Strugglingstudent
UART User interaction
Wed Jan 15, 2014 12:05 am
Dear Rpi community
I am a newbie to C and Rpi in general and i was looking a round a lot to understand how can i use the UART on Rpi in bare metal C programing to make the user able to change the value of variables in the code from the terminal of Ubuntu.
My program is an RGB LED dimmer, I wrote it to give the RGB led "breathing" effect. fade in and fade out slowly.
I am trying now to dimm the different colors from the keyboard and display some kind of message on the terminal to show user interaction, I am using raspbootcom(1) to send the Kernel.img to the Rpi, and as i read it leaves a channel open for all input and output communication through something called STDIN and STDOUT, but i have no idea how or what to write in the code to manage to send values into variables and display output on the screen, given that any library i Include gets rejected by the gcc compiler.
I knw this might be very general and not detailed question but I am lost and i have a deadline to meet to be able to finish this course.
Thanks a lot for your help
(1)https://github.com/mrvn/raspbootin
This is my code:
#include <stdint.h>
#define GPIO_FSEL_ADDR 0x20200000
#define GPSET0_OFFS    28
#define GPCLR0_OFFS    40
#define GPFSEL1_OFFS1   8
#define LED_BIT_SET1    9
#define GPIO_PIN_OFFS1  23
#define GPFSEL1_OFFS2   8
#define LED_BIT_SET2    12
#define GPIO_PIN_OFFS2  24
#define GPFSEL1_OFFS3   8
#define LED_BIT_SET3    15
#define GPIO_PIN_OFFS3  25
#define mmio32(x) (*(volatile uint32_t*) (x))
volatile uint32_t tim;
volatile uint32_t l = 3000;
volatile uint32_t h = 1;
int main()
	//set as output
	mmio32(GPIO_FSEL_ADDR + GPFSEL1_OFFS1) |= (1<<LED_BIT_SET1);
	mmio32(GPIO_FSEL_ADDR + GPFSEL1_OFFS2) |= (1<<LED_BIT_SET2);
	mmio32(GPIO_FSEL_ADDR + GPFSEL1_OFFS3) |= (1<<LED_BIT_SET3);
	while (10)
				//fade in blue
					if (h < 10)
					do
			    h += 1;
			    l -= 1;
					// switch on led
					mmio32(GPIO_FSEL_ADDR + GPCLR0_OFFS) |= (1<<GPIO_PIN_OFFS1);
						// wait 1
						for(tim = 0; tim < l; tim ++);
					// switch off led
					mmio32(GPIO_FSEL_ADDR + GPSET0_OFFS) |= (1<<GPIO_PIN_OFFS1);
						// wait 2
						for(tim = 0; tim < h; tim ++);
			 	}while(h < 3000);
			//fade out blue
			if (l < 10)
					do
			    l += 1;
			    h -= 1;
					// switch on led
						// wait 1
					// switch off led
						// wait 2
			 	}while(l < 2999);
			//fade in green
			if (h < 3000) //h is the Low wave part
					h += 1;
					l -= 1;
					// switch on led
			mmio32(GPIO_FSEL_ADDR + GPCLR0_OFFS) |= (1<<GPIO_PIN_OFFS2);
						// wait 1
					// switch off led
						// wait 2
			//fade out green
			if (l < 10)
					do
			    l += 1;
			    h -= 1;
					// switch on led
						// wait 1
					// switch off led
					mmio32(GPIO_FSEL_ADDR + GPSET0_OFFS) |= (1<<GPIO_PIN_OFFS2);
						// wait 2
			 	}while(l < 2999);
		// fade in red
					h += 1;
					l -= 1;
					// switch on led
					mmio32(GPIO_FSEL_ADDR + GPCLR0_OFFS) |= (1<<GPIO_PIN_OFFS3);
						// wait 1
					// switch off led
					mmio32(GPIO_FSEL_ADDR + GPSET0_OFFS) |= (1<<GPIO_PIN_OFFS3);
						// wait 2
		//fade our red
			if (l < 10)
					do
			    l += 1;
			    h -= 1;
					// switch on led
						// wait 1
					// switch off led
						// wait 2
			 	}while(l < 2999);
