adb is enabled over network, just run adb connect 192.#####karlenando wrote:how can I do if I have no screen?
It may not be on that ip,karlenando wrote:Ok.
I have found how to run adb
I have written "./adb connect 192.168.1.251" (this is the ip my router reserved to rpi)
The answer has been: "unable to connect to 192.168.1.251:5555"
Then I have enabled port 5555 on my router but the answer was the same.
# logcat |more
--------- beginning of /dev/log/main
I/cm ( 54): Welcome to Android 2.3.7 /
I/cm ( 55): _
I/cm ( 56): __ __ _ ___ _ _ __ ___ __ _ _ _ _ __ __))
I/cm ( 57): ((_ \(/'((_( ((\( ((_)((_( (('((\( ((`1( ((_)((_(
I/cm ( 58): )) _))
I/cm ( 59):
I/mountsd ( 73): Checking filesystems..
I/run-parts( 49): e2fsck 1.41.12 (17-May-2010)
I/run-parts( 49): e2fsck: Device or resource busy while trying to open /dev/block/mmcblk0p2
I/run-parts( 49): Filesystem mounted or opened exclusively by another program?
E/mountsd ( 79): Unable to repair filesystem, disabling apps2sd
I/DEBUG ( 99): debuggerd: Jul 27 2012 21:14:00
--------- beginning of /dev/log/system
I/Vold ( 97): Vold 2.1 (the revenge) firing up
D/Vold ( 97): USB mass storage support is not enabled in the kernel
D/Vold ( 97): usb_configuration switch is not enabled in the kernel
D/Vold ( 97): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
I/Netd ( 98): Netd 1.0 starting
D/Vold ( 97): Volume sdcard state changing 0 (No-Media) -> 2 (Pending)
D/DHCP ( 108): ===== DHCP message:
D/DHCP ( 108): op = BOOTREQUEST (1), htype = 1, hlen = 6, hops = 0
D/DHCP ( 108): xid = 0x08140000 secs = 0, flags = 0x8000 optlen = 14
D/DHCP ( 108): ciaddr = 0.0.0.0
D/DHCP ( 108): yiaddr = 0.0.0.0
D/DHCP ( 108): siaddr = 0.0.0.0
D/DHCP ( 108): giaddr = 0.0.0.0
D/DHCP ( 108): chaddr = { b8 27 eb 81 3a dd }
D/DHCP ( 108): sname = ''
D/DHCP ( 108): file = ''
D/DHCP ( 108): op 53 len 1 { 01 } discover
D/DHCP ( 108): op 55 len 4 { 01 03 06 1c }
D/Vold ( 97): Volume sdcard state changing 2 (Pending) -> 1 (Idle-Unmounted)
D/AndroidRuntime( 101):
D/AndroidRuntime( 101): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
I/AndroidRuntime( 101): Heap size: -Xmx16m
D/AndroidRuntime( 101): CheckJNI is ON
I/ ( 102): ServiceManager: 0x13b5d50
W/AudioHardwareInterface( 102): Using stubbed audio hardware. No sound will be produced.
D/AudioHardwareInterface( 102): setMode(NORMAL)
I/CameraService( 102): CameraService started (pid=102)
D/AudioFlinger( 102): setParameters(): io 1, keyvalue routing=2, tid 130, calling tid 102
I/AudioFlinger( 102): AudioFlinger's thread 0x13b7630 ready to run
I/ethernet( 101): Loading ethernet jni class
I/SamplingProfilerIntegration( 101): Profiler is disabled.
I/Zygote ( 101): Preloading classes...
E/Zygote ( 101): setreuid() failed. errno: 30
D/dalvikvm( 101): GC_EXPLICIT freed 47K, 77% free 237K/1024K, external 0K/0K, paused 5ms
W/MediaProfiles( 101): could not find media config xml file
D/RenderScript_jni( 101): RenderScript JNI library not found!
D/dalvikvm( 101): GC_FOR_MALLOC freed 2914K, 57% free 2208K/5123K, external 0K/0K, paused 75ms
D/DHCP ( 108): TIMEOUT
D/dalvikvm( 101): GC_FOR_MALLOC freed 2633K, 52% free 2486K/5123K, external 0K/0K, paused 69ms
D/DHCP ( 108): op = BOOTREPLY (2), htype = 1, hlen = 6, hops = 0
D/DHCP ( 108): xid = 0x08140000 secs = 0, flags = 0x8000 optlen = 64
D/DHCP ( 108): yiaddr = 192.168.1.21
D/DHCP ( 108): siaddr = 192.168.1.1
D/DHCP ( 108): op 53 len 1 { 02 } offer
D/DHCP ( 108): op 54 len 4 { c0 a8 01 01 }
D/DHCP ( 108): op 51 len 4 { 00 00 54 60 }
D/DHCP ( 108): op 1 len 4 { ff ff ff 00 }
D/DHCP ( 108): op 3 len 4 { c0 a8 01 01 }
D/DHCP ( 108): op 6 len 4 { c0 a8 01 01 }
D/DHCP ( 108): op 28 len 4 { c0 a8 01 ff }
D/DHCP ( 108): --- dhcp offer (2) ---
D/DHCP ( 108): ip 192.168.1.21 gw 192.168.1.1 mask 255.255.255.0
D/DHCP ( 108): dns1: 192.168.1.1
D/DHCP ( 108): server 192.168.1.1, lease 21600 seconds
D/DHCP ( 108): xid = 0x09140000 secs = 0, flags = 0x8000 optlen = 26
D/DHCP ( 108): op 53 len 1 { 03 } request
D/DHCP ( 108): op 50 len 4 { c0 a8 01 15 }
D/DHCP ( 108): xid = 0x09140000 secs = 0, flags = 0x8000 optlen = 64
D/DHCP ( 108): op 53 len 1 { 05 } ack
D/DHCP ( 108): --- dhcp ack (5) ---
D/DHCP ( 108): configuring eth0
I/Zygote ( 101): ...preloaded 1829 classes in 8268ms.
D/Zygote ( 101): setreuid() error ignored, same uid.
D/dalvikvm( 101): GC_EXPLICIT freed 852K, 48% free 2678K/5123K, external 0K/0K, paused 57ms
I/Zygote ( 101): Preload resources disabled, skipped.
D/dalvikvm( 101): GC_EXPLICIT freed 25K, 49% free 2653K/5123K, external 0K/0K, paused 46ms
D/dalvikvm( 101): GC_EXPLICIT freed <1K, 49% free 2653K/5123K, external 0K/0K, paused 45ms
I/dalvikvm( 101): System server process 133 has been created
I/Zygote ( 101): Accepting command socket connections
D/SystemClock( 133): Setting time of day to sec=86400
W/SystemServer( 133): System clock is before 1970; setting to 1970.
E/BatteryService( 133): usbOnlinePath not found
E/BatteryService( 133): batteryVoltagePath not found
E/BatteryService( 133): batteryTemperaturePath not found
I/sysproc ( 133): Entered system_init()
I/sysproc ( 133): ServiceManager: 0x1958bb0
I/SurfaceFlinger( 133): SurfaceFlinger is starting
I/SurfaceFlinger( 133): dithering enabled
I/SurfaceFlinger( 133): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
E/SurfaceFlinger( 133): Couldn't open /sys/power/wait_for_fb_sleep or /sys/power/wait_for_fb_wake
I/gralloc ( 133): using (fd=25)
I/gralloc ( 133): id = BCM2708 FB
I/gralloc ( 133): xres = 656 px
I/gralloc ( 133): yres = 512 px
I/gralloc ( 133): xres_virtual = 656 px
I/gralloc ( 133): yres_virtual = 1024 px
I/gralloc ( 133): bpp = 16
I/gralloc ( 133): r = 11:5
I/gralloc ( 133): g = 5:6
I/gralloc ( 133): b = 0:5
I/gralloc ( 133): width = 512 mm (32.543751 dpi)
I/gralloc ( 133): height = 656 mm (19.824390 dpi)
I/gralloc ( 133): refresh rate = 60.00 Hz
D/libEGL ( 133): egl.cfg not found, using default config
D/libEGL ( 133): loaded /system/lib/egl/libGLES_android.so
W/SurfaceFlinger( 133): ro.sf.lcd_density not defined, using 160 dpi by default.
