Pi 2 con Raspbian Jessie LITE no actualiza (solucionado : )
Posted: Sun Nov 13, 2016 5:16 pm
by hiddenotebook
Hola queria preguntar ¿si es normal que mi PI con SO Raspbian Jessie Lite no actualice?
Me da una serie de errores:
hidden@notebook:~ $ sudo apt-get update
Err http://archive.raspberrypi.org jessie InRelease
Err http://archive.raspberrypi.org jessie Release.gpg
  Could not resolve 'archive.raspberrypi.org'
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
  Could not resolve 'mirrordirector.raspbian.org'
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/Release.gpg  Could not resolve 'archive.raspberrypi.org'
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg  Could not resolve 'mirrordirector.raspbian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Cambiando el fichero sources.list para que NO apunte a:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
Y que apunte a este otro:
deb https://www.raspbian.org/RaspbianMirrors jessie main contrib non-free rpi
Me dice que si no tengo instalado apt-transport-https:
hidden@notebook:/etc/apt $ sudo apt-get update
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
Así que dejo de nuevo el fichero sources.list como estaba e intento instalar apt-transport-https y me da el mismo error:
hidden@notebook:/etc/apt $ sudo apt install apt-transport-https
Building dependency tree
The following extra packages will be installed:
  libcurl3-gnutls
The following NEW packages will be installed:
  apt-transport-https libcurl3-gnutls
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 359 kB of archives.
After this operation, 641 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main apt-transport-https armhf 1.0.9.8.3
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/curl/libcurl3-gnutls_7.38.0-4+deb8u4_armhf.deb  Could not resolve 'mirrordirector.raspbian.org'
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/apt/apt-transport-https_1.0.9.8.3_armhf.deb  Could not resolve 'mirrordirector.raspbian.org'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Así que ya no se que mas puedo hacer, alguien me echa una mano? aunque sea al cuello jajaja
No se si sera por cambiar el nombre de la PI a hidden@notebook es lo que quería porque solo voy a usarla como servidor con apache pero tampoco lo puedo instalar por el problema que tengo.
Gracias por vuestro tiempo! un saludo y hablamos.
Alber.
Re: Raspberry pi 2 con Raspbian Jessie (LITE) no actualiza :
Posted: Sun Nov 13, 2016 5:31 pm
by 56kbps
¿Pero tienes conectividad a Internet (o resolución de DNS) en la máquina? esos mensajes tipo "Could not resolve..." o "Failed to fetch..." indican todo lo contrario.
En mi sources.list sólo tengo esta línea:
Yo también uso Lite y acabo de actualizar el sistema sin problemas ejecutando: "apt-get update && apt-get upgrade".
Posted: Sun Nov 13, 2016 5:39 pm
by hiddenotebook
Estoy conectado por ethernet muy raro seria no tener internet voy a hacer un ping
Posted: Sun Nov 13, 2016 5:42 pm
by hiddenotebook
hidden@notebook:/etc/apt $ ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=2.50 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.728 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.601 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=0.586 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=0.616 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=0.676 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=0.616 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=0.608 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=0.647 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=0.594 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=0.632 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=0.590 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=0.602 ms
64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=0.667 ms
64 bytes from 192.168.1.1: icmp_seq=15 ttl=64 time=0.622 ms
64 bytes from 192.168.1.1: icmp_seq=16 ttl=64 time=0.621 ms
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=0.656 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=0.490 ms
^C
--- 192.168.1.1 ping statistics ---
18 packets transmitted, 18 received, 0% packet loss, time 17016ms
rtt min/avg/max/mdev = 0.490/0.725/2.505/0.434 ms
No se mucho pero eso es que tengo internet no?
sera por cambiar el nombre del terminal? seguí este tuto perdon este fue para la ip estática je je este otro
Posted: Sun Nov 13, 2016 5:49 pm
by 56kbps
Estás haciendo ping a una máquina de tu rel local (192.168.1.0/24), eso demuestra que tienes acceso a la red local pero no necesariamente a Internet.
Prueba con:
ping 8.8.8.8
Y luego con:
ping google.com
Posted: Sun Nov 13, 2016 6:04 pm
by hiddenotebook
hidden@notebook:/etc/apt $ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=58 time=35.8 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=58 time=34.9 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=58 time=34.4 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=58 time=33.6 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=58 time=33.9 ms
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 33.604/34.546/35.804/0.796 ms
^Chidden@notebook:/etc/apt $ ping google.com
ping: unknown host google.com
El primero si pero con google dice que no reconoce el host ¿esto que significa?
