rst
Re: BCM2711B0
Sat Jul 13, 2019 11:28 am
Some additional notes on Raspberry Pi 4 bare metal support from basically porting Circle:
Firmware
This has been tested with the firmware from Jul 9 2019 from here. Running bare metal code requires the following new firmware files:
  • fixup4.dat
  • start4.elf
  • bcm2711-rpi-4-b.dtb (did not work without)
bootcode.bin is not needed for the RPi 4. The 32-bit kernel image for the RPi 4 is named kernel7l.img, the 64-bit kernel image kernel8.img, but 64-bit mode is not activated automatically like on the RPi 3. A config.txt file with this entry is needed:
arm_64bit=1
Mailbox property functions work as before.
I/O addresses
Beside the new I/O base address 0xFE000000 for the BCM2835 peripherals, there is a new I/O region for the BCM2836 local peripherals at 0xFF800000 (from the QA7 document). It is not known, how many of these local peripheral registers are implemented, but some are.
MMU and caches
The MMU is fully compatible to that of the Cortex-A53 in both 32- and 64-bit mode (as far as I am using it). Only the translation tables have to be updated to cover the new I/O regions and the Highmem (above 1 GB).
Cache configuration has changed. The L1 data cache (per core) is 2-way with 256 sets of 64 byte cache lines. The L2 data cache (unique) is 16-way with 1024 sets of 64 byte cache lines. The length of the cache lines did not change.
Memory layout and Highmem
The basic memory layout (below 1GB, ARM / GPU memory split) is unchanged. The additional RAM of the RPi 4 is implemented as Highmem above 1GB. The well-known property mailbox function 0x00010005 does only return the available memory size on ARM side below the memory split for the GPU. The available Highmem size can be detected from the board revision (mailbox function 0x00010002).
Interrupt controller
There is a new GIC-400 interrupt controller available, which implements the GICv2 architecture (not GICv3!). It is not known, if the BCM2835 interrupt controller is still available and can be used to generate interrupts. The Distibutor window of the GIC-400 is at 0xFF841000 (unique) and the CPU Interface window at 0xFF842000 (each core "sees its own CPU Interface window at this address). Interrupt numbers can be taken from the device tree sources from Linux. 32 has to be added to SPI interrupt numbers and 16 to PPI numbers from these files.
Unfortunately it is difficult to use the FIQ with the GIC-400 without "kernel_old=1", because the required register settings can only be done from Secure Mode. A Secure Monitor has to be implemented to support this, which is possible in AArch32, but probably not in AArch64. Maybe one has to move to the "kernel_old=1" setting in config.txt to use the FIQ.
Multi-core
Multi-core support works as before (spin mailboxes / table). Inter-Processor-Interrupts (IPI) can be generated using the GIC-400 as SGIs.
Timer and GPIO clocks
The oscillator is running at 54 MHz now. To generate timer interrupts the ARMv7 per core CPU timer can be used (via the GIC). The BCM2835 system timer peripheral still exists, but I don't know, if it can still generate interrupts.
GPIO clock source Oscillator runs at 54 MHz now and PLLD at 750 MHz.
DMA channels
At least DMA channels 0-7 work as before, while channel 1 and 3 is used by the firmware and channel 7 is a LITE engine. Channel 8 should also work and is also a LITE engine, but has the same interrupt number as channel 7. Channel 9 and 10 are used by the firmware. There are new 40-bit DMA engines 11-14, which are unknown.
Audio
PWM audio is working differently and is currently unknown. There is a new PWM peripheral device dedicated to the PWM audio via the headphone jack. It's I/O address is probably "base of PWM0" + 0x800. It is not known, which GPIO clock this PWM device uses and which DMA DREQ selector must be used to program PWM audio on the RPi 4.
Audio using the VCHIQ "AUDS" service does luckily still work (via headphone jack and HDMI).
EDIT: HDMI audio tested
joan
Re: BCM2711B0
Sat Jul 13, 2019 4:53 pm
@rst
Did you discover the 54 MHz Osc clock value in a document or by experiment? Similarly the DMA channel info.
rst
Re: BCM2711B0
Sat Jul 13, 2019 5:40 pm
For the oscillator clock rate I generated a clock signal on GPIO4 with a defined divider and the oscillator source and measured the resulting clock rate. From that I calculated the oscillator frequency to be 54 MHz.
The DMA channel allocation info (free / used by firmware) can be requested via property mailbox call 0x00060001. The LITE engine info can be get from the DEBUG register. I tested DMA channels 0, 2, 4, 5, 6 and 7 with scrolling the frame buffer and a DMA-driven SPI driver.
Further info is from here (40-bit engines) and here (32-bit engines).
joan
Re: BCM2711B0
Sat Jul 13, 2019 5:47 pm
@rst Thanks for that. I knew something had changed about the DMA channels and by experiment the new 750 MHz PLLD. I didn't notice the 54 MHz oscillator change.
rst
Re: BCM2711B0
Sat Jul 13, 2019 6:02 pm
@joan You are welcome.
What I am missing at the moment is the PWM audio info for the new PWM device (assigned clock, DREQ and GPIO Alternate setting). If somebody would share info about this, it would be great. Perhaps we have to wait for the new "Peripherals document", but this may take time.
DavidS
Re: BCM2711B0
Sat Jul 13, 2019 8:22 pm
Gavinmc42 wrote:
Sat Jul 13, 2019 9:30 am
That 512KB boot EEPROM is so calling to me :D
How much of an OS can fit in that?
That depends on how big the OS is, and how much is leftover after the firmware is in it.
theoldwizard1
Re: BCM2711B0
Thu Sep 19, 2019 10:18 pm
Well, it has been about 10 weeks since I kicked off this thread and I still have not found and datasheets or other documentation on the BCM2711B0 ! Anyone else ?