I/SurfaceFlinger( 133): EGL informations:
I/SurfaceFlinger( 133): # of configs : 8
I/SurfaceFlinger( 133): vendor : Android
I/SurfaceFlinger( 133): version : 1.4 Android META-EGL
I/SurfaceFlinger( 133): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_ANDROID_image_native_buffer EGL_ANDROID_swap_rectangle EGL_ANDROID_get_render_buffer
I/SurfaceFlinger( 133): Client API: OpenGL ES
I/SurfaceFlinger( 133): EGLSurface: 5-6-5-0, config=0x0
I/SurfaceFlinger( 133): OpenGL informations:
I/SurfaceFlinger( 133): renderer : Android PixelFlinger 1.4
I/SurfaceFlinger( 133): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 133): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix GL_OES_EGL_image GL_OES_compressed_ETC1_RGB8_texture GL_ARB_texture_compression GL_ARB_texture_non_power_of_two GL_ANDROID_user_clip_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
I/SurfaceFlinger( 133): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger( 133): GL_MAX_VIEWPORT_DIMS = 4096
I/SurfaceFlinger( 133): flags = 000c0000
D/SensorService( 133): nuSensorService starting...
E/SensorService( 133): couldn't load sensors module (No such file or directory)
I/sysproc ( 133): System server: starting Android runtime.
I/sysproc ( 133): System server: starting Android services.
I/sysproc ( 133): System server: entering thread pool.
I/SystemServer( 133): Entered the Android system server!
I/SystemServer( 133): Entropy Service
D/libEGL ( 145): egl.cfg not found, using default config
D/libEGL ( 145): loaded /system/lib/egl/libGLES_android.so
W/zipro ( 145): Unable to open zip '/data/local/bootanimation.zip': No such f ile or directory
I/SystemServer( 133): Power Manager
I/SystemServer( 133): Activity Manager
I/ActivityManager( 133): Memory class: 16
W/UsageStats( 133): Usage stats version changed; dropping
I/SystemServer( 133): Telephony Registry
I/SystemServer( 133): Package Manager
I/installd( 105): new connection
I/Installer( 133): connecting...
D/dalvikvm( 133): GC_CONCURRENT freed 168K, 48% free 2956K/5639K, external 0K/0K, paused 7ms+6ms
W/PackageManager( 133): Running ENG build: no pre-dexopt!
W/PackageParser( 133): Unknown element under <manifest>: meta-data at /system/app/Cyanbread.apk Binary XML file line #43
D/dalvikvm( 133): GC_CONCURRENT freed 249K, 48% free 3124K/5895K, external 0K/0K, paused 4ms+6ms
W/ResourceType( 133): getEntry failing because entryIndex 296 is beyond type entryCount 171
W/ResourceType( 133): Failure getting entry for 0x01030128 (t=2 e=296) in package 0 (error -2147483647)
D/dalvikvm( 133): GC_CONCURRENT freed 196K, 44% free 3415K/6087K, external 0K/0
W/PackageParser( 133): Unknown element under <manifest>: meta-data at /system/app/Androidian.apk Binary XML file line #43
W/PackageParser( 133): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #132
W/PackageParser( 133): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #154
D/dalvikvm( 133): GC_CONCURRENT freed 223K, 43% free 3619K/6343K, external 0K/0K, paused 4ms+9ms
D/PackageManager( 133): No files in app dir /vendor/app
I/PackageManager( 133): Time to scan packages: 3.15 seconds
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 133): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
ECEIVE in package com.koushikdutta.rommanagerom.google.android.c2dm.permission.R--More--
W/PackageManager( 133): Unknown permission com.android.vending.BILLING in package com.koushikdutta.rommanager
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 133): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings
W/PackageManager( 133): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 133): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.cyanogenmod.updatenotify
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 133): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 133): Unknown permission android.permission.READ_OWNER_DATA in package com.android.email
W/PackageManager( 133): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
D/dalvikvm( 133): GC_EXPLICIT freed 365K, 45% free 3615K/6471K, external 0K/0K, paused 66ms
I/SystemServer( 133): Account Manager
I/SystemServer( 133): Content Manager
I/SystemServer( 133): System Content Providers
I/ActivityThread( 133): Pub settings: com.android.providers.settings.SettingsProvider
I/SystemServer( 133): Battery Service
D/SettingsProvider( 133): cache for settings table 'secure' rows=31; fullycached=true
I/SystemServer( 133): Lights Service
I/SystemServer( 133): Vibrator Service
D/SettingsProvider( 133): cache for settings table 'system' rows=59; fullycached=true
I/SystemServer( 133): Alarm Manager
I/SystemServer( 133): Init Watchdog
I/SystemServer( 133): Window Manager
W/dalvikvm( 133): threadid=16: thread exiting with uncaught exception (group=0x401f9560)
E/ActivityManager( 133): Attempt to launch receivers of broadcast intent Intent { act=android.intent.action.TIME_SET flg=0x20000000 } before boot completion
E/AndroidRuntime( 133): *** FATAL EXCEPTION IN SYSTEM PROCESS: AlarmManager
E/AndroidRuntime( 133): java.lang.IllegalStateException: Cannot broadcast before boot completed
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.verifyBroadcastLocked(ActivityManagerService.java:10544)
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.broadcastIntent(ActivityManagerService.java:10561)
E/AndroidRuntime( 133): at android.app.ContextImpl.sendBroadcast(ContextImpl.java:686)
E/AndroidRuntime( 133): at com.android.server.AlarmManagerService$AlarmThread.run(AlarmManagerService.java:665)
I/InputManager( 133): Initializing input manager
I/Process ( 133): Sending signal. PID: 133 SIG: 9
E/AndroidRuntime( 133): Error reporting crash
E/AndroidRuntime( 133): java.lang.NullPointerException
E/AndroidRuntime( 133): at android.os.DropBoxManager.isTagEnabled(DropBoxManager.java:288)
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.addErrorToDropBox(ActivityManagerService.java:6837)
E/AndroidRuntime( 133): at com.android.server.am.ActivityManagerService.handleApplicationCrash(ActivityManagerService.java:6546)
E/AndroidRuntime( 133): at com.android.internal.os.RuntimeInit$UncaughtHandler.uncaughtException(RuntimeInit.java:76)
E/AndroidRuntime( 133): at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:854)
E/AndroidRuntime( 133): at java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:851)
I/ServiceManager( 96): service 'batteryinfo' died
I/ServiceManager( 96): service 'usagestats' died
I/ServiceManager( 96): service 'telephony.registry' died
I/ServiceManager( 96): service 'package' died
I/ServiceManager( 96): service 'permission' died
I/ServiceManager( 96): service 'activity' died
I/ServiceManager( 96): service 'meminfo' died
I/ServiceManager( 96): service 'cpuinfo' died
I/ServiceManager( 96): service 'entropy' died
I/ServiceManager( 96): service 'power' died
I/ServiceManager( 96): service 'SurfaceFlinger' died
I/ServiceManager( 96): service 'sensorservice' died
I/ServiceManager( 96): service 'account' died
I/ServiceManager( 96): service 'content' died
I/ServiceManager( 96): service 'battery' died
I/ServiceManager( 96): service 'hardware' died
I/ServiceManager( 96): service 'vibrator' died
I/ServiceManager( 96): service 'alarm' died
D/BootAnimation( 145): SurfaceFlinger died, exiting...
E/installd( 105): eof
E/installd( 105): failed to read size
I/installd( 105): closing connection
I/Zygote ( 101): Exit zygote because system server (133) has terminated
I/ServiceManager( 96): service 'media.audio_flinger' died
I/ServiceManager( 96): service 'media.audio_policy' died
I/ServiceManager( 96): service 'media.player' died
I/ServiceManager( 96): service 'media.camera' died
I/Netd ( 162): Netd 1.0 starting
D/AndroidRuntime( 163):
D/AndroidRuntime( 163): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
I/AndroidRuntime( 163): Heap size: -Xmx16m
D/AndroidRuntime( 163): CheckJNI is ON
I/ ( 161): ServiceManager: 0x12f8d50
W/AudioHardwareInterface( 161): Using stubbed audio hardware. No sound will be produced.
