LizardLad_1
CPU and GPU memory split?
Sat Aug 04, 2018 7:20 am
How is it possible to determine what is GPU memory and what is available to the CPU?
Re: CPU and GPU memory split?
Sat Aug 04, 2018 7:24 am
Use the vcgencmd command to check the currently configured memory split.
[email protected] ~ $ vcgencmd get_mem arm
arm=448M
[email protected] ~ $ vcgencmd get_mem gpu
gpu=64M
[edit]
I just realised this is the Bare Metal forum. :oops:
There are mailbox calls to get the memory split. I can't remember the details of the top of my head, and I'm away from home this weekend.
LizardLad_1
Sat Aug 04, 2018 9:52 am
So once I have the memory split how would I get the start and end addresses or the start and size?
bzt
Sat Aug 04, 2018 5:26 pm
So get the value of the split with a mailbox call
    mbox[0]=8*4;
    mbox[1]=0;
    mbox[2]=0x10005; // get memory size
    mbox[3]=8;
    mbox[4]=0;
    mbox[5]=0;
    mbox[6]=0;
    mbox[7]=0;
    if (!mbox_call(MBOX_CH_PROP, mbox)) {
        // on failure (should never happen) assume 512Mb memory max
        mbox[6]=512*1024*1024;
Now the memory map looks like:
0 - mbox[6]: CPU memory (you can use it from your ARM code)
mbox[6] - 0x3F000000: GPU memory (don't touch)
0x3F000000+: MMIO area
Remember that your code is also in CPU memory, from 0x80000 - &_end, you probably don't want to accidently overwrite that. It's safe to say you should use &_end - mbox[6] as free memory for your malloc.
Cheers,
bzt
