Me da una serie de errores:
hidden@notebook:~ $ sudo apt-get update
Err http://archive.raspberrypi.org jessie InRelease
Err http://archive.raspberrypi.org jessie Release.gpg
Could not resolve 'archive.raspberrypi.org'
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
Could not resolve 'mirrordirector.raspbian.org'
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/Release.gpg Could not resolve 'archive.raspberrypi.org'
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg Could not resolve 'mirrordirector.raspbian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb https://www.raspbian.org/RaspbianMirrors jessie main contrib non-free rpi
hidden@notebook:/etc/apt $ sudo apt-get update
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?Code: Select all
hidden@notebook:/etc/apt $ sudo apt install apt-transport-https
Building dependency tree
The following extra packages will be installed:
libcurl3-gnutls
The following NEW packages will be installed:
apt-transport-https libcurl3-gnutls
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 359 kB of archives.
After this operation, 641 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main apt-transport-https armhf 1.0.9.8.3
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/curl/libcurl3-gnutls_7.38.0-4+deb8u4_armhf.deb Could not resolve 'mirrordirector.raspbian.org'
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/apt/apt-transport-https_1.0.9.8.3_armhf.deb Could not resolve 'mirrordirector.raspbian.org'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
No se si sera por cambiar el nombre de la PI a hidden@notebook es lo que quería porque solo voy a usarla como servidor con apache pero tampoco lo puedo instalar por el problema que tengo.
Gracias por vuestro tiempo! un saludo y hablamos.
Alber.
