tangoviktor
Strange issue with HDMI on Android TV
Wed Apr 26, 2017 9:29 pm
I used an rpi3 and raspand to make my dumb tv into a smart tv. But i have ran into a slight issue regarding the hdmi settings. I have tried pretty much every possible combination that i can have with the config file, but i only get it so far that i get mode not supported by the TV and then a rainbow poweron screen from rpi aaaand after that a black blank page. The strange issue occurs when i unplug the power. Then i suddenly get a glimps of what is on the screen. In this case the android logo. If i would have waited longer i would have had the android tv main menu. Can anybody help me sort this out? I cant be the only one.
Video of the issue is here https://www.youtube.com/watch?v=W5WUDd5x8Jg
current config.txt settings are as follows
hdmi_force_hotplug=1
hdmi_drive=2
config_hdmi_boost=11
hdmi_group=1
hdmi_mode=4
disable_overscan=1
framebuffer_width=1280
framebuffer_height=720
kernel=zImage
device_tree=bcm2710-rpi-3-b.dtb
dtparam=audio=on
dtoverlay=vc4-kms-v3d,cma-256
initramfs ramdisk.img 0x01f00000
mask_gpu_interrupt0=0x400
avoid_warnings=2
gpu_mem=256
enable_uart=1
Re: Strange issue with HDMI
Wed Apr 26, 2017 9:56 pm
hdmi_drive=2
hdmi_group=1
hdmi_mode=4
disable_overscan=1
kernel=zImage
dtparam=audio=on
avoid_warnings=2
gpu_mem=256
enable_uart=1
Try this:
#hdmi_force_hotplug=1
#hdmi_drive=2
#config_hdmi_boost=11
#hdmi_group=1
#hdmi_mode=4
#disable_overscan=1
#framebuffer_width=1280
#framebuffer_height=720
kernel=zImage
dtparam=audio=on
#dtoverlay=vc4-kms-v3d,cma-256
#mask_gpu_interrupt0=0x400
avoid_warnings=2
gpu_mem=256
enable_uart=1
This is a doctor free zone.
tangoviktor
Thu Apr 27, 2017 4:47 am
Nope, did not work.
tangoviktor
Thu Apr 27, 2017 6:28 am
Works on an HDMI monitor, so i think that the config settings are wrong for my TV.
Fri Apr 28, 2017 4:05 pm
Try booting a copy of plain Raspbian Jessie 2017-04-10.
If that works you can capture the edid data and use that to create a custom setting on your non-Raspbian SDCard.
tangoviktor
Fri Apr 28, 2017 6:39 pm
I got this info , tried
hdmi_group=1
hdmi_mode=5
but still got the same problem. Boots into other raspbian GUI with no problems. picture shows the info that i got.
https://drive.google.com/open?id=0Bxzv- ... VBOd3J4cFE
watch what happens if i unplug the power to the raspberry after a minute or so..
https://www.youtube.com/watch?v=GXbgrUHpmu4
beta-tester
Sat Apr 29, 2017 8:01 am
am i got it right, your TV is able to display Raspbian installation on the screen properly, but your TV is not able to display your "android" installation?
is on your SD card NOOBS installed? then you maybe are dealing with the wrong config.txt file - if you plug such a SD card into your PC, the config.txt file you normally will see is that for NOOBS only.
BTW, those settings i used sucessfully for all the TV's i ever tried (at home, at parents, at friends, at hotels)
[pi1]
arm_freq=1000
core_freq=500
sdram_freq=600
over_voltage=6
[pi2]
arm_freq=1000
core_freq=500
sdram_freq=500
over_voltage=2
[all]
max_usb_current=1
gpu_mem=128
gpu_mem_256=112
gpu_mem_512=160
gpu_mem_1024=256
disable_overscan=1
config_hdmi_boost=4
hdmi_drive=2
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
tangoviktor
Sat Apr 29, 2017 8:31 am
Nope, not NOOBS, but i used the win32diskimager to write the Android tv image to the sd card.
beta-tester
Sun Apr 30, 2017 7:34 am
where did you got your android tv image for RPi from?
maybe better and more efficient to ask them - if there is a forum/community to ask.
Sun Apr 30, 2017 8:26 am
tangoviktor wrote:Hello,
hdmi_drive=2
hdmi_group=1
hdmi_mode=4
disable_overscan=1
kernel=zImage
dtparam=audio=on
avoid_warnings=2
gpu_mem=256
enable_uart=1
Android all flavors has its own Community Forum:
https://groups.google.com/forum/m/#!forum/android-rpi
Retired disgracefully.....
Return to “Android”
