pacebrian0
Scratch3 GPIO input
Fri Apr 02, 2021 6:15 pm
Hi all,
I would like to hook up a sensor to Scratch 3. I checked the GPIO plugins, however, it is mainly used for output and conditions.
Is there a way I can read a stream of data from a sensor using Scratch3?
MiscBits
Re: Scratch3 GPIO input
Sat Apr 03, 2021 10:51 pm
I think you will struggle as the data could be any format.
If you have time to handle many blocks and check for high/low then possibly https://mryslab.github.io/s3-extend/rpi ... ad-digital will help?
Maybe https://edublocks.org/ or https://2simple.com/pythoninpieces/pyth ... ome-users/ could be a better platform if you do not want to dive into raw Python or C.
Return to “Scratch”
