Hallo
Habe gerade da neueste Image gezogen ,
und habe wieder eine CPU Auslastung von 92 % ,und Temperatur 53 Grad ....
Ist das normal ?
thx
topQuelle: http://www.raspbmc.com/wiki/user/freque ... questions/Q: I just installed Raspbmc and it’s slow with 100% CPU usage
A: This is temporary and is because when XBMC launches for the first time it must update any plugins that are out of date. This takes CPU as it must download the plugins, unpack them and configure them. You are advised to leave it a couple of minutes before trying to do anything with XBMC. The system will then respond normally after this. You can also disable automatic plugin updating in the future.
