RicardoGomes
install android sdk/lib32stdc++6 on raspberry pi/raspbian
Thu Jun 16, 2016 9:28 am
I'm trying to install android sdk on raspberry pi 3. I've already download the sdk, however now i want to install the android studio.
The following error appears:
"Unable to run mkscard SDK Tool".
One of the causes/solution i've search in other foruns is due to missing some libraries and compatibilities between version 64 and 32 bts... A solution to solve this was to execute the following comand "$ sudo apt-get install lib32stdc++6" the following error appears:
"Unable to locate package lib32stdc++6
Couldn't find any package by regex lib32stdc++6"
In orther to solve this situation i tried to install lib32stdc++6 manually, using the https://packages.debian.org/jessie/lib32stdc++6. My question is: is there any way i could install lib32stdc++6 on raspbian? Is this needed in order to later install the android studio?
Any help would be very thankful =)
Re: install android sdk/lib32stdc++6 on raspberry pi/raspbia
Thu Jun 16, 2016 9:47 am
RicardoGomes wrote:Hi,
You appear to be trying to install x86-32 or x86-64 CPU Architecture packages.
https://en.wikipedia.org/wiki/Android_Studio
The Raspberry Pi's Raspbian Jessie is for ARMHF ARMv7......
Thinking outside the box is better than burying your head in the sand...
RicardoGomes
Thu Jun 16, 2016 10:19 am
So there will be no feasible to install or to get that packages into raspberry pi's raspbian jessie?
Thu Jun 16, 2016 10:22 am
Unfortunately not, if you had read the system requirements first would of saved you the hassle:
http://code.tutsplus.com/tutorials/andr ... bile-20086
https://developer.android.com/studio/index.html
IgorGanapolsky
Fri Feb 10, 2017 4:25 pm
RicardoGomes wrote:however now i want to install the android studio.
Out of curiosity, do you need to run the full Android Studio IDE on Raspberry Pi? I imagine it would be slow. You can instead use commandline tools from Android SDK and Gradle to build and test your projects...
Return to “Android”
