I have just set up a new Raspberry Pi4 on a Hanspree flat screen Monitor that was suggested by Pi Hut but either the screen is dreadful or the Scratch fonts are too small. I think it could be the latter.
The coding lines are virtually indecipherable or blurry. I have tried changing all the settings for the display but it's really only an issue with Scratch in all versions and there's no option to change the font size in the program.
Do I need to run some code? I am very much a NOOB. So please bear with me as I am trying to get my daughter into coding. This will only put her off!
I have only seen one other post about this, but was a while back, so I don't want to action anything if it's put of date.
Thanks.
A
Re: Scratch fonts not visible on Raspberry Pi4
Try my suggestion on the following post and see if it will help you!
viewtopic.php?f=77&t=291984&p=1791760#p1791760