D/AudioHardwareInterface( 161): setMode(NORMAL)
I/CameraService( 161): CameraService started (pid=161)
D/AudioFlinger( 161): setParameters(): io 1, keyvalue routing=2, tid 168, calling tid 161
I/AudioFlinger( 161): AudioFlinger's thread 0x12fa640 ready to run
I/ethernet( 163): Loading ethernet jni class
I/SamplingProfilerIntegration( 163): Profiler is disabled.
I/Zygote ( 163): Preloading classes...
E/Zygote ( 163): setreuid() failed. errno: 30
D/dalvikvm( 163): GC_EXPLICIT freed 47K, 77% free 237K/1024K, external 0K/0K, paused 4ms
W/MediaProfiles( 163): could not find media config xml file
D/RenderScript_jni( 163): RenderScript JNI library not found!
D/dalvikvm( 163): GC_FOR_MALLOC freed 2915K, 57% free 2208K/5123K, external 0K/0K, paused 75ms
D/dalvikvm( 163): GC_FOR_MALLOC freed 2634K, 52% free 2485K/5123K, external 0K/0K, paused 68ms
I/Zygote ( 163): ...preloaded 1829 classes in 6736ms.
D/Zygote ( 163): setreuid() error ignored, same uid.
D/dalvikvm( 163): GC_EXPLICIT freed 849K, 48% free 2678K/5123K, external 0K/0K, paused 58ms
I/Zygote ( 163): Preload resources disabled, skipped.
D/dalvikvm( 163): GC_EXPLICIT freed 25K, 49% free 2653K/5123K, external 0K/0K, paused 47ms
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 49% free 2653K/5123K, external 0K/0K, paused 47ms
I/dalvikvm( 163): System server process 171 has been created
I/Zygote ( 163): Accepting command socket connections
E/BatteryService( 171): usbOnlinePath not found
E/BatteryService( 171): batteryVoltagePath not found
E/BatteryService( 171): batteryTemperaturePath not found
I/sysproc ( 171): Entered system_init()
I/sysproc ( 171): ServiceManager: 0x19b4650
I/SurfaceFlinger( 171): SurfaceFlinger is starting
I/SurfaceFlinger( 171): dithering enabled
I/SurfaceFlinger( 171): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
E/SurfaceFlinger( 171): Couldn't open /sys/power/wait_for_fb_sleep or /sys/power/wait_for_fb_wake
I/gralloc ( 171): using (fd=25)
I/gralloc ( 171): id = BCM2708 FB
I/gralloc ( 171): xres = 656 px
I/gralloc ( 171): yres = 512 px
I/gralloc ( 171): xres_virtual = 656 px
I/gralloc ( 171): yres_virtual = 1024 px
I/gralloc ( 171): bpp = 16
I/gralloc ( 171): r = 11:5
I/gralloc ( 171): g = 5:6
I/gralloc ( 171): b = 0:5
I/gralloc ( 171): width = 512 mm (32.543751 dpi)
I/gralloc ( 171): height = 656 mm (19.824390 dpi)
I/gralloc ( 171): refresh rate = 60.00 Hz
D/libEGL ( 171): egl.cfg not found, using default config
D/libEGL ( 171): loaded /system/lib/egl/libGLES_android.so
W/SurfaceFlinger( 171): ro.sf.lcd_density not defined, using 160 dpi by default.
I/SurfaceFlinger( 171): EGL informations:
I/SurfaceFlinger( 171): # of configs : 8
I/SurfaceFlinger( 171): vendor : Android
I/SurfaceFlinger( 171): version : 1.4 Android META-EGL
I/SurfaceFlinger( 171): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_ANDROID_image_native_buffer EGL_ANDROID_swap_rectangle EGL_ANDROID_get_render_buffer
I/SurfaceFlinger( 171): Client API: OpenGL ES
I/SurfaceFlinger( 171): EGLSurface: 5-6-5-0, config=0x0
I/SurfaceFlinger( 171): OpenGL informations:
I/SurfaceFlinger( 171): renderer : Android PixelFlinger 1.4
I/SurfaceFlinger( 171): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 171): extensions: GL_OES_byte_coordinates GL_OES_fixed_point
I/SurfaceFlinger( 171): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger( 171): GL_MAX_VIEWPORT_DIMS = 4096
I/SurfaceFlinger( 171): flags = 000c0000
D/SensorService( 171): nuSensorService starting...
E/SensorService( 171): couldn't load sensors module (No such file or directory)
I/sysproc ( 171): System server: starting Android runtime.
I/sysproc ( 171): System server: starting Android services.
I/SystemServer( 171): Entered the Android system server!
I/sysproc ( 171): System server: entering thread pool.
I/SystemServer( 171): Entropy Service
D/libEGL ( 183): egl.cfg not found, using default config
D/libEGL ( 183): loaded /system/lib/egl/libGLES_android.so
W/zipro ( 183): Unable to open zip '/data/local/bootanimation.zip': No such file or directory
W/zipro ( 183): Unable to open zip '/system/media/bootanimation.zip': No such file or directory
I/SystemServer( 171): Power Manager
I/SystemServer( 171): Activity Manager
I/ActivityManager( 171): Memory class: 16
W/UsageStats( 171): Usage stats version changed; dropping
I/SystemServer( 171): Telephony Registry
I/SystemServer( 171): Package Manager
I/Installer( 171): connecting...
D/dalvikvm( 171): GC_CONCURRENT freed 168K, 48% free 2969K/5639K, external 0K/0K, paused 4ms+6ms
W/PackageManager( 171): Running ENG build: no pre-dexopt!
W/PackageParser( 171): Unknown element under <manifest>: meta-data at /system/app/Cyanbread.apk Binary XML file line #43
D/dalvikvm( 171): GC_CONCURRENT freed 254K, 47% free 3174K/5959K, external 0K/0K, paused 4ms+9ms
W/ResourceType( 171): getEntry failing because entryIndex 296 is beyond type entryCount 171
W/ResourceType( 171): Failure getting entry for 0x01030128 (t=2 e=296) in package 0 (error -2147483647)
W/PackageParser( 171): Unknown element under <manifest>: meta-data at /system/app/Androidian.apk Binary XML file line #43
D/dalvikvm( 171): GC_CONCURRENT freed 214K, 45% free 3468K/6215K, external 0K/0K, paused 4ms+8ms
W/PackageParser( 171): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #132
W/PackageParser( 171): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #154
D/PackageManager( 171): No files in app dir /vendor/app
I/PackageManager( 171): Time to scan packages: 1.898 seconds
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
D/dalvikvm( 171): GC_CONCURRENT freed 282K, 43% free 3701K/6471K, external 0K/0K, paused 5ms+9ms
W/PackageManager( 171): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 171): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.koushikdutta.rommanager
W/PackageManager( 171): Unknown permission com.android.vending.BILLING in package com.koushikdutta.rommanager
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 171): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings
W/PackageManager( 171): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 171): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.cyanogenmod.updatenotify
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 171): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 171): Unknown permission android.permission.READ_OWNER_DATA in package com.android.email
W/PackageManager( 171): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
D/dalvikvm( 171): GC_EXPLICIT freed 306K, 46% free 3592K/6599K, external 0K/0K,
I/SystemServer( 171): Account Manager
I/SystemServer( 171): Content Manager
I/ActivityThread( 171): Pub settings: com.android.providers.settings.SettingsProvider
I/SystemServer( 171): System Content Providers
I/SystemServer( 171): Battery Service
D/SettingsProvider( 171): cache for settings table 'secure' rows=31; fullycached=true
I/SystemServer( 171): Lights Service
I/SystemServer( 171): Vibrator Service
D/SettingsProvider( 171): cache for settings table 'system' rows=59; fullycached=true
I/SystemServer( 171): Alarm Manager
I/SystemServer( 171): Init Watchdog
I/SystemServer( 171): Window Manager
I/InputManager( 171): Initializing input manager
I/WindowManager( 171): names for haptic settings for haptic long array: haptic_long_array default: haptic_long_array_default
I/WindowManager( 171): pulled string: 0,1,20,21 default: 0,1,20,21
I/WindowManager( 171): haptic done for long array!
