Dioguex
Ethernet dongle não é detectado
Fri Jul 18, 2014 10:32 am
Bom dia,
Adquiri um ethernet dongle Logilink ua0158a para o meu raspberry, para um projecto. o problema é que não consigo que o raspi detecte o dongle.
Se utilizar o comando dmesg e o resultado foi:
[ 1.871828] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.884953] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.898762] usb usb1: Product: DWC OTG Controller
[ 1.906883] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[ 1.916028] usb usb1: SerialNumber: bcm2708_usb
[ 1.924739] hub 1-0:1.0: USB hub found
[ 1.931991] hub 1-0:1.0: 1 port detected
[ 1.939988] dwc_otg: FIQ enabled
[ 1.940006] dwc_otg: NAK holdoff enabled
[ 1.940028] Module dwc_common_port init
[ 1.940367] usbcore: registered new interface driver uas
[ 1.949082] Initializing USB Mass Storage driver...
[ 1.957535] usbcore: registered new interface driver usb-storage
[ 1.966907] USB Mass Storage support registered.
[ 2.405741] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.416139] Indeed it is in host mode hprt0 = 00001101
[ 2.645983] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.675659] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.706427] hub 1-1:1.0: USB hub found
[ 2.713852] hub 1-1:1.0: 3 ports detected
[ 3.016520] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.266203] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.284538] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.302156] smsc95xx v1.0.4
[ 3.371041] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4d:49:10
[ 3.485731] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.610159] usb 1-1.2: New USB device found, idVendor=0b95, idProduct=1790
[ 3.649302] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.680092] usb 1-1.2: Product: AX88179
[ 3.695625] usb 1-1.2: Manufacturer: ASIX Elec. Corp.
[ 3.704423] usb 1-1.2: SerialNumber: 0000133B9935<F
Pelo que percebi o dongle é detectado como novo dispositivo, mas não activa, ou seja, tenho lá um cabo de rede ligado e não tenho nenhuma informação de uma nova porta no ifconfig.
O SO que estou a utilizar é o OpenWrt.
A energia não deve ser problema porque pelo que medi no TP1 e TP2 está a 4,95V.
Podem ajudar a que o dongle seja detectado?
Obrigado.
Cumprimentos,
Dioguex
MrBreno
Re: Ethernet dongle não é detectado
Fri Dec 12, 2014 6:11 pm
Olá,
Olha o problema nem é tanto a queda de tensão mas sim de corrente, se estiver só com um dongle ethernet na USB e um teclado usb padrão realmente não é motivo, agora se estiver com mais devices na usb (tipo hub, adaptador wif e etc..) pode vir a afetar sim.
Com relação a saída do dmesg, oque deveria aparecer é algo como "setting usb device as eth1" ou algo do tipo, uma vez que a eth0 é reconhecida logo de cara.
Para ter certeza que não é hardware, instale o raspbian, e insira o adaptador, se ele reconhecer o dongle usb como eth1 então não é hardware, provavelmente será necessário mecher nos módulos do opwnert para fazer funcionar.
Hardware:
Raspberry PI Model B (with 5Vdc 1A Power source)
Acessories:
7 port USB HUB
TPLINK USB nano WIFI (with 5Vdc 1A separete Power source)
Ethernet via USB adapter
Logitech K240 mouse and keyboard
raquel
Thu Jan 08, 2015 3:22 pm
Eu estava com esse problema e assim que comprei este hub: http://www.clickplus.pt/p6744 passou a dar.
Espero poder ajudar. Cumprimentos
Return to “Português”
