The rpiForth will grow to include:
1. A file system on the SD card.
2. A text editor to write stored programs to load. ( no more host assembler ).
3. A forth ARM assembler, to write high performance forth words.
4. An Interactive multi-tasking operating system, you can fire up a task and let it run while doing other things or run two or more task at the same time.
5. A Floating point package per ANSI.
6. A I2C driver off board chips. Like the MSP430 micro.
How you all will fine some use for this.
Roland aviatorRHK