I/WindowManager( 171): names for haptic settings for haptic down array: haptic_down_array default: haptic_down_array_defaultI/WindowManager( 171): pulled string: 0,10,20,30 default: 0,10,20,30
I/WindowManager( 171): haptic done for down array!
I/WindowManager( 171): names for haptic settings for haptic tap array: haptic_tap_array default: haptic_tap_array_default
I/WindowManager( 171): pulled string: 40 default: 40
I/WindowManager( 171): haptic done for tap array!
I/WindowManager( 171): names for haptic settings for haptic up array: haptic_up_array default: haptic_up_array_default
I/WindowManager( 171): pulled string: 5,18 default: 5,18
I/WindowManager( 171): haptic done for up array!
I/InputManager( 171): Starting input manager
I/SystemServer( 171): Bluetooth Service
I/EventHub( 171): New device: path=/dev/input/event2 name=USB Optical Mouse id=0x10000 (of 0x1) index=1 fd=91 classes=0x100
E/EventHub( 171): could not get driver version for /dev/input/mouse0, Not a typewriter
I/EventHub( 171): New keyboard: device->id=0x10001 devname='CHICONY USB Keyboard' propName='hw.keyboards.65537.devname' keylayout='/system/usr/keylayout/qwerty.kl'
I/EventHub( 171): New device: path=/dev/input/event1 name=CHICONY USB Keyboard id=0x10001 (of 0x2) index=2 fd=93 classes=0x15
I/EventHub( 171): New keyboard: device->id=0x10002 devname='CHICONY USB Keyboard' propName='hw.keyboards.65538.devname' keylayout='/system/usr/keylayout/qwerty
I/EventHub( 171): New device: path=/dev/input/event0 name=CHICONY USB Keyboard id=0x10002 (of 0x3) index=3 fd=94 classes=0x3
E/EventHub( 171): could not get driver version for /dev/input/mice, Not a typewriter
I/InputReader( 171): Device added: id=0x10002, name=CHICONY USB Keyboard, sources=00000101
I/InputReader( 171): Device added: id=0x0, name=CHICONY USB Keyboard, sources=00001103
I/InputManager-Callbacks( 171): No input device calibration properties found for device CHICONY USB Keyboard.
I/InputReader( 171): Device added: id=0x10000, name=USB Optical Mouse, sources=00002002
I/BluetoothProfileState( 171): Message:Entering Stable State
I/InputManager-Callbacks( 171): No input device calibration properties found for device USB Optical Mouse.
V/SystemServer( 171): Bluetooth Network Service
I/SystemServer( 171): Device Policy
I/SystemServer( 171): Status Bar
I/SystemServer( 171): Clipboard Service
I/SystemServer( 171): Input Method Service
I/InputManagerService( 171): Enabled input methods: com.android.inputmethod.latin/.LatinIME
I/SystemServer( 171): NetStat Service
I/SystemServer( 171): NetworkManagement Service
I/SystemServer( 171): Connectivity Service
I/ConnectivityService( 171): hostname has been set: android-519750752580062e
V/ConnectivityService( 171): Starting Ethernet Service.
I/ethernet( 171): interface eth0:2 found
E/ethernet( 171): android_net_ethernet_initEthernetNative exited with success
V/EthernetStateTracker( 171): Starts...
V/EthernetStateTracker( 171): Successed
I/ethernet( 171): User ask for device name on 0, list:1A23CB0, total:1
I/EthernetService( 171): Ethernet dev enabled 2
V/EthernetService( 171): device 0 name eth0
V/EthernetStateTracker( 171): start to monitor the ethernet devices
I/EthernetManager( 171): Init Ethernet Manager, service: com.android.server.EthernetService@407b21d8
I/EthernetStateTracker( 171): reset device eth0
D/dalvikvm( 171): GC_CONCURRENT freed 163K, 42% free 3843K/6599K, external 0K/0K, paused 4ms+13ms
W/EthernetStateTracker( 171): Could not stop DHCP
I/EthernetStateTracker( 171): trigger dhcp for device eth0
D/EthernetStateTracker( 171): DhcpHandler: DHCP request started
I/WifiService( 171): WifiService starting up with Wi-Fi disabled
D/NetworkManagmentService( 171): Registering observer
I/SystemServer( 171): Throttle Service
I/SystemServer( 171): Accessibility Manager
I/SystemServer( 171): Mount Service
I/SystemServer( 171): Profile Manager
I/PackageManager( 171): Updating external media status from unmounted to unmounted
D/VoldCmdListener( 97): volume list
D/VoldCmdListener( 97): share status ums
D/ProfileService( 171): Found active: 3bc7c46c-083b-4a05-b019-15072abfe187
D/ProfileService( 171): Set active profile to: 3bc7c46c-083b-4a05-b019-15072abfe187 - Default
D/ProfileService( 171): Saving profile data...
D/ProfileService( 171): Save completed.
I/SystemServer( 171): Notification Manager
I/SystemServer( 171): Device Storage Monitor
I/SystemServer( 171): Location Manager
I/SystemServer( 171): Search Service
I/SystemServer( 171): DropBox Service
I/SystemServer( 171): Wallpaper Service
I/SystemServer( 171): Audio Service
W/AudioPolicyManagerBase( 161): setPhoneState() setting same state 0
D/dalvikvm( 171): GC_CONCURRENT freed 307K, 41% free 4067K/6855K, external 0K/0K, paused 6ms+17ms
I/SystemServer( 171): Headset Observer
W/HeadsetObserver( 171): This kernel does not have wired headset support
I/SystemServer( 171): HDMI Observer
W/HDMIObserver( 171): This kernel does not have hdmi support
W/UsbDeviceSettingsManager( 171): settings file not found
I/SystemServer( 171): Dock Observer
W/DockObserver( 171): This kernel does not have dock station support
I/SystemServer( 171): USB Service
I/UsbService( 171): This kernel does not have USB configuration switch support
I/UsbService( 171): Trying legacy USB configuration switch support
I/UsbService( 171): This kernel does not have legacy USB configuration switch support
I/SystemServer( 171): UI Mode Manager Service
I/SystemServer( 171): Backup Service
V/BackupManagerService( 171): No ancestral data
I/BackupManagerService( 171): Found stale backup journal, scheduling
I/BackupManagerService( 171): android
I/BackupManagerService( 171): com.android.browser
I/BackupManagerService( 171): com.android.inputmethod.latin
I/BackupManagerService( 171): com.android.providers.settings
I/BackupManagerService( 171): com.android.providers.userdictionary
I/BackupManagerService( 171): Backup enabled => false
I/SystemServer( 171): AppWidget Service
I/WindowManager( 171): SAFE MODE not enabled
D/dalvikvm( 171): JIT started for system_server
I/SystemServer( 171): Recognition Service
I/SystemServer( 171): DiskStats Service
I/SystemServer( 171): AssetRedirectionManager Service
I/power ( 171): *** set_screen_state 1
E/power ( 171): Failed setting last user activity: g_error=0
D/PowerManagerService( 171): system ready!
I/ActivityManager( 171): System now ready
I/SystemServer( 171): Making services ready
I/StatusBarManagerService( 171): Starting service: ComponentInfo{com.android.systemui/com.android.systemui.statusbar.StatusBarService}
I/Zygote ( 171): Process: zygote socket opened
I/ActivityManager( 171): Start proc com.android.systemui for service com.android.systemui/.statusbar.StatusBarService: pid=229 uid=1000 gids={1015, 3002, 3001, 3003}
I/ActivityManager( 171): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=0 keys=0/0/0 nav=0/0 orien=0 layout=0 uiMode=17 seq=2 themeResource=null}
I/InputReader( 171): Device reconfigured: id=0x0, name=CHICONY USB Keyboard, di
I/InputManager-Callbacks( 171): No virtual keys found for device CHICONY USB Keyboard.
