FarisNT
Running Android Failed :( I am new user
Fri Nov 23, 2012 12:46 am
Hi
Thanks for reading, I am a new user
I try to install Android as mentioned here
http://www.youtube.com/watch?v=paUgfXKD ... h_response
I download the Image named as Gingerbread+EthernetManager from this site
http://androidpi.wikia.com/wiki/Android_Pi_Wiki (Scroll to the end of the page)
but when I place it on the SD "ORITE 16GB" I got this message
I am using Raspberry PI (C) 2011
My Laptop running Windows 7
time out waiting for hardware intruuipt -cmd12
Error - 110 sending stop command,, original md respones 0x900, card status 0x900
final write to SD card still running
this message loop for sometime and the device simply reboot
What can I do
mahjongg
Re: Running Android Failed :( I am new user
Fri Nov 23, 2012 1:25 am
This is still very experimental, unless you are an expert I would suggest you wait a bit for an official release. I doubt at this moment many people here are able to help you to get it running.
aaa801
Fri Nov 23, 2012 9:35 am
Nope thats not a razdroid error, that looks like your sd card isn't making contact properly =/
FarisNT
Fri Nov 23, 2012 12:22 pm
Thanks for your help
but if it was an SD Card problem
why when I run "2012-10-28-wheezy-raspbian" it work normally
I have an Andriod software want them to run on this deivce.
What can I do
ghans
Fri Nov 23, 2012 12:31 pm
Android is still in alpha , especially 4.0 !
Wait till Broadcom releases the inernal build or some guy
with lots (lots !) of free time , heaps of money (i suppose he hasn't to work , what ?) ,
unbelievable amounts of experience and intelligence and a very kind heart gets HW
acceleration running by some other way on the Pi and releases it for community use.
ghans
aaa801
Fri Nov 23, 2012 12:35 pm
FarisNT wrote:Thanks for your help
What can I do
Since i made that image your having issues with, will you listen to what i said?
FarisNT
Fri Nov 23, 2012 12:58 pm
aaa801
OK
So what is your advice, should I change the SD Card ?
aaa801
Fri Nov 23, 2012 2:02 pm
It looks like it wrote the image badly or that the sd card isnt fully down on the contacts =/
FarisNT
Sat Nov 24, 2012 1:03 am
OK Thanks
I will get a new SD and Make sure that the SD is inserted good, and inform you later, and if there is any debug information I will send it to you
aaa801
Sat Nov 24, 2012 12:43 pm
FarisNT wrote:OK Thanks
Actualy its generaly a issue with the sd connecter on the board of the rpi, given that its asaying sd write failed, Are the corners of your sd card broken by any chance?
Return to “Android”