Posted: Sun Nov 13, 2016 6:09 pm
by 56kbps
Que aun teniendo conectividad no tienes resolución de nombres (DNS). Por eso te falla al intentar actualizar el sistema.
Nos has pasado un enlace donde se aconseja editar cierto archivo. Qué has puesto en "static domain_name_servers..."?
Posted: Sun Nov 13, 2016 6:28 pm
by hiddenotebook
En /etc/dhcpcd.conf puse al final:
# Set an static IP by hiddenotebook
interface eth0
static ip_address=192.168.1.132/24
static routers=192.168.1.1
static domain_name_servers=192.168.1
Posted: Sun Nov 13, 2016 6:40 pm
by 56kbps
Esta línea está mal:
No sólo no es una IP válida (pues está incompleta) sino que además apunta a una máquina en tu red local que debería tener un servidor DNS, cosa que dudo (¿tal vez el router?).
Te recomiendo que pongas otra IP, preferiblemente los servidores DNS de tu proveedor de Internet. O en su defecto, para simplificar, puedes limitarte a poner las de Google (8.8.8.8 y 8.8.4.4):
static domain_name_servers=8.8.8.8
Creo que con esto vas a poder solucionar tu problema. :)
Posted: Sun Nov 13, 2016 6:54 pm
by hiddenotebook
No me funcionan macho algo mas tengo por ahí y no se que es dejo el archivo sources.list por si ves algo raro:
#Esta es la version original por defecto para actualizar
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
#Esta tampoco me funciona
#deb https://www.raspbian.org/RaspbianMirrors jessie main contrib non-free rpi
# Vamos a probar con esta:
#deb http://mirrors.coopvgg.com.ar/raspbian/raspbian/ jessie main contrib non-free rpi
voy a ver /etc/network/interfaces a ver si veo algo:
EDITO:
Yo no veo nada raro..
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
En mi router tambien puse en Static IP Lease List: (A maximum 32 entries can be configured)
la mac y la ip de raspberry b8:27:eb:84:f5:0d 192.168.1.132
Si hago un ifconfig todo parece correcto:
hidden@notebook:/etc/apt $ ifconfig
eth0      Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          inet addr:192.168.1.132  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::19ab:7eee:2e23:ed34/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:5540 errors:0 dropped:3 overruns:0 frame:0
          TX packets:5248 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:395561 (386.2 KiB)  TX bytes:815571 (796.4 KiB)
Posted: Sun Nov 13, 2016 7:10 pm
by 56kbps
¿Te funcionan los pings a dominios? ¿Al hacer los cambios has reiniciado el sistema? En caso contrario sería preferible para que pille la nueva configuración.
El fallo al hacer ping a "google.com" es para mi absolutamente esclarecedor: la actualización del sistema no te va a poder funcionar hasta que te funcionen los pings a dominios*. Primero intenta solucionar eso, luego ya mira lo otro.
*Al fin y al cabo, una actualización de sistema requiere obligatoriamente bajarse archivos de Internet, que serán bajados conectándose a servidores usando sus nombres de dominio: "mirrordirector.raspbian.org". Si este dominio no se resuelve, no hay actualización posible.
Posted: Sun Nov 13, 2016 7:11 pm
by hiddenotebook
Por fin un sudo reboot sirvió para poder actualizar jajaja ya me tiraba de los pelos jajaja muchas gracias 56kbps me has ayudado mucho te lo agradezco en el alma, da gusto tener esta comunidad.
Un saludo y no olvidare tu nombre me has solucionado el problema muy bien gracias, gracias, gracias. :D :D :D
Re: Pi 2 con Raspbian Jessie LITE no actualiza (solucionado
Posted: Sun Nov 13, 2016 7:16 pm
by 56kbps
Me alegro! Para eso estamos. ;)
Posted: Sun Nov 13, 2016 8:55 pm
by hiddenotebook
Si me funciona hacer ping a google.com : )
Mirando mas a fondo en mi router comtrend he visto en DNS Server Configuration que dice:
Use the following Static DNS IP address:
Primary DNS server: XXX...
Secondary DNS server: XXX...
Y con esas también funciona, he seguido tu recomendación anterior:
Y funciona no puedo poner las IP's por razones obvias pero ya que estamos dejamos el tema bien completo.
Hoy me has enseñado algo muy valioso te lo agradezco mucho de verdad.
