cleverca22
i have recently ported little-kernel to the VPU
Fri Feb 14, 2020 8:00 am
it may interest you to know, that i have recently ported little-kernel to the VPU, and it can run on all models i own (1,2,3,4)
https://github.com/cleverca22/lk/tree/vc4
for the rpi 1-3, it can run as either a bootcode.bin file, or a start.elf loaded by the official bootcode.bin
for the rpi4, it can run as a start4.elf file
currently, the LK fork isnt able to bring the arm's online, but i do have https://github.com/cleverca22/rpi-open-firmware able to boot linux with the USB fully working, so its just a matter of porting that code over
the main thing you would loose, if switching over from the official firmware, is all graphical output, and all hw encode/decode support, and probably the cameras too
usb/ethernet/i2c/serial/sdcard all work fine, and spi would probably also work (havent tried it yet)
edit: this was a reply to somebody that was asking about LK on the VPU, since i lack permissions to PM them, but it has since been moved to a new thread, and now they are less likely to see it
