Page 3 of 4
Re: Android On RasPi
Posted: Mon Dec 23, 2013 8:07 am
by jamesh
All the known Android stuff is pretty ,much unusable due to low speed (none of the builds are HW accelerated). It's not a Foundation supported OS.
Posted: Mon Dec 23, 2013 9:34 am
by pavand
Hi ,
Android os(2.3) is working in raspberry pi board and is clearly given in youtube . If you have any images about android os for raspberry pi just post here . Because I want to run android app in that board.
Posted: Mon Dec 23, 2013 9:53 am
by jamesh
There's no doubt it can run, but it just runs very badly/slowly.
I don't know who has the builds. Google may help.
Posted: Mon Dec 23, 2013 10:04 am
by pavand
Hi ,
Can any one post the links for android os images( froyo , gingerbread) for raspberry pi
Posted: Mon Dec 23, 2013 10:59 am
by redhawk
Posted: Mon Dec 23, 2013 11:04 am
by pavand
Only ginger bread image is there , but it is not booting in raspberry pi .
Any froyo image file for raspberry pi .
Posted: Mon Dec 23, 2013 11:26 am
by redhawk
Android on Pi is a work in process but without device drivers from Broadcom or any help from them the project is good as dead.
Even if Android was running on the Pi it has nothing special to offer no more than what already exists with Raspbian or XBMC.
If you really want to play around with Android but don't own a tablet or phone then try the Android emulator as part of the Android SDK or run VirtualBox with Android-x86.
Richard S.
Posted: Mon Dec 23, 2013 12:14 pm
by pavand
I downloaded the gingerbread image in the link you posted but I am getting some text on the screen end with rainbow color screen . But I saw many reviews it is booted clearly . I change the modes and groups in config text but the result is same .
Posted: Mon Dec 23, 2013 12:29 pm
by DougieLawson
This bears all of the characteristics of deceased equine flagellation.
Posted: Tue Dec 24, 2013 3:45 am
by pavand
Hi ,
If you have any Donut or Eclair or fro yo images file links for raspberry pi .
Regards
pavan
Posted: Mon Dec 30, 2013 3:29 am
by pavand
Hi ,
Android OS is installing in Rpi model A or model B board ?
Pavan
Posted: Mon Dec 30, 2013 8:55 am
by jamesh
It will probably install on both, but be unusable on both, but even more unusable on the A due to the lower memory.
Posted: Wed Jan 01, 2014 6:14 am
by pavand
Hi ,
Raspberry pi support .flv format or not ?
Which formats are supported in raspberry pi .
Pavan
Posted: Wed Jan 01, 2014 11:37 am
by redhawk
If this question is related to Android then you're wasting your time with video playback there is no proper driver support not even audio.
For video playback it is recommended to use omxplayer already pre-installed with Raspbian or any XBMC distro.
As for flv this is just a container file like avi or mp4 they are handled by the above mentioned programs providing the video codec is supported by the Pi's hardware decoder.
The Pi out of the box supports h.264/avc and with paid licenses you can also play vc-1 and mpeg-2/1 video files, however non-supported codecs will not work and render as audio only playback.
Richard S.
Posted: Fri Jan 03, 2014 4:56 am
by pavand
Can any one send the links for video/audio driver source code for android OS in Raspberry pi . I am getting black screen after I installed Media play back application in android OS .
Pavan
Posted: Fri Jan 03, 2014 9:32 am
by jamesh
You are very persistent.
Although Android will run, its going to be very very slow.
The source code for Android is available from Google.
Posted: Fri Jan 03, 2014 9:11 pm
by DougieLawson
pavand wrote:Can any one send the links for video/audio driver source code for android OS in Raspberry pi . I am getting black screen after I installed Media play back application in android OS .
Why do you keep flogging this dead horse? What does Android have that can't be done with one of the stock Linux distros that are known to work and are well used on the Raspberry Pi?
Posted: Fri Jan 03, 2014 10:22 pm
by jamesh
DougieLawson wrote:pavand wrote:Can any one send the links for video/audio driver source code for android OS in Raspberry pi . I am getting black screen after I installed Media play back application in android OS .
Angry Birds, or in the Raspi case, slightly miffed and more slowly moving birds.
Posted: Sat Jan 04, 2014 2:43 am
by DougieLawson
Perhaps the Raspberry Pi Foundation should talk to Rovio about a RPi version of Angry Birds and Bad Piggies. In much the same way that you got that ancient version of Pocket Minecraft.
Posted: Sat Jan 04, 2014 11:52 am
by redhawk
Rovio don't make Linux builds of Angry Birds so I very much doubt they would bothered to write one for the Pi.
Some Linux x86 users have been getting around this problem by running the Windows build + Wine but as we all know x86 emulators suck on the Pi.
Please do yourself a favour forget about Android on the Pi with working drivers, it's a bad idea and never going to happen given it's low tech old processor you're better off buying a dedicated Android Box TV i.e.
http://www.ebay.co.uk/itm/AndroidBoxTVT ... 1240845651
Richard S.
Posted: Thu Jan 30, 2014 9:41 am
by BoS
DougieLawson wrote:Why do you keep flogging this dead horse? What does Android have that can't be done with one of the stock Linux distros that are known to work and are well used on the Raspberry Pi?
A fully working USB stack?? One can live in hope
Posted: Thu Jan 30, 2014 10:00 am
by jamesh
BoS wrote:DougieLawson wrote:Why do you keep flogging this dead horse? What does Android have that can't be done with one of the stock Linux distros that are known to work and are well used on the Raspberry Pi?
Won't make any difference - the USB difficulties are at a lower level than the software stack. The HW in the chip itself is a bit pants, so a lot of effort is being expended sorting out the driver to get round the problem.
And of course, Android just uses the Linux USB software stack that it sits on.
Posted: Tue Feb 04, 2014 8:28 pm
by BoS
jamesh wrote:BoS wrote:DougieLawson wrote:Why do you keep flogging this dead horse? What does Android have that can't be done with one of the stock Linux distros that are known to work and are well used on the Raspberry Pi?
That's it, squash my only crumb of hope lol - my project is pretty much dead in the water now as isochronous transfers don't work and I can't get any estimate as to when they might.
BoS
Posted: Wed Feb 05, 2014 9:17 am
by jamesh
I believe a new implementation of the USB driver is in development. No idea of schedule, or whether it will fix your particular issue.
Posted: Sat Mar 01, 2014 7:04 am
by moocow1452
Does the unlocking of the GPU code make an Android port a lot more feasible?
