I try to produce a PWM on a RPI zero pin.. it's a bare metal c code
I try to have a pulse on pin 13, I tried many different codes, none of them work
while I can use GPIO's, SPI and UART without problem so the bootloader works
I also tried to put the card directly on the sd card
I tried the sd card in another SPI zero, same problem
#define BCM2835_BASE 0x20000000
#define GPIO_BASE ( BCM2835_BASE + 0x200000 )
#define GPIO_CLOCK_BASE ( BCM2835_BASE + 0x101000 )
#define PWM_BASE ( BCM2835_BASE + 0x20C000 )
#define SYSTIMER_BASE ( BCM2835_BASE + 0x3000 )
#define GPIO_CLOCK_PWM_OFFSET (40 * 4)
#define GPIO_CLOCK_PWD (0x5A << 24)
#define CM_CTL_MASH_1 ( 1 << 9 )
#define CM_CTL_BUSY ( 1 << 7 )
#define CM_CTL_KILL ( 1 << 5 )
#define CM_CTL_ENAB ( 1 << 4 )
#define CM_CTL_SRC_OSCI ( 1 << 0 )
#define CM_DIV_DIVI_SHIFT 12
#define CM_DIV_DIVF_SHIFT 0
#define GPIO_GPFSEL1 4
#define PWM_CTL_SBIT1 ( 1 << 3 )
#define PWM_CTL_PWEN1 ( 1 << 0 )
#define PWM_STA_STA1 ( 1 << 9 )
#define PWM_STA_BERR ( 1 << 8 )
#define PWM_STA_GAPO1 ( 1 << 4 )
#define PWM_BUFFER_SIZE 2048
typedef struct {
volatile unsigned int ctl; // 0x00
volatile unsigned int sta; // 0x04
volatile unsigned int dmac; // 0x08
volatile unsigned int unused1; // 0x0c
volatile unsigned int rng1; // 0x10
volatile unsigned int dat1; // 0x14
volatile unsigned int fif1; // 0x18
volatile unsigned int unused2; // 0x1c
volatile unsigned int rng2; // 0x20
volatile unsigned int dat2; // 0x24
} Pwm_registers;
volatile unsigned int* gpio = (unsigned int*)GPIO_BASE;
typedef struct {
volatile unsigned int control_status;
volatile unsigned int counter_lo;
volatile unsigned int counter_hi;
volatile unsigned int compare0;
volatile unsigned int compare1;
volatile unsigned int compare2;
volatile unsigned int compare3;
} Systimer_t;
Systimer_t* systemTimer = (Systimer_t *)SYSTIMER_BASE;
typedef struct {
volatile unsigned int div;
}Clock_manager;
int notmain ( void )
volatile Pwm_registers* sysPwm = (Pwm_registers *) PWM_BASE;
volatile Clock_manager* sysClockManager = (Clock_manager *) (GPIO_CLOCK_BASE + GPIO_CLOCK_PWM_OFFSET);
// ALT0 on pin 13
gpio[GPIO_GPFSEL1] |= (1 << (9+2));
gpio[GPIO_GPFSEL1] &= ~(1 << (9+1));
gpio[GPIO_GPFSEL1] &= ~(1 << (9+0));
// maximum frequency 37.5K, 256 resolution
sysClockManager->ctl = GPIO_CLOCK_PWD | CM_CTL_KILL;
while ( sysClockManager->ctl & CM_CTL_BUSY);
// clock i = 2 f = 0
sysClockManager->div = GPIO_CLOCK_PWD | (2 << CM_DIV_DIVI_SHIFT) | (0 << CM_DIV_DIVF_SHIFT);
sysClockManager->ctl = GPIO_CLOCK_PWD | CM_CTL_MASH_1 | CM_CTL_SRC_OSCI | CM_CTL_ENAB;
sysPwm->ctl = 0;
sysPwm->rng1 = 256;
sysPwm->dat1 = 128;
sysPwm->ctl |= PWM_CTL_PWEN1;
while(1)
return(0);
Any bare-metal guru that can help me on this one?
thanks for your help
Phil
