Pierrick
Re: FreeRTOS Sucessfully Ported
Mon May 27, 2013 5:11 pm
tufty wrote:You need to FAT32 format the card, copy the various bits of GPU firmware on there, and then simply copy the kernel.img onto the card.
Sorry I'm new on this and I don't know where to find "the various bits of GPU firmware"
President of I-Grebot robotics association
http://www.igrebot.fr
Snigelson
Fri Jul 26, 2013 2:08 pm
Hi guys.
I have rewritten a lot of the interrupt functionality and sent a pull request.
timr wrote:Your EnableInterrupt() and DisableInterrupt() look like mine now! I modified them slightly to return -1 for invalid nIRQ
I think this is the only thing from this thread i forgot to implement. Next time though.
I also added a three functions to gpio.c to handle gpio interrupts. So now, for example, if you want to get an interrupt on a rising edge, just do something like this. Code not tested, just assumed correct.
void Your_ISR(int nIRQ, void* param)
    [... code here ...]
    /* Acknowledge the interrupt */
    ClearGpioInterrupt(PIN_NUMBER);
void Start_Your_Interrupt()
    /* Enable detect for the pin */
    EnableGpioDetect(PIN_NUMBER,DETECT_RISING);
    /* Register the interrupt handler */
    RegisterInterrupt(BCM2835_IRQ_ID_GPIO_0,RecvUART_interrupt,NULL);
    /* Enable the UART interrupt */
    EnableInterrupt(BCM2835_IRQ_ID_GPIO_0);
Regards,
dpc06+t1wG0S/P6frt6iR6fQODFsMCPrXr0+vbVYLzghsro5BpyK61/qRyqLvIQ1
Snigelson
Tue Aug 06, 2013 7:25 am
Nobody wanna try this out? Looked like there was some interest in this, at least.
jaume.vila
Mon Sep 09, 2013 10:13 am
i'm new with the raspberry pi.
I've succesfully build the freertos port, copied the kernel.* files to the SD card but nothing happens.
I'm not sure if i've copied the correct files or maybe i forgot something.
It's supposed to automatically execute de demo project? blink a led connected to the GPIO16?
Thanks in advance
fuffkin
Wed Sep 18, 2013 7:32 am
What's a typical boot time(s) for FreeRTOS and what could be the fastest time?
Sleepy Pi - Extend RPi battery life with a plugin Power Management & Arduino I/O board
http://www.spellfoundry.com
morger
Fri Nov 08, 2013 11:31 am
Hi all,
I'd like to use the Raspberry Pi's ethernet port with FreeRTOS. So what would I have to do to get a working ethernet port?
Thanks in advance
robu
Sun Nov 17, 2013 5:53 pm
Hi, I am trying to write a driver for UART.
I am initializing the serial interface
UARTDriver SerialInit(UARTConfig * pConfig)
	int i;
	unsigned long ra;
	DisableInterrupts();
	if (pConfig == NULL ) UDRV.config = &default_serial_config;
	else UDRV.config = pConfig;
	UART ->CR.REG = 0;
	ra = GPIO_REGS ->GPFSEL[1].REG;
	ra &= ~(7 << 12);
	ra |= 4 << 12;
	GPIO_REGS ->GPFSEL[1].REG = ra;
	GPIO_REGS ->GPPUD[0].REG = 0;
	for (i = 0; i < 150; i++)
		dummy(i);
	GPIO_REGS ->GPPUDCLK[0].REG = (3 << 14);
		dummy(i);
	GPIO_REGS ->GPPUDCLK[0].REG = 0;
	UART ->ICR.REG = 0x7FF;
	//Setting the baud rate
	ra = (configUART_CLOCK << 2) / UDRV.config->baudrate;
	UART ->IBRD.REG = ra >> 6;
	UART ->FBRD.REG = ra & 0x3F;
	//UART ->LCRH.REG = 0x70;
	UART ->IMSC.REG = 0x0010;
	UART ->IFLS.REG = 0x00;
	UART ->CR.REG = 0x301;
	RegisterInterrupt(BCM2835_IRQ_ID_UART, vUARTIrqHandler, NULL );
	EnableInterrupt(BCM2835_IRQ_ID_UART);
	EnableInterrupts();
	return UDRV;
And I am trying to catch the interruption
static void vUARTIrqHandler(int nIRQ, void *pParam)
	if (UART ->MIS.BITS.BIT1)
		SerialSendChar(SerialGetChar());
	//SerialSendChar('I');
	//SerialSendChar('R');
	//SerialSendChar('Q');
	//Clear transmit interrupt
	//UART ->ICR.BITS.BIT5 = 0;
	//Clear receive interrupt
	//UART ->ICR.BITS.BIT6 = 0;
	//Lets acknowledge everything
I started the LED in a thread, so when I am pushing the button two times the LED stop flashing. Any thought what can be the problem?
The whole code can be found under the following git repository https://github.com/runguran/RaspberryPi ... rs/BCM2835
Robert
Arman10
Mon Mar 10, 2014 7:06 am
Hi All,
Fantastic!! I quite easily built and ran your demo.
How can I change demo project? somethings that can visually see.
Can I use different demo projects that is available on freertos.org?
Arman
GibbseyNZ
Mon Apr 07, 2014 10:04 pm
FreeRTOS running on the new raspberry pi compute module would make a great base for an open source PLC.
http://www.raspberrypi.org/raspberry-pi ... w-product/
jshintani
Thu May 29, 2014 9:33 pm
Has anybody successfully gotten printf (stdio) to work?
