AYUDA: Problemas con las librerias MFRC522 RFID
Posted: Fri May 08, 2020 2:26 am
by Takkata
Hola, Tengo un proyecto y estoy usando la raspbery pi 3 para ingresar usuarios a una base de datos con tecnologia RFID, específicamente el modulo RC522, busque e instale las bibliotecas correspondientes:
https://github.com/lthiery/SPI-Py
https://github.com/mxgxw/MFRC522-python
Y a la hora de probar el codigo Read.py de MFRC522, la consola me da lo siguientes errores:
  File "Write.py", line 41, in <module>
    MIFAREReader = MFRC522.MFRC522()
  File "/home/pi/rfid/MFRC522-python/MFRC522.py", line 135, in __init__
    self.MFRC522_Init()
  File "/home/pi/rfid/MFRC522-python/MFRC522.py", line 406, in MFRC522_Init
    self.MFRC522_Reset()
  File "/home/pi/rfid/MFRC522-python/MFRC522.py", line 138, in MFRC522_Reset
    self.Write_MFRC522(self.CommandReg, self.PCD_RESETPHASE)
  File "/home/pi/rfid/MFRC522-python/MFRC522.py", line 141, in Write_MFRC522
    spi.transfer(((addr<<1)&0x7E,val))
TypeError: function takes exactly 2 arguments (1 given)
El codigo de Read.py es el siguiente:
#!/usr/bin/env python
# -*- coding: utf8 -*-
#    Copyright 2014,2018 Mario Gomez <mario.gomez@teubi.co>
#    This file is part of MFRC522-Python
#    MFRC522-Python is a simple Python implementation for
#    the MFRC522 NFC Card Reader for the Raspberry Pi.
#    MFRC522-Python is free software: you can redistribute it and/or modify
#    it under the terms of the GNU Lesser General Public License as published by
#    the Free Software Foundation, either version 3 of the License, or
#    (at your option) any later version.
#    MFRC522-Python is distributed in the hope that it will be useful,
#    but WITHOUT ANY WARRANTY; without even the implied warranty of
#    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#    GNU Lesser General Public License for more details.
#    You should have received a copy of the GNU Lesser General Public License
#    along with MFRC522-Python.  If not, see <http://www.gnu.org/licenses/>.
import RPi.GPIO as GPIO
import MFRC522
import signal
continue_reading = True
# Capture SIGINT for cleanup when the script is aborted
def end_read(signal,frame):
    global continue_reading
    print "Ctrl+C captured, ending read."
    continue_reading = False
    GPIO.cleanup()
# Hook the SIGINT
signal.signal(signal.SIGINT, end_read)
# Create an object of the class MFRC522
# This loop keeps checking for chips. If one is near it will get the UID and authenticate
while continue_reading:
    # Scan for cards
    (status,TagType) = MIFAREReader.MFRC522_Request(MIFAREReader.PICC_REQIDL)
    # If a card is found
    if status == MIFAREReader.MI_OK:
        print "Card detected"
    # Get the UID of the card
    (status,uid) = MIFAREReader.MFRC522_Anticoll()
    # If we have the UID, continue
        # Print UID
        print "Card read UID: %s,%s,%s,%s" % (uid[0], uid[1], uid[2], uid[3])
        # This is the default key for authentication
        key = [0xFF,0xFF,0xFF,0xFF,0xFF,0xFF]
        # Select the scanned tag
        MIFAREReader.MFRC522_SelectTag(uid)
        # Authenticate
        status = MIFAREReader.MFRC522_Auth(MIFAREReader.PICC_AUTHENT1A, 8, key, uid)
        print "\n"
        # Check if authenticated
            # Variable for the data to write
            data = []
            # Fill the data with 0xFF
            for x in range(0,16):
                data.append(0xFF)
