franastor
La rasp me envia el siguiente mail
Mon Aug 05, 2013 9:29 am
Como dice el titulo, de vez en cuando la raps me envia este correo y no se porque....
Delivery to the following recipient failed permanently:
     postmaster@raspberrypi
Technical details of permanent failure:
DNS Error: Domain name not found
----- Original message -----
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
        d=gmail.com; s=20120113;
        h=message-id:date:from:to:subject:content-type:x-cron-env:x-cron-env
         :x-cron-env:x-cron-env;
        bh=ufmyvs5OwxMy0Gesn9zW3Sa9V98qRlGmKzu/LxJzxXc=;
        b=Iy9YzUYB1SSHVRajnzRG3h5f0cglT8WMlrWFZ2QWCIkUiiCF2tMJzlbTQEsTV71/Wz
         lyhAHo7OnFc5USXdX7L4yJinuECnJlSYpmp3Sy2xCxcND/5AZIN/1kb+ap+KRLHwwQNL
         3o6+nh67PuhGmGajm0GD0/D0ozZuOHTBV1N/5AUqI+4nDYGoyYLmZjBbe4kHIgvNRu2l
         u9PdS8swU/6ehNJZfcb/UXtbAKh8M8VC0UXOJEOnMe9ISTjGbaLIK4V6vyMtkSxF6TOO
         nSUXIeWF4VF64tWvYVxDmuRP69rwPyi+guBtkKWN4WoKcAXtJra6HtUYak+Nt6qoBUNG
         2tRA==
X-Received: by 10.194.109.104 with SMTP id hr8mr9461703wjb.32.1375597572502;
        Sat, 03 Aug 2013 23:26:12 -0700 (PDT)
Return-Path: <********@gmail.com>
Received: from raspberrypi (*****************************])
        by mx.google.com with ESMTPSA id jf9sm13351250wic.5.2013.08.03.23.26.10
        for <postmaster@raspberrypi>
        (version=TLSv1 cipher=RC4-SHA bits=128/128);
        Sat, 03 Aug 2013 23:26:11 -0700 (PDT)
Message-ID: <51fdf403.e9c6b40a.6083.5f18@mx.google.com>
Received: by raspberrypi (sSMTP sendmail emulation); Sun, 04 Aug 2013 06:26:08 +0000
Date: Sun, 04 Aug 2013 06:26:08 +0000
To: root
Subject: Cron <root@raspberrypi> test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
Content-Type: text/plain; charset=UTF-8
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <LOGNAME=root>
Algjuien sabe que puede estar pasando???
blamarpa
Re: La rasp me envia el siguiente mail
Mon Aug 05, 2013 6:19 pm
¿Le has instalado un servidor de correo (sSMTP sendmail emulation) a la rpi?
Parece que lo enviaste desde tu correo en gmail (Return-Path: <********@gmail.com>, root <morales991@gmail.com>) y el servidor de gmail no encuentra al dominio raspberry (by mx.google.com) con destinatario postmaster@raspberry (for <postmaster@raspberrypi>)
picavid
Fri Nov 01, 2013 10:06 am
Lo has podido solucionar?
A mi me pasa lo mismo. Lo hace por dos motivos desde que instalé ssmtp
- 1º (solucionado) . El hostname no estaba correctamente configurado. Solucionado con http://tipsraspberry.blogspot.com.es/20 ... u-rpi.html Me faltaba modificar el archivo /etc/hosts y aplicar los cambios. Por este motivo evité que mandara un email cada 20 minutos.
- 2º . Pendiente de solucionar. Me manda un email cada vez que ejecuta un evento del CRON. y no sé como solucionarlo.
HEEEEELP
P.D.: Cuidado, si hay demasiados emails devueltos por error de destinatario, que es el caso (pi@raspberry), Gmail os bloqueará la cuenta que estéis usando para el envío durante 24h por considerarla SPAM.
iscroman
Fri Jan 17, 2014 6:44 pm
Gracias por sus comentarios muchachos.
Efectivamente es un cron que se ejecuta cada 20 minutos con esta sentencia: "test -x /etc/init.d/sendmail && /usr/share/sendmail/sendmail cron-msp".
Hay que deshabilitarlo solamente.
Saludos cordiales desde México. :lol:
Return to “Español”