I have followed a few tutorials and have compiled syscalls.c to an object file. But when I try and link the two together it blows up.
Can someone point me to a good tutorial or walk me trough it?
Greatly appreciated,
Jason
dpmjoshi
Thu Jan 22, 2015 6:50 pm
Hi Everyone,
I am new to Raspbery Pi community,
I am trying to port FreeRTOS on PI by using your port and documentation.
But I am facing some problem while compiling the code,
after hitting make i get following errors
Dark Builder - Unified Build Environment
Version (1.0.0 - Armstrong)
arm-none-eabi-ld: cannot find -lgcc
arm-none-eabi-ld: cannot find -lce
make: *** [kernel.elf] Error 1
Can anyone please guide me regarding these errors,
Thanks in advance.
prabhakar_est
Fri Jan 30, 2015 1:51 pm
Hi... Hello James
Firstly thanks for the effort.
I'm stuck. I'm able to build the port, and even load it to the SD card, but still no blinking LED. Could you venture a guess as to what I might be doing wrong?
root@ubuntu:/home/prabhakar/Downloads/RaspberryPi-FreeRTOS-master# sudo dd if=kernel.img of=/dev/sdb
100+1 records in
100+1 records out
51440 bytes (51 kB) copied, 0.0279959 s, 1.8 MB/s
After this point, I remove the SD card, stick it into the RPi, and plug in the micro-USB. I see the red (PWR) light come up, but nothing else happens.
prabhakar_est
Fri Jan 30, 2015 2:17 pm
hi James,
100+1 records in
100+1 records out
after this i inserted the SD card in RPi B+, LED is not blinking.
i connected the LED to pin no.38(GPIO16).
not working, so can u help me in this???
by,
prabhakar
Avoncliff
Sun Feb 01, 2015 10:48 am
Hi prabhakar
This was answered mar15th last year.
The raspberry has a slightly odd boot process in that the GPU boots first and then starts the ARM.
To produce a boot SD you need to format the card to FAT32 and install the bootcode.bin and start.elf files for the GPU, and then add your new kernel.img file.
The arm chip will then run the kernel.img file.
You can get the first two files from any current booting system.
David
Ckcompton
Thu Apr 23, 2015 5:43 pm
I have the Rpi B+. How do you install FreeRTOS using a windows computer? Will the hdmi port work?
sree_yuvi
Sun Jan 24, 2016 6:51 pm
Hi David, James,
1. Where can I get bootcode.bin and start.elf?. I have Rasbian OS binaries which contains these two files, can I just copy them?.
2. Do I need to copy cmdline.txt and config.txt present in the Raspian OS?.
3. In windows I simply COPIED bootcode.bin, start.elf, kernel.img to SD disk, is it good enough? I have properly formatted with FAT32. My question here is just copying good enough or something else I have to do?.
4. After powering on Raspberry Pi, In the monitor I am only getting colored screen, nothing else. Is it the right behavior?.
Please help me in clearing my doubts.
Thanks,
Sreekanth.
dwelch67
Sun Jan 24, 2016 11:52 pm
Go to http://github.com/raspberrypi, you DO NOT need to download
the repo. Go to the firmware directory and then the boot directory.
For each of these files, bootcode.bin and start.elf (NOT kernel.img,
dont need it, too big)(loader.bin is no longer used/required). Click
on the file name, it will go to another page then click on View Raw and
it will let you download the file.
sree_yuvi
Mon Jan 25, 2016 6:27 am
Thanks dwelch67.
I have copied bootcode.bin, start.elf from the link you have provided.
I have also copied kernel.img to SD card. when I power it on the device I can't see any log messages on monitor.
Does some log messages are displayed on monitor while loading bootcode.bin/start.elf/kernel.img? I see colored screen without any
activity.
Thanks.
sree_yuvi
Mon Jan 25, 2016 2:27 pm
I am using RaspberryPi 2, and connected LED to GPIO16(pin-36), LED is not blinking.
Does same code work for RaspberryPi 2?.
Appreciate your help.
dwelch67
Tue Jan 26, 2016 1:33 am
https://github.com/dwelch67/raspberrypi
try the blinker01/pi2 directory example copy blinker01.bin as your kernel7.img file and see if the leds blink, should just work.
if you have a uart connected up you can try the bootloader07/kernel7.img file as your kernel7.img file.
remember to sync and safely unmount your flash drive.
if these things dont work then as mentioned before by someone partition and format your sdcard as a FAT32, then copy these files over again
sree_yuvi
Tue Jan 26, 2016 9:11 am
dwelch67, thanks for the reply.
In the original example what are all files we need to copy to SD card.
1. kernel.img
2. kernel.elf (required ??)
3. bootcode.bin
4. start.elf
5. cmdline.txt (required ??)
6. config.txt (required ??)
any other file?.
hellblessar
Wed Oct 04, 2017 8:00 pm
I would like to bump the problem with files on SD card. I've upload all required files and I just see colourful screen and no blinking LED. Do you have an file list what should be on the card to make FreeRTOS work properly?
Best regards,
Pawel
Wed Oct 04, 2017 8:08 pm
Best regards,
Pawel
It appears you have resurrected a Post which predates the RPi 2B ? / 3B and Zero :shock:
It would appear that a newer community project to port FreeRTOS is here:
https://github.com/Forty-Tw0/RaspberryPi-FreeRTOS
""understanding the theoretical, but not always the end goal""
My other Devices are the ChromeBit CS10, ChromeCast & Huawei Mate 10 Pro SmartPhone
Return to “Bare metal”
Who is online
Users browsing this forum: No registered users and 2 guests
