satyria
Use #define or EQU in assembler
Mon Aug 17, 2020 3:21 pm
I want to make my assembler code more readable and wanted to use something like #define (EQU).
I use "Gnu-AS".
Example:
#define BASE 0xFE000000
ldr r0,= BASE
Unfortunately, the linker shows an error when compiling:
build/main.o: in function `wait2$':
(.init+0x8044): undefined reference to `BASE'
By the way: BASE is not used in the WAIT function.
What options are there with the Gnu-AS?
Greetings, Matthias
trejan
Re: Use #define or EQU in assembler
Mon Aug 17, 2020 3:25 pm
The equivalent to #define in gas is .set
You need to feed it through the cpp preprocessor first if you want to use #define. Either add that as part of your build script or give your source file the .S extension and use gcc on it.
dwelch67
Mon Aug 17, 2020 3:30 pm
#define is C and not assembly language (gnu assembler), so you would want to use equ. Otherwise it is yet another assembly/hybrid language and you have to pass it through the C preprocessor before it goes to the assembler.
satyria
Mon Aug 17, 2020 4:00 pm
many thanks
Unfortunately, equ did not work either. same error.
I've just read the GAS documentary. The attempt with "=" worked within the code:
BASE = 0xFE200000
However, when I try to load this with .include, the same error occurs again.
in the "main.s" file:
.include ../include/base.h
The base.h:
BASE = 0xFE200000
satyria
Thu Aug 20, 2020 6:50 am
Sorry, found my mistake. It works as described.
However, I have a new question: I would now like to set a value that I would like to process via .if query. Example:
.equ RPI_Version, "1a"
.if RPI_Version == "1a"
 .endif
However, this does not work because the assembler does not understand the "a" under .equ here. How can I avoid that?
How can I use strings for .if?
Greetings, Matthias
LdB
Thu Aug 20, 2020 9:16 am
Use just numbers :-)
The `#if' directive allows you to test the value of an arithmetic expression, rather than the mere existence of one macro. Its syntax is
#if expression
controlled text
#endif
#ifdef in C is for strings but I don't think the assembler can handle them but admittedly I would never do it so check you might get lucky.
satyria
Thu Aug 20, 2020 9:24 am
I found a solution.
Example:
.equ RPI_Version_1a, 1
.ifdef RPI_Version_1a
.endif
Greetings Matthias
