2ndwolf
Baking Pi OK4
Fri Jan 04, 2013 5:27 am
Considering the following code:
 .globl GetSystemTimerBase
GetSystemTimerBase:
ldr r0,=0x20003000
mov pc,lr
.globl GetTimeStamp
GetTimeStamp:
push {lr}
ldrd r0,r1,[r0,#4]
pop {pc}
delay .req r2
mov delay,r0
push {lr}
bl GetTimeStamp
start .req r3
mov start,r0
loop$:
bl GetTimeStamp
elapsed .req r1
sub elapsed,r0,start
cmp elapsed,delay
.unreq elapsed
bls loop$
.unreq delay
.unreq start
pop {pc}
Why do we push{lr} just before bl GetTimeStamp?
Wouldn't pop{pc} at the end of the code just take that lr we pushed and give an endless loop?
Chadderz
Re: Baking Pi OK4
Fri Jan 04, 2013 7:29 am
Yes, it would take the lr we pushed, but the lr contains the address after the bl that takes us to GetTimeStamp. The bl sets the pc to the address we wish to branch to, but also has the side effect of setting lr to the address after the bl command. This means at the time of the push the lr contains the address after the bl, and so when we do the pop we are effectively branching to that address. This achieves the effect of a function call and return. We have to do this in order to preserve the lr, which would otherwise be overwritten in the bl GetSystemTimerBase.
2ndwolf
Re: Baking Pi OK4
Fri Jan 04, 2013 10:43 pm
So we do want the program to branch back to bl GetTimeStamp once loop$ has finished?
2ndwolf
Re: Baking Pi OK4
Wed Jan 09, 2013 9:53 pm
*bump*
DavidS
Re: Baking Pi OK4
Wed Jan 09, 2013 11:50 pm
2ndwolf wrote:So we do want the program to branch back to bl GetTimeStamp once loop$ has finished?
No we branch back to the instruction fallowing bl GetTimeStamp
