Help WIth GPIO C module
Posted: Tue Jul 02, 2019 8:46 am
by ElasticBottle
Hi guys,
I am new to Raspberry Pi, and have been trying to mess around with it in C.
I am running this on a bare-metal Pi, following along this page: http://cs107e.github.io/assignments/assign2/#submit
Just to be clear, I am not a student there, just a regular kid trying to learn operating systems using their material. Otherwise, I would have approached the staff there for help instead.
With that clarified, below's a bit more on my specific problem:
Everything is ran on a rpi 1 model A+
I am trying to write a module.
The gpio_write function that sets the GPIO pin module to be SET(on) or CLR(off) depending on the value 1 or 0.
The gpio_read module then returns whether a particular pin has been most recently SET or CLR by reading the LEV register.
#define GPIO_CLR0 ((unsigned int *) 0x20200028)
#define GPIO_SET0 ((unsigned int *) 0x2020001c)
#define GPIO_LEV0 ((volatile unsigned int *) 0x20200034)
#define SET (int) 1
#define BYTEDIFF 4
void gpio_write(unsigned int pin, unsigned int value) {
    if (pin < GPIO_PIN_FIRST || pin > GPIO_PIN_LAST) { return;}
    int* setting_loc;
    if (value) {
        setting_loc = GPIO_SET0 + (BYTEDIFF * (pin / 32));
    else {
        setting_loc = GPIO_CLR0 + (BYTEDIFF * (pin / 32));
    *setting_loc = (SET << (pin % 32));
unsigned int gpio_read(unsigned int pin) {
        return GPIO_INVALID_REQUEST;
    volatile unsigned int* loc = GPIO_LEV0 + (BYTEDIFF * (pin / 32));
    int is_set = (SET << (pin % 32)) & *loc;
    return is_set >> (pin % 32);
In order to ensure that everything is working, I created a test module with a test function, but the assert keeps failing. Am I doing something wrong?
Assert is a module that blink the Pi's red light when failed, and shows green when it passes. It was provided in the starter file https://github.com/cs107e/lab2/blob/mas ... g/assert.h so I doubt it's wrong
// Tests for the SET and CLR register in gpio module
// Does so by looping over all GPIO pins except 14, 15, 37, and 42
// Sets each pin to be high, asserts, and then sets it to low and asserts
void test_gpio_read_write_function() {
    gpio_write(55, 1);
    assert(gpio_read(55) == GPIO_INVALID_REQUEST);
    for (int i = GPIO_PIN0; i <= GPIO_PIN_LAST; i ++) {
        if (i == GPIO_TX || i == GPIO_RX || i == GPIO_PIN35 || i == GPIO_PIN47){
            continue;
        gpio_write(i, 1);
        assert(gpio_read(i) == 1);
        gpio_write(i, 0);
        assert(gpio_read(i) == 0);
Re: Help WIth GPIO C module
Posted: Tue Jul 02, 2019 9:14 am
by joan
Could you confirm you are using bare metal, i.e. you are not running this program under Linux?
Posted: Tue Jul 02, 2019 11:29 am
by mahjongg
Doesn't seem to be a "beginners" subject, and the assignment seems to be to do some bare metal programming, so moving this to bare metal.
Posted: Tue Jul 02, 2019 2:42 pm
by LdB
hmmm I seem to only remember the Pi1 having 54 GPIO
I am very dubious of this .. check how many GPIO a Pi1 has and even if it exists does it even go to the real world?
gpio_write(55, 1);
Posted: Tue Jul 02, 2019 3:49 pm
by ElasticBottle
mahjongg wrote: Doesn't seem to be a "beginners" subject, and the assignment seems to be to do some bare metal programming, so moving this to bare metal.
Alright, thank you so much for the re-categorization! I apologize for my lack of experience here.
joan wrote: Could you confirm you are using bare metal, i.e. you are not running this program under Linux?
Yes I'm using bare metal! Not sure how to confirm it though, I compile using the GCC -ffreestanding flag if that helps. And if it's any more help, I have also pushed on assembly code that worked before
LdB wrote: hmmm I seem to only remember the Pi1 having 54 GPIO
gpio_write(55, 1);
Yes! You're right, attempting to set 55 is to make sure that my program handles dubious request properly. In case of
 gpio_write(...)
function, it simply returns without doing any setting or clearing, the read function returns an invalid request
Posted: Tue Jul 02, 2019 6:29 pm
by LdB
This is is a really weird test
pin is unsigned so it can't go negative and the GPIO start from zero so it seems to be nonsense.
Now to what you problem is ... C POINTER ARITHMETIC
What exactly do you think this does?
Give you the tip the pointer doesn't equal what you think it does ... try removing the BYTEDIFF
volatile unsigned int* loc = GPIO_LEV0 +  (pin / 32);
GPIO_LEV0 is a pointer when you add to it already multiplies by the size of the thing it points to as always happens in C
Posted: Wed Jul 03, 2019 4:09 am
by ElasticBottle
I see, so does simply changing it to:
 if (pin > GPIO_PIN_LAST)
make the check better? as just a form of safeguard against typo
THank You!! That was my mistake due to my poor understanding of C pointer arithmetic. But this clarifies it for me!
At the same time, I still can't seem to pass this portion of the code on my test:
            continue;
        gpio_write(i, 1);
        gpio_write(i, 0);
Just to check my understanding, writing 1 to the SET register for a pin will result in its LEV register to become 1too, is that correct?
Similarly, writing 1 to the CLR register for a pin will result in 0 in the LEV register for that pin.
Posted: Wed Jul 03, 2019 6:55 am
by LdB
I would assume so but your write and read have same C pointer bug did you fix them?
Basically anywhere you used this "BYTEDIFF" is bugged
Yes this makes more sense
Posted: Wed Jul 03, 2019 7:10 am
by ElasticBottle
Yeap!
my current code looks like this
#define SET (int) 1
    if (pin > GPIO_PIN_LAST) { return;}
    unsigned int* setting_loc;
    if (value) {
        setting_loc = GPIO_SET0 + (pin / 32);
    else {
        setting_loc = GPIO_CLR0 + (pin / 32);
    unsigned int is_set = (SET << (pin % 32)) & *loc;
Posted: Wed Jul 03, 2019 12:53 pm
by LdB
Looks right now ... mine aren't much different
bool gpio_output (unsigned int gpio, bool on)
	if (gpio < MAX_GPIO_NUM) 		// Check GPIO pin number valid
		volatile uint32_t* p;
		uint32_t bit = 1 << (gpio % 32);		// Create mask bit
		p = (on) ? &GPIO->GPSET[0] : &GPIO->GPCLR[0];	// Set pointer depending on on/off state
		p[gpio / 32] = bit;		// Output bit to register number
		return true;			// Return true
	return false;		// Return false
bool gpio_input (unsigned int gpio)
		uint32_t mem = GPIO->GPLEV[gpio / 32];	// Read port level
		if (mem & bit) return true;	// Return true if bit set
Posted: Fri Jul 05, 2019 6:14 pm
by ElasticBottle
Thank you so much! And sorry for the delayed response! I'm currently serving national Service so I don't get to check back when I'm in the jungle.
Will give this a go when I reach home sometime over the weekends and post my results then.
Thanks so much again for your help LdB!
Posted: Mon Jul 08, 2019 9:31 am
by ElasticBottle
LdB wrote: Looks right now ... mine aren't much different
Finally got the chance to try to code out and it worked!
Turns out, there seems to be some dead gpio pins on board my rpi :(
Thanks so much for your time and help LdB! And sorry for troubling you!