I/ActivityManager( 171): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=2/1/2 nav=1/1 orien=2 layout=268435475 uiMode=17 seq=3 themeResource=null}
W/RecognitionManagerService( 171): no available voice recognition services found
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 339K, 42% free 4042K/6919K, external 0K/0K, paused 126ms
W/AssetRedirectionManager( 171): No such resource found for com.tmobile.theme.Cyanbread:@drawable/frameworks_res_btn_toggle_off
W/AssetRedirectionManager( 171): No such resource found for android:drawable/star_small_on
W/AssetRedirectionManager( 171): No such resource found for android:drawable/star_small_half
D/dalvikvm( 229): GC_CONCURRENT freed 394K, 51% free 2774K/5639K, external 0K/0K, paused 15ms+31ms
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 149K, 41% free 4126K/6919K, external 364K/512K, paused 105ms
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 148K, 40% free 4179K/6919K, external 966K/1056K, paused 83ms
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/progress_horizontal
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/btn_playback_top_selected
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/ic_mp_album_playback
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/ic_mp_artist_playback
W/AssetRedirectionManager( 171): No such resource found for com.android.music:drawable/ic_mp_song_playback
I/ActivityManager( 171): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/.Launcher } from pid 0
W/AssetRedirectionManager( 171): No such resource found for com.tmobile.theme.Cyanbread:@drawable/shortcut_selector
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/home_button_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/home_button_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/all_apps_button_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/all_apps_button_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_phone_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_phone_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_phone_normal
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_browser_focused
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_browser_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:drawable/hotseat_browser_normal
D/dalvikvm( 171): GC_CONCURRENT freed 350K, 41% free 4244K/7111K, external 1516K/1658K, paused 12ms+9ms
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:color/apps3d_glow_pressed
W/AssetRedirectionManager( 171): No such resource found for com.android.launcher:color/apps3d_glow_focused
I/ActivityManager( 171): Start proc com.android.launcher for activity com.android.launcher/.Launcher: pid=238 uid=10010 gids={1015}
D/dalvikvm( 171): GREF has increased to 201
D/LockPatternKeyguardView( 171): onScreenTurnedOn()
I have done this quote with "logcat|more" because the system didn't accept "logcat >pippo".
I/ActivityManager( 171): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=242 uid=10028 gids={}
I/LocationManagerService( 171): Setting GPS Source to: 0
E/ThrottleService( 171): Could not open GPS configuration file /etc/gps.conf
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_3_fully
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_2_fully
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_1_fully
W/AssetRedirectionManager( 171): No such resource found for com.android.systemui:drawable/stat_sys_data_wimax_signal_0_fully
I/ActivityManager( 171): Start proc com.android.phone for added application com.android.phone: pid=249 uid=1001 gids={3002, 3001, 3003, 1015}
I/SystemServer( 171): Enabled StrictMode for system server main thread.
W/GpsLocationProvider( 171): Could not open GPS configuration file /etc/gps.conf
I//system/bin/tc( 162): Cannot find device "rmnet0"
I/logwrapper( 162): /system/bin/tc terminated by exit(1)
W/ActivityManager( 171): Unable to start service Intent { act=@0 }: not found
W/GpsLocationProvider( 171): Failed to enable location provider
I//system/bin/tc( 162): Cannot find device "ifb0"
I/PowerWidget( 229): Clearing any old widget stuffs
I/PowerWidget( 229): Setting up widget
I/PowerWidget( 229): Default buttons being loaded
I/PowerWidget( 229): Button list: toggleWifi|toggleBluetooth|toggleGPS|toggleSound
D/dalvikvm( 229): GC_EXTERNAL_ALLOC freed 52K, 51% free 2787K/5639K, external 0K/0K, paused 366ms
D/dalvikvm( 242): GC_CONCURRENT freed 404K, 51% free 2767K/5639K, external 0K/0K, paused 4ms+44ms
D/dalvikvm( 238): GC_CONCURRENT freed 404K, 51% free 2767K/5639K, external 0K/0K, paused 16ms+45ms
D/dalvikvm( 249): GC_CONCURRENT freed 405K, 51% free 2767K/5639K, external 0K/0K, paused 4ms+55ms
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 237K, 40% free 4316K/7111K, external 1643K/1658K, paused 341ms
I/ActivityManager( 171): Start proc com.android.settings for broadcast com.android.settings/.widget.SettingsAppWidgetProvider: pid=283 uid=1000 gids={1015, 3002, 3001, 3003}
I/ActivityThread( 238): Pub com.android.launcher.settings: com.android.launcher.LauncherProvider
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 230K, 40% free 4334K/7175K, external 2092K/2175K, paused 176ms
D/szipinf ( 242): Initializing inflate state
I/ActivityThread( 249): Pub mms: com.android.providers.telephony.MmsProvider
I/ActivityThread( 249): Pub sms: com.android.providers.telephony.SmsProvider
I/ActivityThread( 249): Pub telephony: com.android.providers.telephony.TelephonyProvider
D/dalvikvm( 242): GC_EXTERNAL_ALLOC freed 40K, 51% free 2816K/5639K, external 0K/0K, paused 409ms
I/ActivityThread( 249): Pub icc: com.android.phone.IccProvider
I/ActivityThread( 249): Pub mms-sms: com.android.providers.telephony.MmsSmsProvider
D/dalvikvm( 283): GC_CONCURRENT freed 407K, 51% free 2765K/5639K, external 0K/0K, paused 5ms+44ms
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 43K, 50% free 2828K/5639K, external 0K/0K, paused 389ms
D/dalvikvm( 242): GC_FOR_MALLOC freed <1K, 51% free 2816K/5639K, external 821K/1333K, paused 295ms
I/dalvikvm-heap( 242): Grow heap (frag case) to 6.774MB for 841021-byte allocation
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 145K, 40% free 4306K/7175K, external 2563K/2837K, paused 241ms
D/dalvikvm( 242): GC_CONCURRENT freed <1K, 44% free 3637K/6471K, external 821K/1333K, paused 4ms+45ms
D/szipinf ( 242): Initializing zlib to inflate
D/dalvikvm( 171): GC_EXTERNAL_ALLOC freed 26K, 41% free 4286K/7175K, external 2506K/3130K, paused 264ms
I/ActivityManager( 171): Start proc android.process.acore for content provider com.android.providers.userdictionary/.UserDictionaryProvider: pid=296 uid=10025 gids={3003, 1015}
I/StatusBarManagerService( 171): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@40785ed8
D/CallManager( 249): registerPhone(GSM Handler{406dbc48})
D/StorageNotification( 229): Startup with UMS connection false (media state unmounted)
I/StorageNotification( 229): UMS connection changed to false (media state unmounted)
V/AudioManager( 229): shouldVibrate, group: a126d48a-aaef-47c4-baed-7f0e44aeffe5 mode: DEFAULT
W/ActivityManager( 171): Unable to start service Intent { act=com.android.ussd.IExtendedNetworkService }: not found
D/dalvikvm( 171): GREF has increased to 301
I/ActivityThread( 296): Pub com.android.social: com.android.providers.contacts.SocialProvider
I/TelephonyRegistry( 171): notifyServiceState: 1 home null null null Unknown CSS not supported -1 -1RoamInd: -1DefRoamInd: -1EmergOnly: false
I/TelephonyRegistry( 171): notifyDataConnection: state=0 isDataConnectivityPossible=false reason=radioTurnedOff interfaceName=null networkType=0
