cmarrin
Why does my Raspberry Pi Zero W report that it has 256MB?
Wed Sep 26, 2018 6:16 pm
I'm working on some bare metal mailbox code. So I decided to test it out by getting some info from the system. I've sent the ARMMemory (0x00010005) and VCMemory (0x00010006) commands and this is what I get back:
ARMMemory: start=0x00000000, size=0x08000000
VCMemory: start=0x08000000, size=0x08000000
That's showing that I have 256MB. But all the specs I've read say that these boards have 512MB. This is a board I bought from Adafruit and shows as rev 1.1, so I don't think it's some kind of grey market board. I also have an older model B+. It also shows that it has 256MB. But it's from 2014 and it looks like that's what those boards should have.
Are the specs lying, or does the Zero W set it set it self up with half it's available memory? Or am I misinterpreting the response from the mailbox?
rst
Re: Why does my Raspberry Pi Zero W report that it has 256MB?
Wed Sep 26, 2018 6:40 pm
I guess, the firmware file fixup.dat is missing on your uSD card. Without it the firmware cannot relocate the file start.elf in memory.
Imperf3kt
Contact: Twitter
Wed Sep 26, 2018 9:11 pm
Your Pi0w did not come from 2014 as they weren't made until 2017.
Did you perhaps mean the Raspberry Pi model A?
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
cmarrin
Wed Sep 26, 2018 10:26 pm
Sorry, I wasn't clear. My Raspberry Pi model B+ is from 2014. That's why I think it probably only has 256MB.
ericcooper
Wed Sep 26, 2018 10:38 pm
Boot it with a Raspbian SD card and see how much memory the kernel reports in the log, or the "free" command prints. If it says 512M, there's probably some low-level hardware initialization that you haven't done, or are doing differently.
cmarrin
Wed Sep 26, 2018 10:41 pm
Thanks! That was the problem. Everything worked without it, so I assumed it was an optional file! With its inclusion, I now get:
ARMMemory: start=0x00000000, size=0x1c000000
VCMemory: start=0x1c000000, size=0x04000000
That's 64MB for the VC, which the docs say is the default, and 448MB for the ARM. All is well. Not only that but my model B+ also reports 512MB. So I have all the memory in the world now
Imperf3kt
Contact: Twitter
Wed Sep 26, 2018 10:44 pm
No, sorry it was actually my mistake. I misread your post.
55:55:44:44:4C
52:4C:52:42:41
Thu Sep 27, 2018 5:23 am
The B+ had 512MB RAM. It may be that your GPU memory split is set to use 256MB/256MB, which would limit the memory available to Linux.
The only Pi models with 256MB RAM were the original (1)B from 2012 and the (1)A.
