jorsantander
whic android works better on rasperry
Wed Dec 19, 2012 10:56 pm
whic android works better on rasperry, I ve been trying to installing on 512 ram rasperry pero none of them seems to work, a black screen shows on the nothing
redhawk
Re: whic android works better on rasperry
Wed Dec 19, 2012 11:07 pm
There isn't an official Android build for the PI yet not until Broadcom have release their hardware drivers yet (which seems to be taking forever).
Richard S.
jorsantander
Thu Dec 20, 2012 3:37 am
which one you use, or have used in the past
flyinghappy
Thu Dec 20, 2012 4:06 am
Most people use Raspbian (linux).
Have a look here, it has the official OS selections for the board... http://www.raspberrypi.org/downloads
Pi with ArchLinux running a minidlna/samba home server
aaa801
Thu Dec 20, 2012 4:50 pm
android doesn't run on raspberry, its a separate OS
jackokring
Contact: ICQ
Thu Dec 20, 2012 5:37 pm
For most people running .apk files from android market would be enough. With the pre release of JavaFX, most android apps will be easy to convert form source. Theoretically the android API should be possible to translate into a JavaFX set of runtime classes and an install script.
The problem then becomes getting google to allow market downloads to the Pi, and the supplying of a Pi application which does all the fancy sychronization to google.
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
CoolApps
Fri Dec 21, 2012 1:56 pm
jackokring wrote:For most people running .apk files from android market would be enough. With the pre release of JavaFX, most android apps will be easy to convert form source. Theoretically the android API should be possible to translate into a JavaFX set of runtime classes and an install script.
False, the Play Store downloads two files which are not .apk files.
One file is the application itself and the second file is the update, when updating only the second file (update file) will be downloaded and installed.
You can install .apk with the package installer application.
Android, web, linux, windows and scripting developer
Download Page: caftp.3owl.com
6677
Sat Dec 22, 2012 5:20 pm
you would have to decompile the dalvik bytecode and recompile it for the regular jvm. The 2 VM's arent compatible.
Or, you could implement the dalvik VM straight on the pi.
CoolApps
Mon Feb 18, 2013 8:13 pm
The Play Store/Android Market installs applications has two files, the original application and the update package which are not .apk, they are in different file extensions.
Return to “Android”