            print "Sector 8 looked like this:"
            # Read block 8
            MIFAREReader.MFRC522_Read(8)
            print "\n"
            print "Sector 8 will now be filled with 0xFF:"
            # Write the data
            MIFAREReader.MFRC522_Write(8, data)
            print "\n"
            print "It now looks like this:"
            # Check to see if it was written
            print "\n"
            data = []
            # Fill the data with 0x00
                data.append(0x00)
            print "Now we fill it with 0x00:"
            print "\n"
            print "It is now empty:"
            print "\n"
            # Stop
            MIFAREReader.MFRC522_StopCrypto1()
            # Make sure to stop reading for cards
        else:
            print "Authentication error"
Y el codigo de MFRC522 es el siguiente:
import spi
import signal
import time
class MFRC522:
  NRSTPD = 22
  MAX_LEN = 16
  PCD_IDLE       = 0x00
  PCD_AUTHENT    = 0x0E
  PCD_RECEIVE    = 0x08
  PCD_TRANSMIT   = 0x04
  PCD_TRANSCEIVE = 0x0C
  PCD_RESETPHASE = 0x0F
  PCD_CALCCRC    = 0x03
  PICC_REQIDL    = 0x26
  PICC_REQALL    = 0x52
  PICC_ANTICOLL  = 0x93
  PICC_SElECTTAG = 0x93
  PICC_AUTHENT1A = 0x60
  PICC_AUTHENT1B = 0x61
  PICC_READ      = 0x30
  PICC_WRITE     = 0xA0
  PICC_DECREMENT = 0xC0
  PICC_INCREMENT = 0xC1
  PICC_RESTORE   = 0xC2
  PICC_TRANSFER  = 0xB0
  PICC_HALT      = 0x50
  MI_OK       = 0
  MI_NOTAGERR = 1
  MI_ERR      = 2
  Reserved00     = 0x00
  CommandReg     = 0x01
  CommIEnReg     = 0x02
  DivlEnReg      = 0x03
  CommIrqReg     = 0x04
  DivIrqReg      = 0x05
  ErrorReg       = 0x06
  Status1Reg     = 0x07
  Status2Reg     = 0x08
  FIFODataReg    = 0x09
  FIFOLevelReg   = 0x0A
  WaterLevelReg  = 0x0B
  ControlReg     = 0x0C
  BitFramingReg  = 0x0D
  CollReg        = 0x0E
  Reserved01     = 0x0F
  Reserved10     = 0x10
  ModeReg        = 0x11
  TxModeReg      = 0x12
  RxModeReg      = 0x13
  TxControlReg   = 0x14
  TxAutoReg      = 0x15
  TxSelReg       = 0x16
  RxSelReg       = 0x17
  RxThresholdReg = 0x18
  DemodReg       = 0x19
  Reserved11     = 0x1A
  Reserved12     = 0x1B
  MifareReg      = 0x1C
  Reserved13     = 0x1D
  Reserved14     = 0x1E
  SerialSpeedReg = 0x1F
  Reserved20        = 0x20
  CRCResultRegM     = 0x21
  CRCResultRegL     = 0x22
  Reserved21        = 0x23
  ModWidthReg       = 0x24
  Reserved22        = 0x25
  RFCfgReg          = 0x26
  GsNReg            = 0x27
  CWGsPReg          = 0x28
  ModGsPReg         = 0x29
  TModeReg          = 0x2A
  TPrescalerReg     = 0x2B
  TReloadRegH       = 0x2C
  TReloadRegL       = 0x2D
  TCounterValueRegH = 0x2E
  TCounterValueRegL = 0x2F
  Reserved30      = 0x30
  TestSel1Reg     = 0x31
  TestSel2Reg     = 0x32
  TestPinEnReg    = 0x33
  TestPinValueReg = 0x34
  TestBusReg      = 0x35
  AutoTestReg     = 0x36
  VersionReg      = 0x37
  AnalogTestReg   = 0x38
  TestDAC1Reg     = 0x39
  TestDAC2Reg     = 0x3A
  TestADCReg      = 0x3B
  Reserved31      = 0x3C
  Reserved32      = 0x3D
  Reserved33      = 0x3E
  Reserved34      = 0x3F
  serNum = []
  def __init__(self, dev='/dev/spidev0.0', spd=1000000):
    spi.openSPI(device=dev,speed=spd)
    GPIO.setmode(GPIO.BOARD)
    GPIO.setup(self.NRSTPD, GPIO.OUT)
    GPIO.output(self.NRSTPD, 1)
    self.MFRC522_Init()
  def MFRC522_Reset(self):
  def Write_MFRC522(self, addr, val):
  def Read_MFRC522(self, addr):