One thing I am very curious about is if there more than 1 channel of PCIe ?
Segue - Does Broadcomm actually directly sell any of the other chips that have been spun for the Raspberry Foundation. I would think the volume would not be high enough for them to "spin" a chip for just one customer !
While everybody is having fun with the 4B, I am sure that people are already working on Pi 5. Pi 4 had several breakthroughs : large memory, USB-C power (technically called USB Power Delivery (USB PD) ) and PCIe. My dream for Pi 5 would optional 8Gb of memory, 15V@3A power (from the USB PD spec), and at least 4 lanes of PCIe (V3.x is adequate), one for USB, one for Ethernet/WiFi, one for SD Express and a spare.
An unassigned PCIe lane and faster boot/SSD memory, more main memory and power and NOW you would have a viable desktop !
Paeryn
Re: BCM2711B0
Fri Sep 20, 2019 1:40 am
Until Broadcom or RPF/RPT (if they are allowed to, I don't know whether RP has the rights to without BCM's permission) get around to it you'll just have to wait, I'm pretty sure that as soon as they are publically available you'll see posts on here saying so. I doubt it being a major priority though, Broadcom don't sell the chips publically and RPF/RPT are hard at work, making documentation fit for general release is time consuming, especially when their engineers can probably just ask someone who knows if they need anything.
From what has been said in other threads there is just one single lane PCIe and on the RPi that is connected to the USB3 hub.
Possibly they do sell them to other companies but likely such companies aren't going to advertise what SoC they use.
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
Gavinmc42
Re: BCM2711B0
Fri Sep 20, 2019 1:46 am
The Peripheral manual is being edited, it's big, so we are told.
Only one PCI-e channel.
Keep dreaming - Pi6 128GB NVRAM.....
My home Desktop Mint box has been replaced by the Pi4B1, then the Pi4B2 and next week the Pi4B4 ;)
Just depends on what your "Viable" Desktop requirements are.
I'm dancing on Rainbows.
cleverca22
Re: BCM2711B0
Fri Dec 06, 2019 4:17 am
[clever@amd-nixos:~/apps/rpi/rpi-eeprom/firmware/beta]$ ls -lh main-body.bin bootconf.txt memsys0?.bin mcb.bin
-rw-r--r-- 1 clever users  212 Dec  3 21:24 bootconf.txt
-rw-r--r-- 1 clever users  61K Dec  3 21:24 bootcode.bin
-rw-r--r-- 1 clever users 3.8K Dec  3 21:24 mcb.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys00.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys01.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys02.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys03.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys04.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys05.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys06.bin
-rw-r--r-- 1 clever users  21K Dec  3 21:24 memsys07.bin
using the python code that extracts `bootconf.txt` for updating config, i reverse engineered the spi firmware files, and extracted all of their contents
currently, ~232kbyte are used, the `memsys??.bin` files have something to do with ddr4, and thats about all ive been able to figure out so far
there isnt enough room for a `start.elf`, and without that, the ARM core will never boot
any custom OS would either need to be a VC4 os (just overwrite the `bootcode.bin`)
or possibly rely on undocumented abilities of the current bootcode to load a (custom) `start.elf` from SPI flash, and then make your own smaller VC4 os, with less of the bootstrap pains
michals
Re: BCM2711B0
Tue Feb 18, 2020 7:51 pm
None. If this is in any way similar to Pi 3 then you can only boot in the 'official' way - from SD card or Ethernet.
The bootcode.bin in the SPI flash is signed so that you cannot replace it, and does not support booting from useful devices like USB or SPI.
You could overwrite it and then the mask rom would skip reading the SPI and you could boot from USB but the only signed bootode.bin you have is the one in SPI flash that does not support it. The mask rom is actually quite flexible when it comes to possible boot media but because it's locked to signed bootcode.bin you cannot make use of that. And the start4elf is not signed so there is no security bough by this inflexibility. A truly ingenious design.
cleverca22
Re: BCM2711B0
Wed Feb 19, 2020 4:23 am
and some users have poured over raw asm enough, to extract the hmac keys for the rpi4...
i now have the ability to sign my own files, but i dont know how to bring ddr4 online, while i can replace the bootcode.bin, i loose access 99.99% of the ram on the machine
LdB
Re: BCM2711B0
Thu Feb 20, 2020 2:40 am
Wow all I can do is applaud your tenacity and hard work.
szediwy
Re: BCM2711B0
Sat Jan 02, 2021 9:11 pm
The peripheral Base address is 0xFE000000 on the Raspberry Pi 4B.
I tried to find that - how did you find the base address?
cleverca22
Re: BCM2711B0
Sun Jan 03, 2021 8:28 am
https://www.raspberrypi.org/documentati ... dresses.md
bcm_host_get_peripheral_address() should tell you, when under linux
https://gist.github.com/cleverca22/64b1 ... tb-dts-L64
the device-tree passed to the kernel also says to map 0x7c to 0xfc, which means 7e is mapped to fe
but note that the 2711 can have it at 2 locations, based on the low-peripheral mode flag:
https://www.raspberrypi.org/documentati ... 11_1p0.pdf
page 9
Re: BCM2711B0
Sun Jan 03, 2021 10:46 am
That page needs to be updated for the Pi 4/CM4.
Unreadable squiggle
Re: BCM2711B0
Sun Jan 03, 2021 1:46 pm
Please post an issue in the docs repo so I don't forget it!
Re: BCM2711B0
Sun Jan 03, 2021 3:24 pm
Done. I hope I got it right. :)
Unreadable squiggle
