SHINYFATHIMA
Enable/Disable Cache
Sat Jan 05, 2013 9:09 am
I would like to enable or disable portion of ARM L2 's cache memory of raspberry PI. Please help me on this.
tufty
Re: Enable/Disable Cache
Sat Jan 05, 2013 4:11 pm
http://infocenter.arm.com/help/index.js ... index.html should have the information you need.
Lob0426
Sat Jan 05, 2013 6:02 pm
Add the following line in /boot/config.txt
enable_l2cache=0
I believe that will disable your L2 cache for you. If not try =1.
enable_l2cache: enable arm access to GPU's L2 cache. Needs corresponding L2 enabled kernel. Default 0.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
SHINYFATHIMA
Sun Jan 06, 2013 4:01 am
Thank you for your answer. If i add the enable_L2Cache in my config file how do i make sure that my cache has either enabled or disabled? Could you please help me with the steps to get the disabled kernel for my board. Thanks in Advance......