    val = spi.transfer((((addr<<1)&0x7E) | 0x80,0))
    return val[1]
  def SetBitMask(self, reg, mask):
    tmp = self.Read_MFRC522(reg)
    self.Write_MFRC522(reg, tmp | mask)
  def ClearBitMask(self, reg, mask):
    tmp = self.Read_MFRC522(reg);
    self.Write_MFRC522(reg, tmp & (~mask))
  def AntennaOn(self):
    temp = self.Read_MFRC522(self.TxControlReg)
    if(~(temp & 0x03)):
      self.SetBitMask(self.TxControlReg, 0x03)
  def AntennaOff(self):
    self.ClearBitMask(self.TxControlReg, 0x03)
  def MFRC522_ToCard(self,command,sendData):
    backData = []
    backLen = 0
    status = self.MI_ERR
    irqEn = 0x00
    waitIRq = 0x00
    lastBits = None
    n = 0
    i = 0
    if command == self.PCD_AUTHENT:
      irqEn = 0x12
      waitIRq = 0x10
    if command == self.PCD_TRANSCEIVE:
      irqEn = 0x77
      waitIRq = 0x30
    self.Write_MFRC522(self.CommIEnReg, irqEn|0x80)
    self.ClearBitMask(self.CommIrqReg, 0x80)
    self.SetBitMask(self.FIFOLevelReg, 0x80)
    self.Write_MFRC522(self.CommandReg, self.PCD_IDLE);
    while(i<len(sendData)):
      self.Write_MFRC522(self.FIFODataReg, sendData[i])
      i = i+1
    self.Write_MFRC522(self.CommandReg, command)
      self.SetBitMask(self.BitFramingReg, 0x80)
    i = 2000
    while True:
      n = self.Read_MFRC522(self.CommIrqReg)
      i = i - 1
      if ~((i!=0) and ~(n&0x01) and ~(n&waitIRq)):
        break
    self.ClearBitMask(self.BitFramingReg, 0x80)
    if i != 0:
      if (self.Read_MFRC522(self.ErrorReg) & 0x1B)==0x00:
        status = self.MI_OK
        if n & irqEn & 0x01:
          status = self.MI_NOTAGERR
          n = self.Read_MFRC522(self.FIFOLevelReg)
          lastBits = self.Read_MFRC522(self.ControlReg) & 0x07
          if lastBits != 0:
            backLen = (n-1)*8 + lastBits
          else:
            backLen = n*8
          if n == 0:
            n = 1
          if n > self.MAX_LEN:
            n = self.MAX_LEN
          i = 0
          while i<n:
            backData.append(self.Read_MFRC522(self.FIFODataReg))
            i = i + 1;
      else:
    return (status,backData,backLen)
  def MFRC522_Request(self, reqMode):
    status = None
    backBits = None
    TagType = []
    self.Write_MFRC522(self.BitFramingReg, 0x07)
    TagType.append(reqMode);
    (status,backData,backBits) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, TagType)
    if ((status != self.MI_OK) | (backBits != 0x10)):
    return (status,backBits)
  def MFRC522_Anticoll(self):
    backData = []
    serNumCheck = 0
    serNum = []
    self.Write_MFRC522(self.BitFramingReg, 0x00)
    serNum.append(self.PICC_ANTICOLL)
    serNum.append(0x20)
    (status,backData,backBits) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE,serNum)
    if(status == self.MI_OK):
      i = 0
      if len(backData)==5:
        while i<4:
          serNumCheck = serNumCheck ^ backData[i]
          i = i + 1
        if serNumCheck != backData[i]:
      else:
    return (status,backData)
  def CalulateCRC(self, pIndata):
    self.ClearBitMask(self.DivIrqReg, 0x04)
    self.SetBitMask(self.FIFOLevelReg, 0x80);
    i = 0
    while i<len(pIndata):
      self.Write_MFRC522(self.FIFODataReg, pIndata[i])
      i = i + 1
    self.Write_MFRC522(self.CommandReg, self.PCD_CALCCRC)
    i = 0xFF
    while True:
      n = self.Read_MFRC522(self.DivIrqReg)
      i = i - 1
      if not ((i != 0) and not (n&0x04)):
        break
