thebuell
Pixels in 24 bit resolutions
Wed Apr 24, 2013 10:02 pm
Does anyone have any example code that can draw pixels on a 24 bit resolution? Thanks!
valtonia
Re: Pixels in 24 bit resolutions
Fri Apr 26, 2013 9:13 pm
While not the most efficient way to do it, this works.
Where x and y is the pixel location and c is the colour. This routine will work for all bit-depths, in this example I've hard-coded fb_depth to be 24.
void set_pixel(unsigned int x, unsigned int y, unsigned int c)
   volatile unsigned char *pixel_addr;
   unsigned int fb_depth = 24;
   unsigned int ws = fb_depth / 8;
   // Calculate the pixel address
   pixel_addr = (volatile unsigned char *)FB_ADDRESS + (y * FB_PITCH) + (x * ws);
   // Set the pixel
   if (fb_depth >= 8)
      *pixel_addr++ = (c & 0x000000FF);
   if (fb_depth >= 16)
      *pixel_addr++ = (c & 0x0000FF00) >> 8;
   if (fb_depth >= 24)
      *pixel_addr++ = (c & 0x00FF0000) >> 16;
   if (fb_depth == 32)
      *pixel_addr++ = (c & 0xFF000000) >> 24;
Hope this helps.
V.
