satyria
Change code from FASMARM assembler to GAS
Wed Sep 30, 2020 11:42 am
I'm currently trying to change a code that was written for FASMARM to Gnu AS.
The following code is written as a macro in FASMARM:
macro imm32 reg,immediate {
  mov reg,(immediate) and $FF
  orr reg,(immediate) and $FF00
  orr reg,(immediate) and $FF0000
  orr reg,(immediate) and $FF000000
My change resulted in this code:
.macro imm32 reg,immediate
  mov \reg,\immediate and $FF
  orr \reg,\immediate and $FF00
  orr \reg,\immediate and $FF0000
  orr \reg,\immediate and $FF000000
.endm
Now when I use this macro with the following code, I get error messages.
Code:
imm32 r0,#FB_STRUCT + MAIL_TAGS
Error messages:
main.s:25: Error: garbage following instruction -- `mov r0,#FB_STRUCT+MAIL_TAGS and $FF'
main.s:25: Error: garbage following instruction -- `orr r0,#FB_STRUCT+MAIL_TAGS and $FF00'
main.s:25: Error: garbage following instruction -- `orr r0,#FB_STRUCT+MAIL_TAGS and $FF0000'
main.s:25: Error: garbage following instruction -- `orr r0,#FB_STRUCT+MAIL_TAGS and $FF000000'
What should the macro look like correctly?
Greetings, Matthias
hippy
Re: Change code from FASMARM assembler to GAS
Wed Sep 30, 2020 12:12 pm
This is what I am using ....
.macro          num32   reg,opr
                mov     \reg,#(\opr) & 0xFF000000
                orr     \reg,#(\opr) & 0x00FF0000
                orr     \reg,#(\opr) & 0x0000FF00
                orr     \reg,#(\opr) & 0x000000FF
.endm
Putting the 'opr' within brackets ensures precedence is kept when it is invoked with an expression. And I don't think '$' is accepted as a hexadecimal prefix; use '0x' instead.
jahboater
Wed Sep 30, 2020 12:15 pm
Perhaps use movw and movt instead of all the orr's ? (16-bit immediates)
At least:
movw \reg,#(\opr) & 0x0000FFFF
should save one insn.
similarly mov and movk for A64
The A72 CPU is starting to merge these operations.
Pi4 8GB running PIOS64 Lite
satyria
Wed Sep 30, 2020 12:50 pm
Great, it worked. But now I get a new error message:
main.s:25: Error: invalid operands (.text and *UND* sections) for `+'
The code is:
imm32 r0,FB_STRUCT + MAIL_TAGS
Greetings, Matthias
