Champ8888
python-chess stockfish
Fri May 31, 2019 1:39 pm
Ich habe ein schachprogramm geschrieben das mit hilfe von Stockfish eine KI erstellt.
Auf Windows funktioniert es aber auf Linux bekomme ich immer eine Fehlermeldung
Code:
import chess
import chess.engine
def zug(brett):
    engine = chess.engine.SimpleEngine.popen_uci("./stockfish-10-linux/Linux/stockfish_10_x64")
    global result
    global a
    board = brett
    result = engine.play(board, chess.engine.Limit(time=0.100))
    a = result.move
    engine.quit()
    return a
board = chess.Board()
zug(board)
Fehlermeldung:
File "/home/pi/Python-Programme/Zauberschach_fertig/schach_ki.py", line 21, in <module>
zug(board)
File "/home/pi/Python-Programme/Zauberschach_fertig/schach_ki.py", line 8, in zug
File "/home/pi/.local/lib/python3.5/site-packages/chess/engine.py", line 2302, in popen_uci
return cls.popen(UciProtocol, command, timeout=timeout, debug=debug, setpgrp=setpgrp, **popen_args)
File "/home/pi/.local/lib/python3.5/site-packages/chess/engine.py", line 2294, in popen
return run_in_background(background, debug=debug)
File "/home/pi/.local/lib/python3.5/site-packages/chess/engine.py", line 193, in run_in_background
return future.result()
File "/usr/lib/python3.5/concurrent/futures/_base.py", line 405, in result
return self.__get_result()
File "/usr/lib/python3.5/concurrent/futures/_base.py", line 357, in __get_result
raise self._exception
File "/home/pi/.local/lib/python3.5/site-packages/chess/engine.py", line 172, in background
loop.run_until_complete(coroutine(future))
File "/usr/lib/python3.5/asyncio/base_events.py", line 466, in run_until_complete
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/home/pi/.local/lib/python3.5/site-packages/chess/engine.py", line 2283, in background
transport, protocol = yield from Protocol.popen(command, setpgrp=setpgrp, **popen_args)
File "/home/pi/.local/lib/python3.5/site-packages/chess/engine.py", line 803, in popen
return (yield from loop.subprocess_exec(cls, *command, **popen_args))
File "/usr/lib/python3.5/asyncio/base_events.py", line 1189, in subprocess_exec
bufsize, **kwargs)
File "/usr/lib/python3.5/asyncio/unix_events.py", line 191, in _make_subprocess_transport
**kwargs)
File "/usr/lib/python3.5/asyncio/base_subprocess.py", line 39, in __init__
stderr=stderr, bufsize=bufsize, **kwargs)
File "/usr/lib/python3.5/asyncio/unix_events.py", line 695, in _start
universal_newlines=False, bufsize=bufsize, **kwargs)
File "/usr/lib/python3.5/subprocess.py", line 676, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.5/subprocess.py", line 1282, in _execute_child
raise child_exception_type(errno_num, err_msg)
OSError: [Errno 8] Exec format error
Kann mir bitte jemand helfen?
holgerble
Re: python-chess stockfish
Mon Jun 03, 2019 9:56 am
Falsche Bibliothek ???
x64 ???
stretch ist 32 Bit Betriebssystem!!
Champ8888
Mon Jun 03, 2019 5:10 pm
Ich habe allerdings keine 32 Bit Version für Linux gefunden.
Außerdem bin ich ziemlich verwirrt da es bei Windows eine exe Datei ist und bei Linux eine "Gemeinsame Bibliothek". Was auch immer das ist.
mline
Mon Jun 03, 2019 8:18 pm
Weil es keine gibt. Wenn du das Binary für raspberry pi brauchst (arm) dann müsstest du dir die source laden und selbst kompilieren. Oder falls es das ist was du benötigst, installiere dir das Paket aus der Repository für raspbian
sudo apt-get install stockfish
Es wird sich bei der von der Seite herunterladbaren Datei auch um eine ausführbare Datei handeln. Allerdings läuft die nur auf der Architektur x86_64 (oder kurz x64) und nicht auf arm. Bibliotheken haben bei Linux die Extension .so
Champ8888
Tue Jun 04, 2019 3:44 pm
Ich habe jetzt mit dem Befehl stockfish installiert.
Aber was muss ich in die Zeile: engine = chess.engine.SimpleEngine.popen_uci("") schreiben?
B.z.w. muss ich dann einen anderen Befehl verwenden?
mline
Tue Jun 04, 2019 4:26 pm
Ich vermute mal /usr/bin/stockfish
Champ8888
Tue Jun 04, 2019 4:41 pm
Jetzt funktioniert es endlich. :D
Es war allerdings unter Games gespeichert. Warum auch immer.
Vielen Dank für die Hilfe.
Return to “Deutsch”
