Matt_Raj
How to install Scratch2.0 on Raspberry pi
Fri Feb 19, 2016 9:14 pm
Hi All,
How do you install Scratch 2.0 ( or update scratch 1.4 ) on a raspberry pi ?
I have a Pi running Raspbian
Thanks!
-Matt
Re: How to install Scratch2.0 on Raspberry pi
Sat Feb 20, 2016 6:05 am
Matt_Raj wrote:Hi All,
Thanks!
-Matt
Scratch 2.0 requires Adobe Flash Player which is not natively available in Raspbian, so version 2 is useless..
Updating. Raspbian can take an hour or so depending on when last updated, this will include NuSratch etcetera, may also be a large download so ensure you have space on SD Card:
sudo apt-get update
sudo apt-get dist-upgrade
sudo reboot
https://www.raspberrypi.org/blog/a-new- ... dded-gpio/
""understanding the theoretical, but not always the end goal""
My other Devices are the ChromeBit CS10, ChromeCast & Huawei Mate 10 Pro SmartPhone
timrowledge
Sun Feb 21, 2016 9:09 pm
Actual MIT Scratch 2.0 cannot run on a Pi since it is a Flash thingy. Flash does not ... well, it just doesn't.
The latest Pi release of Scratch is 1.4-2016-10-15 and if you update to the latest Raspbian Jessie it is include automatically. If you don't want to download the full latest Jessie image file you could try
sudo apt-get update
sudo apt-get upgrade
which, on my machines at least, upgrades Scratch from 1.4-2015-11-11 (at least I think that's what it was) successfully. If you are still using Wheezy this probably won't work but I'm no expert at using apt-get. It has been claimed that
should work.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
Sun Feb 21, 2016 9:30 pm
timrowledge wrote:Actual MIT Scratch 2.0 cannot run on a Pi since it is a Flash thingy. Flash does not ... well, it just doesn't.
sudo apt-get update
should work.
Thanks for confirming what I posted yesterday :?
mattmiller
Sun Feb 21, 2016 10:04 pm
There is a Scratch mod called Whiskers which might be good enough for you.
https://scratch.mit.edu/discuss/topic/157672/?page=1
Its still in development from what I've seen but looks to have great potential as a Scratch 2 lookalike for the Pi
Matthew
Matt_Raj
Mon Feb 22, 2016 1:15 am
sudo apt-get update
should work.
Thanks! I will try this and revert back ( I want to update scratch since a critical feature that I want to use isn't available in the old version
Matt_Raj
Mon Feb 22, 2016 1:16 am
mattmiller wrote:There is a Scratch mod called Whiskers which might be good enough for you.
Matthew
Thanks Matt! I will try all the options one a time to find which one clicks !
Matt_Raj
Mon Feb 22, 2016 1:17 am
Thanks!
-Matt
sudo apt-get update
sudo reboot
Thank You for your input! I will try and get back to you
bertsierra
Contact: Facebook
Thu Sep 14, 2017 6:21 am
As an update to this thread, an offline Scratch 2 editor is now available for Raspberry Pi 2 or 3 systems. This doesn’t depend on Chromium and you don’t need to be Internet connected to run it, either. I believe it requires an ARM7 processor or better; it will fail with a segmentation fault if you run it on ARM6-based boards. I noticed that it was pre-installed with the Raspbian 4.9 Jessie 2017-09-07 release you can download from RaspberryPi.org, but it was super easy to install via the following steps.
First, as recommended above, make sure your apps, libraries, and distribution are fully up to date. The reboot is needed if the distribution upgrade updates anything.
sudo apt-get update
sudo reboot
Then, to install Scratch 2, just type the following. It will increase your system size by about 143MB:
sudo apt-get install scratch2
You’ll see that Scratch 1.4 and Scratch 2 are both installed and available in the Programming menu. Alternatively you can launch Scratch 1.4 as ‘scratch’ in a Terminal window or script, and Scratch 2 as ‘scratch2’ instead. Scratch 1.4 will only load .sb files. Scratch 2.0 will be able to read the older .sb files or the newer .sb2 files it creates. The offline Scratch 2 editor can access GPIO pins whereas the Chromium-based online extension cannot.
Here’s an article dated June 27, 2017 which talks about Scratch 2 offline editor release in more detail, including the GPIO capabilities:
https://www.raspberrypi.org/blog/scratc ... pberry-pi/
Return to “Scratch”
Who is online
Users browsing this forum: No registered users and 1 guest
