Good:
After downloading a movie from transmission and trying to rewind it (it's a .avi format movie) I get the message of "have a nice day". I have researched a bit but I have not found anything conclusive. Can somebody help me?
Thank you.
"have a nice day" is just the signoff message from omxplayer. I.e., it always displays that message just before the program exits. Therefore, there is no real significance to that seeing that message.
But something you are doing is causing omxplayer to exit. My guess is that somehow, omxplayer is unable to deal with your file - usually, this is caused by its not being able to handle whatever codec you are using.
"Have a nice day" es solo el mensaje de inicio de sesión de omxplayer. Es decir, siempre muestra ese mensaje justo antes de que el programa salga. Por lo tanto, no hay ningún significado real para que vea ese mensaje.
Pero algo que estás haciendo está causando omxplayer para salir. Mi conjetura es que de alguna manera, Omxplayer es incapaz de hacer frente a su archivo - por lo general, esto es causado por su no ser capaz de manejar cualquier codec que está utilizando.
If this post appears in the wrong forums category, my apologies.
