baking pi: external led
Posted: Sat Sep 28, 2013 5:07 pm
by strebor27
I have completed the baking pi tutorials and started on my own projects. At the moment I am just trying to switch a led on via GPIO PIN 24 (18).
this is very simple but I am obviously doing something wrong. is either my code or circuit incorrect? I first used the baking pi lesson 01 code and had my external led attached to pin 16. the pi's OK light came on but not my external led. I thought maybe 16 was not for external peripherals so I changed to pin 18.
.section .init
.globl _start
_start:
ldr r0,=0x20200000
mov r1,#1
lsl r1,#24
str r1,[r0,#4]
mov r1,#1
lsl r1,#18
str r1,[r0,#40]
loop$:
b loop$
Re: baking pi: external led
Posted: Sat Sep 28, 2013 5:54 pm
by rpdom
Which pin of P1 are you using?
GPIO 18 is connected to Pin 12 of P1.
Posted: Sat Sep 28, 2013 7:18 pm
by strebor27
p1 header: 18
GPIO 24
Posted: Sat Sep 28, 2013 8:29 pm
by rpdom
strebor27 wrote:p1 header: 18
GPIO 24
Ok, but your code is using GPIO 18. P1-12.
To use GPIO 24 it would have to be something like
.section .init
.globl _start
_start:
ldr r0,=0x20200000
mov r1,#1
lsl r1,#12
str r1,[r0,#8]
mov r1,#1
lsl r1,#24
str r1,[r0,#40]
loop$:
b loop$
(caveat: I haven't tested this, but I believe it to be correct)
Posted: Sat Sep 28, 2013 10:37 pm
by strebor27
ok thanks your right I was getting confused with the GPIO pins. I agree, your code looks right, I ran it but it still did not light the LED.
found this table, I understand that I have to turn the pin on at location 0x2020 0008 then clear the pin at 0x2020 0028 but what if I was to set pin 24 at address 0x2020 001c?
Posted: Sun Sep 29, 2013 11:50 am
by rpdom
Aha, yes.
The OK/ACT LED on GPIO 16 is connected between 3.3v and the GPIO, so it turns on when the GPIO is set to 0 (cleared), and off when the GPIO is set to 1 (set).
I assume your external LED is linked via a resistor between the GPIO pin and 0V. Therefore you will need to set the GPIO to 1 to make the LED turn on. [edit] I just re-checked your diagram, and this is correct.
So you are correct in saying that you need to write a 1 to bit 18 of 0x2020 001c.
Just change the "str r1,[r0,#40]" to "str r1,[r0,#28]".
Posted: Sun Sep 29, 2013 8:36 pm
by strebor27
yep thats it, got it working
cheers for your help
Do you know how many amps is in the output of the gpio pins?. trying to figure out what type of transistor I will need to drive a small dc motor.
Posted: Sun Sep 29, 2013 9:07 pm
by rpdom
I can't remember exactly, but the GPIO pins are only able to handle a few mA, maybe as much as 16mA but I would try to take as little current as possible from them. Somewhere like 2 mA should be enough to drive a mosfet transistor that will run a motor. Other people have driven motors from the GPIO pins, so a search should find some details of the circuits required.
Posted: Thu Oct 03, 2013 10:58 pm
by strebor27
hey any idea how I would go about setting the pin drive strength. I read that the default is 8mA. each pin is 3 bits so instead of setting the pin to 001 would you change its strength with a different value like 011?