I/TelephonyRegistry( 171): notifyDataConnection: state=0 isDataConnectivityPossible=false reason=gprsDetached interfaceName=null networkType=0
E/EthernetStateTracker( 171): DhcpHandler: DHCP request failed: Timed out waiting for dhcpcd to start
I/ActivityThread( 296): Pub applications: com.android.providers.applications.ApplicationsProvider
D/BT HSHFP( 249): Starting BluetoothHeadsetService
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 75K, 49% free 2919K/5639K, external 504K/512K, paused 650ms
V/SipBroadcastReceiver( 249): start auto registration
D/dalvikvm( 249): GC_CONCURRENT freed 167K, 47% free 3044K/5703K, external 0K/0K, paused 4ms+34ms
D/dalvikvm( 296): GC_CONCURRENT freed 418K, 52% free 2753K/5639K, external 0K/0K, paused 28ms+33ms
I/ActivityThread( 296): Pub contacts;com.android.contacts: com.android.providers.contacts.ContactsProvider2
D/ViewConsistency( 238): AbsListView com.android.launcher.AllAppsGridView@406a6f20 enabled= true
I/Database( 296): sqlite returned: error code = 0, msg = Recovered 107 frames from WAL file /data/data/com.android.providers.contacts/databases/contacts2.db-wal
D/HomeLoaders( 238): load applications
D/HomeLoaders( 238): loading user items in Thread[main,5,main]
D/HomeLoaders( 238): --> starting workspace loader
D/HomeLoaders( 238): ----> running workspace loader (1)
I/Database( 238): sqlite returned: error code = 0, msg = Recovered 8 frames from WAL file /data/data/com.android.launcher/databases/launcher.db-wal
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 47K, 48% free 2957K/5639K, external 893K/1028K, paused 206ms
I/ActivityThread( 296): Pub call_log: com.android.providers.contacts.CallLogProvider
I/ActivityThread( 296): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
D/dalvikvm( 238): GC_EXTERNAL_ALLOC freed 10K, 48% free 2966K/5639K, external 1950K/2453K, paused 228ms
W/AssetRedirectionManager( 171): No such resource found for com.android.camera:
D/dalvikvm( 171): GC_CONCURRENT freed 585K, 42% free 4421K/7495K, external 2618K/3818K, paused 6ms+30ms
I/Database( 296): sqlite returned: error code = 0, msg = Recovered 4 frames from WAL file /data/data/com.android.providers.userdictionary/databases/user_dict.db-wal
D/HomeLoaders( 238): ----> workspace loader 1 finished loading data
D/HomeLoaders( 238): ----> worskpace items=9
D/HomeLoaders( 238): ----> worskpace widgets=3
D/HomeLoaders( 238): --> done loading workspace; not stopped
D/HomeLoaders( 238): ----> items cloned, ready to refresh UI
D/HomeLoaders( 238): ----> loading applications from workspace loader
D/HomeLoaders( 238): --> starting applications loader unlocked
D/HomeLoaders( 238): ----> running applications loader (1)
D/HomeLoaders( 238): ----> onDesktopItemsLoaded()
D/Launcher( 238): ------> binding 9 items
D/Launcher( 238): ------> binding 3 widgets
D/Launcher( 238): ------> start binding items
D/HomeLoaders( 238): ----> cleared application list
W/ActivityManager( 171): Activity idle timeout for HistoryRecord{40863368 com.android.launcher/.Launcher}
D/OtaStartupReceiver( 249): Not a CDMA phone, no need to process OTA
I/ActivityManager( 171): Start proc com.bel.android.dspmanager for broadcast com.bel.android.dspmanager/.ServiceLaunchReceiver: pid=326 uid=10005 gids={3002}
D/PowerManagerService( 171): bootCompleted
I/SurfaceFlinger( 171): Boot is finished (23693 ms)
D/VoldCmdListener( 97): volume mount /mnt/sdcard
I/Vold ( 97): /dev/block/vold/179:1 being considered for volume sdcard
D/Vold ( 97): Volume sdcard state changing 1 (Idle-Unmounted) -> 3 (Checking)
W/logwrapper( 331): Unable to background process (No such file or directory)
I/StorageNotification( 229): Media {/mnt/sdcard} state changed from {unmounted} -> {checking}
I/SearchManagerService( 171): Building list of searchable activities
D/dalvikvm( 238): GC_CONCURRENT freed 121K, 47% free 3077K/5703K, external 2296K/3289K, paused 10ms+25ms
D/dalvikvm( 296): GC_CONCURRENT freed 225K, 49% free 2941K/5703K, external 0K/0K, paused 5ms+15ms
I//system/bin/fsck_msdos( 97): ** /dev/block/vold/179:1
I//system/bin/fsck_msdos( 97): ** Phase 1 - Read and Compare FATs
I//system/bin/fsck_msdos( 97): Attempting to allocate 591 KB for FAT
D/dalvikvm( 229): GC_EXTERNAL_ALLOC freed 212K, 49% free 2948K/5703K, external 506K/512K, paused 330ms
I//system/bin/fsck_msdos( 97): ** Phase 2 - Check Cluster Chains
I//system/bin/fsck_msdos( 97): ** Phase 3 - Checking Directories
I//system/bin/fsck_msdos( 97): ** Phase 4 - Checking for Lost Files
I//system/bin/fsck_msdos( 97): 26 files, 63106 free (126212 clusters)
I/Vold ( 97): Filesystem check completed OK
I/Vold ( 97): Filesystem type is: VFAT
I/PackageManager( 171): Updating external media status from unmounted to mounted
I/Vold ( 97): Device /dev/block/vold/179:1, target /mnt/sdcard mounted @ /mnt/secure/staging
D/Vold ( 97): Volume sdcard state changing 3 (Checking) -> 4 (Mounted)
D/VoldCmdListener( 97): asec list
I/PackageManager( 171): No secure containers on sdcard
I/StorageNotification( 229): Media {/mnt/sdcard} state changed from {checking} -> {mounted}
I/RecoverySystem( 171): No recovery log file
I/HeadsetService( 326): Starting service.
I/ActivityManager( 171): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=338 uid=10002 gids={3003}
I/ActivityManager( 171): Start proc android.process.media for content provider com.android.providers.downloads/.DownloadProvider: pid=341 uid=10006 gids={1015, 2001, 3003}
I/Effect-Equalizer( 161): EQ_PARAM_NUM_BANDS OK
D/dalvikvm( 163): GC_EXPLICIT freed 11K, 51% free 2665K/5379K, external 0K/0K, paused 264ms
I/HeadsetService( 326): Phone status idle: enable DSP.
I/Effect-BassBoost( 161): New strength: 0
I/Effect-Equalizer( 161): Setting band 2 to 0
I/Effect-Equalizer( 161): Setting band 2 to 1
I/Effect-Equalizer( 161): Setting band 2 to 2
I/Effect-Equalizer( 161): Setting band 2 to 3
I/Effect-Equalizer( 161): Setting band 2 to 4
I/Effect-Equalizer( 161): Setting loudness correction reference to 100.000000 dB
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 289ms
D/dalvikvm( 326): GC_CONCURRENT freed 345K, 52% free 2699K/5575K, external 0K/0K, paused 4ms+20ms
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 246ms
I/ActivityThread( 341): Pub media: com.android.providers.media.MediaProvider
I/ActivityThread( 338): Pub com.android.calendar: com.android.providers.calendar.CalendarProvider2
D/dalvikvm( 338): GC_CONCURRENT freed 390K, 52% free 2746K/5639K, external 0K/0K, paused 6ms+27ms
I/Database( 338): sqlite returned: error code = 0, msg = Recovered 34 frames from WAL file /data/data/com.android.providers.calendar/databases/calendar.db-wal
D/dalvikvm( 341): GC_CONCURRENT freed 421K, 52% free 2751K/5639K, external 0K/0K, paused 4ms+24ms
V/MediaProvider( 341): Attached volume: internal
V/MediaProvider( 341): /mnt/sdcard volume ID: -245575889
I/ActivityManager( 171): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=357 uid=10007 gids={}
V/MediaProvider( 341): Attached volume: external
I/ActivityThread( 341): Pub downloads: com.android.providers.downloads.DownloadProvider
D/Calendar( 338): missed alarms found: 0
I/ActivityThread( 341): Pub drm: com.android.providers.drm.DrmProvider
I/Database( 341): sqlite returned: error code = 0, msg = Recovered 8 frames from WAL file /data/data/com.android.providers.downloads/databases/downloads.db-wal
I/ActivityThread( 357): Pub com.android.deskclock: com.android.deskclock.AlarmProvider
I/Database( 357): sqlite returned: error code = 0, msg = Recovered 4 frames from WAL file /data/data/com.android.deskclock/databases/alarms.db-wal
