chigley
GPIO Controller Segmentation Fault
Mon Dec 10, 2012 2:42 pm
I'm trying to use the below assembly code to set GPIO pin 16 high, taken from this tutorial:
.align 2
.globl main
main:
    ldr r0,=0x20200000
    mov r1,#1
    lsl r1,#18
    str r1,[r0,#4]
    mov r1,#1
    lsl r1,#16
    str r1,[r0,#40]
loop$:
    b loop$
I'm compiling it with GCC, and when I debug with GDB, the following error occurs:
Program received signal SIGSEGV, Segmentation fault.
main () at pinHigh.s:42
42	str r1,[r0,#4]
I believe that the address value in r0 is correct, as a C file which correctly compiles and runs has the following definitions at the top:
// Access from ARM Running Linux
#define BCM2708_PERI_BASE        0x20000000
#define GPIO_BASE                (BCM2708_PERI_BASE + 0x200000) /* GPIO controller */
Any advice would be appreciated!
Cheers
chigley
Re: GPIO Controller Segmentation Fault
Mon Dec 10, 2012 4:02 pm
I should add, I'm running with sudo permissions, as I understand that this is required for GPIO.
joan
Mon Dec 10, 2012 4:43 pm
If you are using Linux (which mention of gdb, sudo etc. suggests) then you'll need to memory map fron Linux virtual addresses to the hardware physical address.
