adriann
rpi to laptop connection
Thu Jan 10, 2013 2:15 pm
I am new at bare metal and I'd need some clear, step-by-step instructions for connecting the RPI to my laptop for this kind of programming. I know there are several ways to do it, but I need the simplest one. I believe it's the serial UART USB connection, but I am not sure what I need and what to do for this.
What is your opinion? What works best for you?
Thanks,
Adrian
DexOS
Re: rpi to laptop connection
Thu Jan 10, 2013 2:28 pm
There are many tuts, heres one that i wrote for my OS:
http://www.dex-os.com/DexBasic/Lesson2.htm
Batteries not included, Some assembly required.
dwelch67
Thu Jan 10, 2013 2:58 pm
I have some instructions as well
http://github.com/dwelch67/raspberrypi
David
adriann
Thu Jan 10, 2013 3:25 pm
Thanks for the replies. As far as I can see, both your instructions are based on a FTDI breakout board. But is it possible to use instead a USB to TTL 3.3V cable? I have one with the same specs as this one: https://www.modmypi.com/raspberry-pi-ac ... spberry-Pi
@David - After setting the connection and saving the config, what are the following steps needed to run your examples (say, blinker01) with this setup? How does it end up on the SD card and gets to be executed?
Thank you.
Adrian