D/dalvikvm( 357): GC_CONCURRENT freed 406K, 52% free 2753K/5639K, external 0K/0K, paused 7ms+5ms
I/ActivityManager( 171): Start proc com.koushikdutta.rommanager for broadcast com.koushikdutta.rommanager/.UpdateReceiver: pid=367 uid=10018 gids={1015, 3003}
I/PurchasingManager( 367): Purchasing Framework initialization complete. Build ID 1.0.3
D/PurchasingManager( 367): In App Purchasing SDK - Sandbox Mode: PurchasingObserver registered: com.clockworkmod.billing.b@406fe2b8
D/SandboxRequestHandler( 367): In App Purchasing SDK - Sandbox Mode: sendGetUserIdRequest
W/ActivityManager( 171): Unable to start service Intent { act=com.amazon.testclient.iap.appUserId flg=0x10000000 (has extras) }: not found
I/ActivityManager( 171): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=377 uid=10020 gids={3003, 1015}
D/dalvikvm( 367): GC_CONCURRENT freed 384K, 51% free 2785K/5639K, external 0K/0K, paused 4ms+7ms
W/System.err( 367): java.io.FileNotFoundException: /sdcard/clockworkmod/.settings (No such file or directory)
W/System.err( 367): at org.apache.harmony.luni.platform.OSFileSystem.open(Native Method)
W/System.err( 367): at dalvik.system.BlockGuard$WrappedFileSystem.open(BlockGuard.java:232)
W/System.err( 367): at java.io.FileOutputStream.<init>(FileOutputStream.java:94)
W/System.err( 367): at java.io.FileOutputStream.<init>(FileOutputStream.java:165)
W/System.err( 367): at java.io.FileOutputStream.<init>(FileOutputStream.java:144)
W/System.err( 367): at com.koushikdutta.rommanager.as.a(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.DownloadService.onCreate(Unknown Source)
W/System.err( 367): at android.app.ActivityThread.handleCreateService(ActivityThread.java:2066)
W/System.err( 367): at android.app.ActivityThread.access$2500(ActivityThread.java:123)
W/System.err( 367): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:993)
W/System.err( 367): at android.os.Handler.dispatchMessage(Handler.java:99)
W/System.err( 367): at android.os.Looper.loop(Looper.java:130)
W/System.err( 367): at android.app.ActivityThread.main(ActivityThread.java:3835)
W/System.err( 367): at java.lang.reflect.Method.invokeNative(Native Method)
W/System.err( 367): at java.lang.reflect.Method.invoke(Method.java:507)
W/System.err( 367): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:864)
W/System.err( 367): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:622)
W/System.err( 367): at dalvik.system.NativeStart.main(Native Method)
W/System.err( 367): java.lang.Exception: no proof string
W/System.err( 367): at com.clockworkmod.billing.aa.a(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.as.c(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.DownloadService.b(Unknown Source)
W/System.err( 367): at com.koushikdutta.rommanager.DownloadService.onStart(Unknown Source)
W/System.err( 367): at android.app.Service.onStartCommand(Service.java:428)
W/System.err( 367): at android.app.ActivityThread.handleServiceArgs(ActivityThread.java:2160)
W/System.err( 367): at android.app.ActivityThread.access$2800(ActivityThread.java:123)
W/System.err( 367): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1002)
I/ClockworkModBilling( 367): Refreshing Market purchases...
I/ClockworkBilling( 367): com.clockworkmod.billing.BillingReceiver.REFRESH_MARKET
W/ActivityManager( 171): Unable to start service Intent { act=com.android.vending.billing.MarketBillingService.BIND }: not found
leaked IntentReceiver com.clockworkmod.billing.bh@406e8778 that was originally registered here. Are you missing a call to unregisterReceiver()?
E/ActivityThread( 367): android.app.IntentReceiverLeaked: Service com.koushikdutta.rommanager.DownloadService has leaked IntentReceiver com.clockworkmod.billing.bh@406e8778 that was originally registered here. Are you missing a call to unregisterReceiver()?
E/ActivityThread( 367): at android.app.LoadedApk$ReceiverDispatcher.<init>(LoadedApk.java:756)
E/ActivityThread( 367): at android.app.LoadedApk.getReceiverDispatcher(LoadedApk.java:551)
E/ActivityThread( 367): at android.app.ContextImpl.registerReceiverInternal(ContextImpl.java:826)
E/ActivityThread( 367): at android.app.ContextImpl.registerReceiver(ContextImpl.java:813)
E/ActivityThread( 367): at android.app.ContextImpl.registerReceiver(ContextImpl.java:807)
E/ActivityThread( 367): at android.content.ContextWrapper.registerReceiver(ContextWrapper.java:318)
E/ActivityThread( 367): at com.clockworkmod.billing.aa.a(Unknown Source)
E/ActivityThread( 367): at com.koushikdutta.rommanager.as.c(Unknown Source)
E/ActivityThread( 367): at com.koushikdutta.rommanager.as.a(Unknown Source)
E/ActivityThread( 367): Service com.koushikdutta.rommanager.DownloadService has
E/ActivityThread( 367): at com.koushikdutta.rommanager.DownloadService.b(Unknown Source)
E/ActivityThread( 367): at com.koushikdutta.rommanager.DownloadService.onStart(Unknown Source)
E/ActivityThread( 367): at android.app.Service.onStartCommand(Service.java:428)
E/ActivityThread( 367): at android.app.ActivityThread.handleServiceArgs(ActivityThread.java:2160)
E/ActivityThread( 367): at android.app.ActivityThread.access$2800(ActivityThread.java:123)
E/ActivityThread( 367): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1002)
E/ActivityThread( 367): at android.os.Handler.dispatchMessage(Handler.java:99)
E/ActivityThread( 367): at android.os.Looper.loop(Looper.java:130)
E/ActivityThread( 367): at android.app.ActivityThread.main(ActivityThread.java:3835)
E/ActivityThread( 367): at java.lang.reflect.Method.invokeNative(Native Method)
E/ActivityThread( 367): at java.lang.reflect.Method.invoke(Method.java:507)
E/ActivityThread( 367): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:864)
E/ActivityThread( 367): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:622)
E/ActivityThread( 367): at dalvik.system.NativeStart.main(Native Method)
I/ActivityThread( 377): Pub com.android.mms.SuggestionsProvider: com.android.mms.SuggestionsProvider
D/dalvikvm( 377): GC_CONCURRENT freed 396K, 51% free 2777K/5639K, external 0K/0K, paused 11ms+32ms
I/Database( 249): sqlite returned: error code = 0, msg = Recovered 37 frames from WAL file /data/data/com.android.providers.telephony/databases/mmssms.db-wal
D/dalvikvm( 171): GREF has increased to 401
I/ActivityManager( 171): Start proc com.cyanogenmod.stats for broadcast com.cyanogenmod.stats/.ReportingServiceManager: pid=401 uid=10024 gids={3003}
D/dalvikvm( 249): GREF has increased to 201
D/CMStats ( 401): BOOT_COMPLETED: Setting checkedin=false
I/ActivityManager( 171): Start proc com.android.bluetooth for broadcast com.android.bluetooth/.opp.BluetoothOppReceiver: pid=410 uid=10032 gids={3003, 3002, 3001, 1015}
I/ActivityThread( 410): Pub com.android.bluetooth.opp: com.android.bluetooth.opp.BluetoothOppProvider
D/dalvikvm( 410): GC_CONCURRENT freed 399K, 52% free 2721K/5639K, external 0K/0K, paused 4ms+4ms
I/Database( 410): sqlite returned: error code = 0, msg = Recovered 5 frames from WAL file /data/data/com.android.bluetooth/databases/btopp.db-wal
D/MediaScannerService( 341): start scanning volume internal
I/ActivityManager( 171): Start proc com.android.voicedialer for broadcast com.android.voicedialer/.VoiceDialerReceiver: pid=422 uid=10036 gids={3002}
D/dalvikvm( 171): GC_CONCURRENT freed 898K, 43% free 4544K/7943K, external 2618K/3818K, paused 6ms+43ms
D/VoiceDialerReceiver( 422): onReceive Intent { act=android.intent.action.BOOT_COMPLETED cmp=com.android.voicedialer/.VoiceDialerReceiver }
V/RecognizerEngine( 422): deleteCachedGrammarFiles /data/data/com.android.voicedialer/files/openentries.txt
