Sugandha123
APK corrupted in SD card using Android Things
Fri Apr 12, 2019 4:35 am
I am using raspberry Pi 3 Model B with Android Things with 64 GB SD card. Most of the times my apk in the sd card has been corrupted.I don't know why.
I am using Android things. When apk corrupts, only android things shows on the display.
Can you please tell me what can be the issue and how can I resolve this issue?
Please refer
pcmanbob
Re: SD card corrupt
Sat Apr 13, 2019 11:25 am
Hi.
I don't know about android on the pi but common causes of SD card corruption when using Linux are , no doing a proper shutdown and just pulling the power , or a bad or underrated power supply which causes repeated low volt situations.
You will probably have to reinstall your OS on the SD card if its truly corrupted and wont boot.
Return to “Android”
