hippy
[SOLVED] Life's a GAS, or maybe not!
Sun Sep 27, 2020 8:40 pm
This works ...
pi@Pi3B:~/apps/sol $ as -o xyzzy.o xyzzy.hll.sol.pi
pi@Pi3B:~/apps/sol $ gcc -o xyzzy.exe xyzzy.o
pi@Pi3B:~/apps/sol $ ./xyzzy.exe
Yippee!
But this doesn't ...
pi@Pi3B:~/apps/sol $ as -g -o xyzzy.o xyzzy.hll.sol.pi
xyzzy.hll.sol.pi: Assembler messages:
xyzzy.hll.sol.pi: Error: unaligned opcodes detected in executable segment
So how do I find what it thinks are those unaligned opcodes and where they are ?
I can't see anything in the source, nor anything obvious when I get 'as' to produce a listing file, no error message which says "this here is unaligned".
trejan
Re: Life's a GAS, or maybe not!
Sun Sep 27, 2020 9:00 pm
You enabled debug and as is emitting DWARF debug info like the address mapping for code to source line. Your error is because it is assuming everything will be a multiple of 2 bytes since DWARF2_LINE_MIN_INSN_LENGTH is set to 2 but somewhere you're adding a single byte to a segment.
You'll have to dig around in your code to work out what exactly is causing this. Check data as well.
hippy
Sun Sep 27, 2020 9:45 pm
That's the problem; how ?
Everything is aligned on 4-byte boundaries, lower two lsb's zero. I'm only using 32-bit data and that's aligned. Every '.asciz' has a '.align 2' so that doesn't appear to be it. And there's nothing left which I can see to explain it.
jahboater
Sun Sep 27, 2020 10:12 pm
Could you post the code?
It must be quite small, or does it do more than print Yippee! ?
Pi4 8GB running PIOS64 Lite
hippy
Re: [SOLVED] Life's a GAS, or maybe not!
Mon Sep 28, 2020 7:32 am
It's generated code with a full-blown Virtual Machine implementation included so there's a bit more to it than just a 'print', but the source size would be manageable.
Having battled through adding print commands to debug a tricky part of task scheduling I thought it was time to learn how to use 'gdb', which is where what was working fell apart.
I have however resolved the issue. Not so much "unaligned opcodes" as the image not being padded to be multiples of two/four bytes as trejan predicted. I had inserted my '.align 2' before my '.asciz' so that aligned their address and padded previous '.asciz' but could leave a trailing number of odd bytes at the end of the program. Moving the '.align' to after '.asciz', or a final '.align' at the end of the program, pads things out as required.
"Unaligned opcodes" had me focusing on what opcodes there were, not what opcodes there weren't.
