jean.michel.78
system UI has stopped android 4.0
Tue Nov 13, 2012 7:39 pm
hello i have uploaded he android_sd_2.tar.gz
and copied the img file to an SDCARD 8Gb with dd if=android_sd_2.img of=/dev/sdc
1)
i am surprised because i cannot mount the partitions on my linux system
why i dont know
when i boot with this card i have android but it is full on message "unfortunately , system UI has stopped
it very slow
sometimes i have "unfortunately, trebuchet has stopped"
the mouse let a lot of blues arrow
somebody has got this problem
chocis
Re: system UI has stopped android 4.0
Wed Nov 14, 2012 7:25 am
Seriously, you should read information in page you downloaded the image.
Current status
CyanogenMOD 9 (based on Android 4.0): Boots, unusable
Framebuffer issues: possibly due to the lack of double buffering and/or page flipping in the bcm2708 framebuffer driver
Proper libEGL library not present: libraries *are* available, but those are linked against glibc instead of android's bionic libc (issue filed here)
UI Crashes
jean.michel.78
Wed Nov 14, 2012 9:59 am
i have copied image on another Sdcard same result
biut now i can mount parttions on my linux PC
and may be add something .
i dont understand your reply
redhawk
Wed Nov 14, 2012 11:00 am
Current status
CyanogenMOD 9 (based on Android 4.0): Boots, ==>unusable <==
Android on the PI isn't officially supported yet therefore the current images you can download and flash are effectively experimental builds.
From what I understand Broadcom are currently working on drivers for the PI I would suggest you wait until they get released first.
Richard S.
CoupedUp
Wed Nov 14, 2012 1:46 pm
jean.michel.78 wrote:i have copied image on another Sdcard same result
Je ne parle pas du français mais j'espère que ceci aidera mieux transmet le message.
L'androïde ne travaille pas pourtant. Tout le construit d'Androïde sont inutilisable. Il y a un morceau de logiciel qui toujours est exigé pour lui travailler.
jean.michel.78
Wed Nov 14, 2012 3:35 pm
merci coupedup pour ta traduction
yes i have understood your status "unusable"
but i have seen a video where i have seen it working ( android 4.0 ) for that reason i am so tenacious
thank anyway for your replies
6677
Wed Nov 14, 2012 7:13 pm
The "working" video was not a public available version of android. It uses broadcom code which we didnt have.
aaa801
Fri Nov 16, 2012 7:30 pm
Use this, http://rosefire.us/%7Erazdroid/aaa801/G ... Manager.7z
The 4.0 image is UNUSABLE , as stated in the wiki....
Return to “Android”
