m4the0
Raspberry Pi 3 - USB OTG HOST
Mon Mar 13, 2017 11:29 am
I would like to ask if Raspberry Pi 3 have usb otg ?
Thanks in advance.
Regards
Re: Raspberry Pi 3 - USB OTG HOST
Mon Mar 13, 2017 11:38 am
m4the0 wrote:Hello,
Thanks in advance.
Regards
No, because there is a USB Hub Chipset on the USB2 Bus........
Retired disgracefully.....
PiGraham
Mon Mar 13, 2017 12:03 pm
m4the0 wrote:Hello,
Thanks in advance.
Regards
Pi3 doesn't have OTG. Pi Zero has that.
Pi3 has USB host mode. You can plug in slave devices like keyboards, memory sticks and sound cards.
It doesn't have slave mode, so the Pi3 won't appear as a device connected to your PC or Mac.
m4the0
Mon Mar 13, 2017 12:07 pm
So, if i used Android Things image on my Raspberry Pi 3, i wouldn't be able to connect mouse or keyboard to it ?
mahjongg
Mon Mar 13, 2017 12:15 pm
m4the0 wrote:So, if i used Android Things image on my Raspberry Pi 3, i wouldn't be able to connect mouse or keyboard to it ?
Yes you would because it would use host mode, not OTG mode to connect mice and keyboards, OTG mode would mean the PI would *act* like a mouse or keyboard.
But Android isn't an officially supported OS anyway. For information about it you should go here: https://groups.google.com/forum/#!forum/android-rpi
or here https://developer.android.com/things/ha ... rrypi.html but not in this forum, as we do NOT support any version of Android. That is why the android version of this forum is locked, and all questions about android are moved there.
also read the FAQ: https://www.raspberrypi.org/help/faqs/#softwareAndroid
Return to “Android”
