I would like to know if it is possible to put android application on a raspberry pi 3 B +? thank you
aBUGSworstnightmare wrote: ↑Fri Jun 29, 2018 1:56 pmAre you sure?
https://www.raspberrypi.org/blog/magpi- ... pberry-pi/
https://emteria.com
But you need an RPi3 for it as the +rev is not supported (as of today)
MathieuSollier wrote: ↑Fri Jun 29, 2018 7:26 amHello,
From https://help.emteria.com/kb/devices-rpi-3 it is not clear if the 3B+ is supported or not. The comment "Bluetooth doesn’t work on Raspberry Pi 3 Model B+ (but works on Raspberry Pi 3 Model B)" suggest that it is supported on a 3B+ but not as fully supported as on the 3B. The Emteria forums may contain more definitive and detailed information.aBUGSworstnightmare wrote: ↑Fri Jun 29, 2018 1:56 pmhttps://emteria.com