    pOutData = []
    pOutData.append(self.Read_MFRC522(self.CRCResultRegL))
    pOutData.append(self.Read_MFRC522(self.CRCResultRegM))
    return pOutData
  def MFRC522_SelectTag(self, serNum):
    backData = []
    buf = []
    buf.append(self.PICC_SElECTTAG)
    buf.append(0x70)
    i = 0
    while i<5:
      buf.append(serNum[i])
      i = i + 1
    pOut = self.CalulateCRC(buf)
    buf.append(pOut[0])
    buf.append(pOut[1])
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, buf)
    if (status == self.MI_OK) and (backLen == 0x18):
      print "Size: " + str(backData[0])
      return    backData[0]
    else:
      return 0
  def MFRC522_Auth(self, authMode, BlockAddr, Sectorkey, serNum):
    buff = []
    # First byte should be the authMode (A or B)
    buff.append(authMode)
    # Second byte is the trailerBlock (usually 7)
    buff.append(BlockAddr)
    # Now we need to append the authKey which usually is 6 bytes of 0xFF
    i = 0
    while(i < len(Sectorkey)):
      buff.append(Sectorkey[i])
      i = i + 1
    i = 0
    # Next we append the first 4 bytes of the UID
    while(i < 4):
      buff.append(serNum[i])
      i = i +1
    # Now we start the authentication itself
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_AUTHENT,buff)
    # Check if an error occurred
    if not(status == self.MI_OK):
      print "AUTH ERROR!!"
    if not (self.Read_MFRC522(self.Status2Reg) & 0x08) != 0:
      print "AUTH ERROR(status2reg & 0x08) != 0"
    # Return the status
    return status
  def MFRC522_StopCrypto1(self):
    self.ClearBitMask(self.Status2Reg, 0x08)
  def MFRC522_Read(self, blockAddr):
    recvData = []
    recvData.append(self.PICC_READ)
    recvData.append(blockAddr)
    pOut = self.CalulateCRC(recvData)
    recvData.append(pOut[0])
    recvData.append(pOut[1])
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, recvData)
      print "Error while reading!"
    i = 0
    if len(backData) == 16:
      print "Sector "+str(blockAddr)+" "+str(backData)
  def MFRC522_Write(self, blockAddr, writeData):
    buff = []
    buff.append(self.PICC_WRITE)
    buff.append(blockAddr)
    crc = self.CalulateCRC(buff)
    buff.append(crc[0])
    buff.append(crc[1])
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, buff)
    if not(status == self.MI_OK) or not(backLen == 4) or not((backData[0] & 0x0F) == 0x0A):
    print "%s backdata &0x0F == 0x0A %s" % (backLen, backData[0]&0x0F)
    if status == self.MI_OK:
        i = 0
        buf = []
        while i < 16:
            buf.append(writeData[i])
            i = i + 1
        crc = self.CalulateCRC(buf)
        buf.append(crc[0])
        buf.append(crc[1])
        (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE,buf)
            print "Error while writing"
            print "Data written"
  def MFRC522_DumpClassic1K(self, key, uid):
    i = 0
    while i < 64:
        status = self.MFRC522_Auth(self.PICC_AUTHENT1A, i, key, uid)
            self.MFRC522_Read(i)
        else:
        i = i+1
  def MFRC522_Init(self):
    self.MFRC522_Reset();
    self.Write_MFRC522(self.TModeReg, 0x8D)
    self.Write_MFRC522(self.TPrescalerReg, 0x3E)
    self.Write_MFRC522(self.TReloadRegL, 30)
    self.Write_MFRC522(self.TReloadRegH, 0)
    self.Write_MFRC522(self.TxAutoReg, 0x40)
    self.Write_MFRC522(self.ModeReg, 0x3D)
    self.AntennaOn()
Si alguien es capaz de ayudarme se lo agradecería totalmente
