DavidS
USB Interrupts???
Mon Jan 14, 2013 12:23 am
Currently I am using the CSUD USB driver with some small modifications, and would like to optimize this a bit. I would like to be able to hook an inturupt for USB Events rather than polling in order to improve the responciveness of the rest of my Operating System. And I am kind of stuck until I can improve the USB Handling a bit. The trouble is that I can not seem to find any information on what if any interupts are gennerated by the USB controler.
I have searched the forums, looked through the wiki, looked through every document that I have found related to the RPi HW, all to no avail.
Thus I have the following quesions about the USB HW configuration.
  • 1:) Does the USB controller generate inturpts to the ARM? if so on what events?
    2:) Is it possible to use DMA with the USB on the RPi?
    3a:) Where do I find some documentation on these points?
    3b:) Else can any one give me a usable overview on the above?
RPi = Way for me to have fun and save power.
100% Off Grid.
Household TTL Electricity Usage = 1.4KW/h per day.
500W Solar System, produces 2.8KW/h per day average.
tufty
Re: USB Interrupts???
Mon Jan 14, 2013 1:48 pm
DavidS wrote:I have searched the forums, looked through the wiki, looked through every document that I have found related to the RPi HW, all to no avail.
That's not terribly surprising, the USB implementation is made by Synopsys, and they are not forthcoming with documentation. Some information /is/ available, but only by pulling apart various datasheets, which mainly don't include the modifications Broadcom made to the Synopsys IP
Luke Robertson's document is probably the most complete one out there. The Ralink 3050 datasheet contains lots of handy tidbits, too.
Yes, it can / does. Lots and lots and lots of them.
It should be, if I've read properly. The Ralink documentation seems to imply it is.
Luke's document, and the Linux source.
DavidS
Mon Jan 14, 2013 2:03 pm
Ouch. I whas trying to avoid the Linux Source.
I have only glanced at it, though as with most things Linux it seems as if the people that write it do not know how to reasonably comment there code.
100% Off Grid.
DexOS
Mon Jan 14, 2013 2:40 pm
Batteries not included, Some assembly required.
DavidS
Mon Jan 14, 2013 3:19 pm
Thank you I seem to have forgot one document. That should help.
100% Off Grid.
