adb connect <ip>I have installed droidvnc but for some strange reason there are no binaries in the folder in order to do a direct app run on command line. I look in the com. folder and there is just two empty folders of cache and code_cache with nothing in them. However it isn't a problem with the os I dont think because I tested installng the odroid app on an emulator and looking in the same folder and the were still empty however on the emulator I can click the icon from the gui and it runs fine which ofc I can't do on the headless pi.
Below is the output I got when I tried the command I found online for running an app from the command line yet there was still no server running after that iirc (was some days ago and was trying many things to no avail).
$adb shell monkey -p org.onaips.vnc -c android.intent.category.LAUNCHER 1
bash arg: -p
bash arg: org.onaips.vnc
bash arg: -c
bash arg: android.intent.category.LAUNCHER
bash arg: 1
args: [-p, org.onaips.vnc, -c, android.intent.category.LAUNCHER, 1]
arg: "-p"
arg: "org.onaips.vnc"
arg: "-c"
arg: "android.intent.category.LAUNCHER"
arg: "1"
data="org.onaips.vnc"
data="android.intent.category.LAUNCHER"
** SYS_KEYS has no physical keys but with factor 2.0%.