I/ActivityManager( 171): Start proc com.android.email for broadcast com.android.email/.service.EmailBroadcastReceiver: pid=431 uid=10038 gids={3003, 1015}
I/Database( 341): sqlite returned: error code = 0, msg = Recovered 94 frames from WAL file /data/data/com.android.providers.media/databases/internal.db-wal
I/dalvikvm( 171): Jit: resizing JitTable from 512 to 1024
D/dalvikvm( 431): GC_CONCURRENT freed 406K, 52% free 2756K/5639K, external 0K/0K, paused 15ms+18ms
I/ActivityThread( 431): Pub com.android.email.provider: com.android.email.provider.EmailProvider
I/ActivityThread( 431): Pub com.android.email.attachmentprovider: com.android.email.provider.AttachmentProvider
I/ActivityThread( 431): Pub com.android.exchange.provider: com.android.exchange.provider.ExchangeProvider
I/Database( 431): sqlite returned: error code = 0, msg = Recovered 28 frames fr
D/EAS SyncManager( 431): !!! EAS SyncManager, onCreate
I/ActivityManager( 171): Start proc com.android.music for broadcast com.android.music/.MediaAppWidgetProvider4x2: pid=442 uid=10026 gids={3003, 1015}
D/EAS SyncManager( 431): !!! EAS SyncManager, onStartCommand
D/Email ( 431): BOOT_COMPLETED
I/Database( 431): sqlite returned: error code = 0, msg = Recovered 6 frames from WAL file /data/data/com.android.email/databases/EmailProviderBody.db-wal
D/MediaScanner( 341): prescan time: 848ms
D/MediaScanner( 341): scan time: 797ms
D/MediaScanner( 341): postscan time: 36ms
D/MediaScanner( 341): total time: 1681ms
D/MediaScannerService( 341): done scanning volume internal
D/dalvikvm( 442): GC_CONCURRENT freed 395K, 52% free 2754K/5639K, external 0K/0K, paused 15ms+5ms
D/EAS SyncManager( 431): !!! EAS SyncManager, stopping self
D/Eas Debug( 431): Logging:
D/EAS SyncManager( 431): !!! EAS SyncManager, onDestroy
I/ActivityManager( 171): Start proc com.android.quicksearchbox for broadcast com.android.quicksearchbox/.SearchWidgetProvider: pid=454 uid=10031 gids={3003}
I/ActivityThread( 454): Pub com.android.quicksearchbox.google: com.android.quic
I/ActivityThread( 454): Pub com.android.quicksearchbox.shortcuts: com.android.quicksearchbox.ShortcutsProvider
I/ActivityManager( 171): Start proc com.android.protips for broadcast com.android.protips/.ProtipWidget: pid=462 uid=10035 gids={}
D/dalvikvm( 454): GC_CONCURRENT freed 365K, 52% free 2751K/5639K, external 0K/0K, paused 4ms+5ms
I/ActivityManager( 171): Start proc com.cyanogenmod.cmparts for broadcast com.cyanogenmod.cmparts/.intents.LEDNotificationReceiver: pid=470 uid=1000 gids={1015, 3002, 3001, 3003}
D/dalvikvm( 462): GC_CONCURRENT freed 379K, 52% free 2728K/5639K, external 0K/0K, paused 4ms+34ms
D/dalvikvm( 163): GC_EXPLICIT freed 11K, 51% free 2665K/5379K, external 0K/0K, paused 236ms
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 135ms
I/ActivityThread( 470): Pub com.cyanogenmod.cmparts.provider.Settings: com.cyanogenmod.cmparts.provider.SettingsProvider
D/dalvikvm( 163): GC_EXPLICIT freed <1K, 51% free 2665K/5379K, external 0K/0K, paused 99ms
I/ActivityManager( 171): Start proc com.cooliris.media for broadcast com.cooliris.media/com.cooliris.cache.BootReceiver: pid=479 uid=10004 gids={1015, 3003}
D/dalvikvm( 470): GC_CONCURRENT freed 411K, 52% free 2738K/5639K, external 0K/0
I/ActivityThread( 479): Pub com.cooliris.picasa.contentprovider: com.cooliris.picasa.PicasaContentProvider
D/dalvikvm( 479): GC_CONCURRENT freed 424K, 52% free 2746K/5639K, external 0K/0K, paused 4ms+5ms
I/Database( 479): sqlite returned: error code = 0, msg = Recovered 10 frames from WAL file /data/data/com.cooliris.media/databases/picasa.db-wal
I/BootReceiver( 479): Got intent with action android.intent.action.MEDIA_MOUNTED
I/CPUSettings( 470): Restore disabled by user preference.
D/MediaScannerService( 341): start scanning volume external
I/BootReceiver( 479): Got intent with action android.intent.action.MEDIA_SCANNER_FINISHED
V/MediaScanner( 341): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@406bd420
V/MediaScanner( 341): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@406bd420
D/MediaScanner( 341): prescan time: 228ms
D/MediaScanner( 341): scan time: 11ms
D/MediaScanner( 341): postscan time: 9ms
D/MediaScanner( 341): total time: 248ms
D/MediaScannerService( 341): done scanning volume external
D/dalvikvm( 479): GC_CONCURRENT freed 504K, 52% free 2785K/5767K, external 0K/0K, paused 4ms+5ms
I/CacheService( 479): Starting CacheService
I/CacheService( 479): Preparing DiskCache for all thumbnails.
I/CacheService( 479): DiskCache ready for all thumbnails.
I/ActivityManager( 171): No longer want com.android.settings (pid 283): hidden #16
E/ActivityThread( 367): Service com.clockworkmod.billing.BillingService has leaked ServiceConnection com.clockworkmod.billing.t@406a8ae8 that was originally bound here
E/ActivityThread( 367): android.app.ServiceConnectionLeaked: Service com.clockworkmod.billing.BillingService has leaked ServiceConnection com.clockworkmod.billing.t@406a8ae8 that was originally bound here
E/ActivityThread( 367): at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:938)
E/ActivityThread( 367): at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:833)
E/ActivityThread( 367): at android.app.ContextImpl.bindService(ContextImpl.java:898)
E/ActivityThread( 367): at android.content.ContextWrapper.bindService(ContextWrapper.java:347)
E/ActivityThread( 367): at com.clockworkmod.billing.BillingService.onSta
rtCommand(Unknown Source)
W/ActivityManager( 171): Unbind failed: could not find connection for android.os.BinderProxy@40917488
D/dalvikvm( 367): GC_EXPLICIT freed 297K, 52% free 2763K/5639K, external 0K/0K, paused 52ms
D/dalvikvm( 171): GC_CONCURRENT freed 1058K, 45% free 4546K/8135K, external 2618K/3818K, paused 6ms+9ms
D/dalvikvm( 229): GC_CONCURRENT freed 136K, 47% free 3026K/5703K, external 507K/1012K, paused 4ms+6ms
I/power ( 171): *** set_screen_state 0
D/LockPatternKeyguardView( 171): onScreenTurnedOff()
I/dalvikvm( 171): Jit: resizing JitTable from 1024 to 2048
D/dalvikvm( 171): GC_CONCURRENT freed 1023K, 44% free 4578K/8135K, external 2618K/3818K, paused 6ms+9ms
D/dalvikvm( 249): GC_CONCURRENT freed 403K, 49% free 3078K/6023K, external 0K/0K, paused 5ms+7ms
andI/gralloc ( 133): using (fd=25)
what ive found, is that if yres is over 600, it fails to support page flipping (yres == yres_virtual) and everything just works fineE/ActivityManager( 133): Attempt to launch receivers of broadcast intent Intent { act=android.intent.action.TIME_SET flg=0x20000000 } before boot completion
that is ignorable, its due to there being no rtc hardwarecleverca22 wrote:this looks similar to a problem i just ran into as well, the key things ive found so far are this (from above log)
I/gralloc ( 133): yres_virtual = 1024 pxwhat ive found, is that if yres is over 600, it fails to support page flipping (yres == yres_virtual) and everything just works fineE/ActivityManager( 133): Attempt to launch receivers of broadcast intent Intent { act=android.intent.action.TIME_SET flg=0x20000000 } before boot completion
while trying to get page flipping to work, i used config.txt to force the hdmi to 800x600 (did you force 656x512, or is your tv just really sucky?)
and once i had the resolution low enough, it began to crash in the same spot, sending a broadcast before boot is done
the only 'fix' right now that i can see, is to bring yres over 600, but thats far from optimal
No idea, we havnt investigated rca due to it being a PITAcleverca22 wrote:its causing the entire system_server to crash, and on the 2nd start, the screen remains completely black
any idea why it would be solid black?
