copio el codigo siguiente y me da error en la linea 15 #Now setup the first pin for HIGH OUTPUT
gpio.setup(led[0],gpio.OUT) impidiendome continuar, como no se mucho de python no se que falla...
# Import the module that runs the GPIO pins
import RPi.GPIO as gpio
# Import the sleep function for pausing
from time import sleep
# Import the random integer function
from random import randint
# This fuction lights a specif LED.
# The led variable input is a 2 item list,
# each item representing a pin
def lightLED(led):
#First clear the pins, by setting them all to input
for pin in charliePins:
gpio.setup(pin,gpio.IN)
gpio.output(led[0],gpio.HIGH)
#Now setup the second pin for LOW OUTPUT
gpio.setup(led[1],gpio.OUT)
gpio.output(led[1],gpio.LOW)
# define an array of pins used as leads
charliePins=[7,11,12]
# Define the top and bottom rows as the number of the
# LED in the list of LEDs to be created.
top=[0,2,4]
bottom=[1,3,5]
# Define the array of LEDs. This is normally done
# by defining each pair separately, but I wanted the code
# to be easy to expand, so I went with this method of
# cycling through the pins and creating the pairs. It
# has the disadvantage of not making them in order for larger
# sets of pairs, but is easier to maintain, IMO.
charlieLEDS=[]
for i in range(0,len(charliePins)-1):
for j in range(i+1,len(charliePins)):
charlieLEDS.append([charliePins[i],charliePins[j]])
charlieLEDS.append([charliePins[j],charliePins[i]])
# setup the GPIO pins to BOARD mode
gpio.setmode(gpio.BOARD)
#Run the code over and over and over again
while 1:
# First light them in order
for led in charlieLEDS:
lightLED(led)
sleep(.25)
# Next flash the top and bottom rows
for flash in range(0,6):
for light in range(0,100):
for led in top:
lightLED(charlieLEDS[led])
sleep(.001)
for led in bottom:
sleep(.001)
# Finally, flash them randomly
for counter in range(0,26):
lightLED(charlieLEDS[randint(0,5)
sleep(.1)
