Oops, I have overseen some braces in the Diff of the Linux driver update referenced above. So the fix does modify the function of the driver in an important manner.okenido wrote: ↑Sat Oct 13, 2018 9:46 amApplying those changes fixed the problem ! I can do a pull request if you wantrst wrote: ↑Fri Oct 12, 2018 1:38 pm
Circle is using the original algorithm for detecting touch screen events from the Linux driver. There has been an update to the Linux driver later, which fixes a spurious event issue from the touch screen. This fix has not been applied to the Circle driver yet. I will check this soon.
Yes, please add a pull request. Thanks.
