Buenos dias, tengo un problema y creo que va muy relacionado también, no se porque pero la tarjeta de memoria SD se llena cuando empiezo a descargar por transmission.
S.ficheros Tamaño Usados Disp Uso% Montado en
rootfs 15G 14G 392K 100% /
/dev/root 15G 14G 392K 100% /
devtmpfs 236M 0 236M 0% /dev
tmpfs 48M 208K 47M 1% /run
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 95M 0 95M 0% /run/shm
/dev/mmcblk0p1 56M 17M 40M 30% /boot
/dev/sda1 466G 69G 398G 15% /media/torrent
tmpfs 95M 0 95M 0% /tmp
He ido a las carpetas de descargas y hay cosas pero en incompletos no.
He estado mirando en mi fichero de configuracion de transmission pero no he visto nada raro.
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "
http://www.example.com/blocklist",
"cache-size-mb": 4,
"dht-enabled": true,
"download-dir": "/media/torrent/descargas",
"download-limit": 100,
"download-limit-enabled": 0,
"download-queue-enabled": true,
"download-queue-size": 5,
"blocklist-url": "
"cache-size-mb": 4,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/media/torrent/incompletos",
"incomplete-dir-enabled": false,
"lpd-enabled": false,
"max-peers-global": 200,
"message-level": 2,
"peer-congestion-algorithm": "",
"peer-limit-global": 240,
"message-level": 2,
"peer-limit-per-torrent": 60,
"peer-port": 35000,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": false,
"preallocation": 1,
"prefetch-enabled": 1,
"peer-port": 35000,
"preallocation": 1,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{c64cd42f3959bce6d68d9afe4a470e6800f15ca8YT7dRJMI",
"rpc-port": 50000,
"ratio-limit": 2,
"rpc-port": 50000,
"rpc-url": "/transmission/",
"rpc-username": "i0roloe",
"rpc-whitelist": "127.0.0.1",
"rpc-whitelist-enabled": false,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": true
