit and trying to connect WeDo USB hub to it.
Following the instructions above to create the rule file, but the usb connection is not working. Motor can't be turned on and sensor value is not changing.
Here is dmesg output which looks fine to me:
[ 86.668920] usb 1-1.2: new low-speed USB device number 12 using dwc_otg
[ 86.818378] usb 1-1.2: New USB device found, idVendor=0694, idProduct=0003
[ 86.830740] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 86.843443] usb 1-1.2: Product: LEGO USB Hub V1.00
[ 86.869818] hid-generic 0003:0694:0003.0005: hiddev0,hidraw0: USB HID v1.10 Device [LEGO USB Hub V1.00] on usb-bcm2708_usb-1.2/input0
more /lib/udev/rules.d/40-scratch.rules
Thanks.
Fang
arieg
Sat Apr 11, 2015 9:11 pm
Hi -
Just unpacked a new Pi 2, and connected to WeDo via Scratch. Unfortunately the motor and sensors are not responsive.
dmesg output, and 40-scratch.rules look correct - as in a recent post by Fang
I've succeeded to activate WeDo with python wedo library - but only after tweaking wedo USB device initialization code
Advice appreciated
ArieG
mattmiller
Fri May 01, 2015 9:25 pm
It might be worth trying to use the original version of Scratch just in case its an issue with the latest version
Try running opening up LX Terminal and typing
/usr/bin.scratch.old
arieg
Sat May 02, 2015 7:05 pm
mattmiller wrote:It might be worth trying to use the original version of Scratch just in case its an issue with the latest version
This works perfectly, thanks!!
timrowledge
Sun May 03, 2015 8:53 pm
The problem you're going to face using the old Scratch system is that you lose out on the fairly dramatic performance improvements made over the last year or so as well as some very big speed bumps coming fairly soon.
I can't offer to do any debugging of the WeDo stuff since I have no WeDo hardware, *but* looking at the codebase I don't think it's even being built right now. I'll add it to the (rather long) list of things to look at when possible.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
Return to “Scratch”
