ardera
Understanding the mailbox property interface
Wed Jul 18, 2018 10:14 am
I am really confused about this documentation: https://github.com/raspberrypi/firmware ... -interface
For example: it says "concatenated tags" in there. That does mean the complete tags are placed in that buffer, not the pointers to them, doesn't it? (cause using pointers it'd be a lot easier to implement IMO)
Next, when I want to find out the VideoCore firmware revision for example: the property tag would look like this, wouldn't it?
struct {
	uint32_t id = 0x00000001;	// ID 1 = get VC firmware revision
	uint32_t vbuffer_size = 0;	// no request value, so the value buffer size is 0
	uint32_t req_resp_code = 0;	// bit 31 clear = request
} p_tag_t;
(no real C i know)
But where does the return value go then? does the GPU shift the whole property request by 4 bytes in order to fit its response (the firmware revision) into the value buffer? (seems highly unlikely)
Or do I have to include a value buffer large enough for the return values?
Re: Understanding the mailbox property interface
Wed Jul 18, 2018 10:31 am
I've started writing a more comprehensive mailbox document, the work in [progress is here
https://github.com/raspberrypi/document ... /mailboxes
Does that help?
ardera
Wed Jul 18, 2018 12:44 pm
Yep, now I understand. Thanks!
Wed Jul 18, 2018 1:25 pm
Does that help?
In your article can you include a simple sample C program that anyone can cut'n'paste and get running. Do something naff like reading the CPU serial with a mailbox call.
(Yes I know I can write that, I'm thinking about the newbies.)
Edit: Or just steal https://github.com/AndrewFromMelbourne/ ... _mailbox.c
Note:Having anything remotely humorous in your signature is completely banned on this forum.
Wed Jul 18, 2018 3:44 pm
Does that help?
Yes, don't see why not. Similar to the linked code, but with comments to explain everything. I'll add it to the list.
Wed Jul 18, 2018 4:26 pm
Turns out we already had a link to our own example source code on the first page, but I have also added a link to the example linked above, as that is pretty clear and simple.
bzt
Wed Jul 18, 2018 4:42 pm
Considering this question was asked under Bare Metal, I suppose opening "/dev/vcio" (as in the example linked above) is not really an option. I think this example would be more appropriate (also MIT licensed):
https://github.com/bztsrc/raspi3-tutori ... xes/main.c
Just a sidenote, because of the varying number of tags, I have used an uint32_t array instead of a struct. Although if you don't plan to take advantage of more tags in a single query you can use your struct as well.
Cheers,
bzt
